<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Bug with PA 9.11.01 and extraction of long file&#x2F;folder names]]></title><description><![CDATA[<p dir="auto">While testing PA 9.11.01 to see if the problem I reported with long preparation time, I noticed another problem. In my test archive, I have lots of files/folders with very long path names.</p>
<p dir="auto">Near the end of the extraction (after right-click and Extract Here in Explorer), I got the following message:</p>
<p dir="auto">Error creating destination file "Extracting:</p>
<p dir="auto">G:\Essential_Software_Main_CD\Offline_Explorer_Settings\download[www.techsmith.com\products\studio\tutorials\showmenu=About](<a href="http://www.techsmith.com" target="_blank" rel="noopener noreferrer nofollow ugc">www.techsmith.com</a>\products\studio\tutorials\showmenu=About) TechSmith;image=\images\menu\aboutoff_2.gif;overimage=\images\menu\Descr.WD3".</p>
<p dir="auto">Check that file is not in use.</p>
<p dir="auto">When you click OK, all files afterwards are not extracted.</p>
<p dir="auto">When I checked this file in Explorer, it had actually been extracted, but some of the folders in the same folder as Descr.WD3 had not been extracted. Several problems here:</p>
<ol>
<li>
<p dir="auto">The error message refers to the file that was last extracted, instead of the file/folder that could not be extracted.</p>
</li>
<li>
<p dir="auto">PA is still not supporting the maximum number of characters. I know this because WinZip successfully extracted some files/folders that PA could not. WinZip still did have some problems though (eg. it could not extract the following path (253 chars) “G:\Essential_Software_Main_CD\Offline_Explorer_Settings\download[www.techsmith.com\products\studio\tutorials\showmenu=About](<a href="http://www.techsmith.com" target="_blank" rel="noopener noreferrer nofollow ugc">www.techsmith.com</a>\products\studio\tutorials\showmenu=About) TechSmith;image=\images\menu\aboutoff_2.gif;overimage=\images\menu\showmenu=Products;image=\images\menu\tabs_ad_2.gif;overimage=.”).</p>
</li>
<li>
<p dir="auto">PA stops extraction immediately. WinZip asks “Would you like WinZip to try to continue with the next file?” with a yes or no. Can you make PA do this. I’d also like a “Yes to All” button, which WinZip does not have.</p>
</li>
</ol>
<p dir="auto">Also, at the end of the extraction, WinZip then tells you there were problems with the extraction, Do you want to see the report ?</p>
<p dir="auto">Can you also make PA do this as well.</p>
<p dir="auto">Let me know if you need any more info.</p>
]]></description><link>https://forums.powerarchiver.com/topic/425/bug-with-pa-9-11-01-and-extraction-of-long-file-folder-names</link><generator>RSS for Node</generator><lastBuildDate>Sat, 14 Nov 2026 08:23:53 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/425.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 Dec 2004 22:34:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Bug with PA 9.11.01 and extraction of long file&#x2F;folder names on Fri, 31 Dec 2004 09:47:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/deipotent" aria-label="Profile: deipotent">@<bdi>deipotent</bdi></a>:</p>
<p dir="auto">The error message “Check that file is not in use” is incorrect as well. It should say something like “The filename or extension is too long” instead.</p>
<p dir="auto">indeed.</p>
]]></description><link>https://forums.powerarchiver.com/post/7093</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7093</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 31 Dec 2004 09:47:17 GMT</pubDate></item><item><title><![CDATA[Reply to Bug with PA 9.11.01 and extraction of long file&#x2F;folder names on Fri, 31 Dec 2004 05:16:12 GMT]]></title><description><![CDATA[<p dir="auto">The error message “Check that file is not in use” is incorrect as well. It should say something like “The filename or extension is too long” instead.</p>
]]></description><link>https://forums.powerarchiver.com/post/7092</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7092</guid><dc:creator><![CDATA[deipotent]]></dc:creator><pubDate>Fri, 31 Dec 2004 05:16:12 GMT</pubDate></item><item><title><![CDATA[Reply to Bug with PA 9.11.01 and extraction of long file&#x2F;folder names on Thu, 30 Dec 2004 23:40:14 GMT]]></title><description><![CDATA[<p dir="auto">Yep, this issue has been confirmed in another thread. We will be checking it out for 9.2.</p>
<p dir="auto">thanks,</p>
]]></description><link>https://forums.powerarchiver.com/post/7089</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7089</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Thu, 30 Dec 2004 23:40:14 GMT</pubDate></item></channel></rss>
