<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Bug in beta opens anything]]></title><description><![CDATA[<p dir="auto">basically try opening any file with the latest beta and it shows up in pa toolbar as if it has been opened but nothing on the screen. shouldn’t it say can’t open it, no plugins installed</p>
]]></description><link>https://forums.powerarchiver.com/topic/4148/bug-in-beta-opens-anything</link><generator>RSS for Node</generator><lastBuildDate>Fri, 06 Mar 2026 12:13:04 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/4148.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 10 Oct 2010 09:30:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Bug in beta opens anything on Thu, 28 Oct 2010 14:16:54 GMT]]></title><description><![CDATA[<p dir="auto">issue has been fixed in new beta, you can find it here;</p>
<p dir="auto"><a href="http://www.powerarchiver.com/test/release10/powarc117007.exe" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.powerarchiver.com/test/release10/powarc117007.exe</a></p>
]]></description><link>https://forums.powerarchiver.com/post/24089</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/24089</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Thu, 28 Oct 2010 14:16:54 GMT</pubDate></item><item><title><![CDATA[Reply to Bug in beta opens anything on Thu, 14 Oct 2010 10:39:20 GMT]]></title><description><![CDATA[<p dir="auto">thanks david, we have logged it in.</p>
]]></description><link>https://forums.powerarchiver.com/post/23972</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/23972</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Thu, 14 Oct 2010 10:39:20 GMT</pubDate></item><item><title><![CDATA[Reply to Bug in beta opens anything on Tue, 12 Oct 2010 06:39:33 GMT]]></title><description><![CDATA[<p dir="auto">all i did was install the new beta and try and open any file doesn’t matter what format it is it opens up empty it should say can’t openj it as it used too</p>
]]></description><link>https://forums.powerarchiver.com/post/23953</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/23953</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Tue, 12 Oct 2010 06:39:33 GMT</pubDate></item><item><title><![CDATA[Reply to Bug in beta opens anything on Mon, 11 Oct 2010 15:12:44 GMT]]></title><description><![CDATA[<p dir="auto">I think he means any (non-archive) file.</p>
<p dir="auto">In GUI select “Open Archive”<br />
Change “files of type” to&lt;any file=“”&gt;<br />
Select non-archive file</p>
<p dir="auto">e.g. I just tried with a txt and an xml file.&lt;/any&gt;</p>
]]></description><link>https://forums.powerarchiver.com/post/23950</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/23950</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Mon, 11 Oct 2010 15:12:44 GMT</pubDate></item><item><title><![CDATA[Reply to Bug in beta opens anything on Mon, 11 Oct 2010 12:12:56 GMT]]></title><description><![CDATA[<p dir="auto">any file that you open using the Beta comes up empty?</p>
]]></description><link>https://forums.powerarchiver.com/post/23947</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/23947</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Mon, 11 Oct 2010 12:12:56 GMT</pubDate></item></channel></rss>
