<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Remove many files from Archive with one command]]></title><description><![CDATA[<p dir="auto">Hi!<br />
I’m doing some tests with list files in PACOMP and the documentation about this says the following thing.</p>
<p dir="auto">@list : specify list of files for compression (use filename instead of list - see example)</p>
<p dir="auto">I assume this means that I can only use a list file when I create a archive using the -a parameter.</p>
<p dir="auto">I have tried this:</p>
<p dir="auto">pacomp -d Test_Remove.zip @Filelist.txt</p>
<p dir="auto">Archive: D:\Script\Test_Remove.zip<br />
preparing to compress…<br />
*** WARNING: Nothing to add or update…</p>
<p dir="auto">All OK</p>
<p dir="auto">The error probably appears because I can only use a list file when I create the archive and not when delete files from it.</p>
<p dir="auto">Now I can remove one file at a time, but if the Archive is about 1 Gb in size, it will take a lot of time updating the archive after removing one file. It would be better if I could have a list of files that I wanted to remove from the archive. That way I could for example remove 10 files at one time and then update the archive instead of remove 1 file at a time and update the archive 10 times in total.</p>
<p dir="auto">If each update of the Archive takes approximate 5 min, then it would take about 50 min to remove 10 files from an Archive that is 1 Gb in size. If I could remove the 10 files at one time instead, then the whole update would take 5 min instead of 50 min.</p>
<p dir="auto">My question is this:<br />
Is it possible to remove more than one file at a time from an archive using PACL?</p>
<p dir="auto">If not, I’ll put it in a Wishlist for future versions of PACL.</p>
<p dir="auto">Kind Regards<br />
Micke</p>
]]></description><link>https://forums.powerarchiver.com/topic/4003/remove-many-files-from-archive-with-one-command</link><generator>RSS for Node</generator><lastBuildDate>Tue, 17 Nov 2026 11:17:16 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/4003.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 22 May 2010 19:33:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Remove many files from Archive with one command on Mon, 14 May 2012 18:40:52 GMT]]></title><description><![CDATA[<p dir="auto">thanks Micke!</p>
]]></description><link>https://forums.powerarchiver.com/post/28533</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/28533</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 14 May 2012 18:40:52 GMT</pubDate></item><item><title><![CDATA[Reply to Remove many files from Archive with one command on Mon, 14 May 2012 18:28:19 GMT]]></title><description><![CDATA[<p dir="auto"><strong>Test 4 - Archive with full paths including driveletter to the files inside</strong></p>
<p dir="auto"><em>Begin with create the archive T4_FullPathDrive.zip</em></p>
<pre><code>C:\Programs\PACL_Test&gt;pacomp -a -PP T4_FullPathDrive.zip issue4*_en.pdf
PowerArchiver Command Line (PACL)              Version 7.00       [May 11 2012]
Copyright(c) 1998-2012 ConeXware, Inc.  All Rights Reserved.  Shareware Version
Remainder: This is unregistered version of PACL. Please register at http://www.powerarchiver.com
Press &lt;enter&gt;to continue.
Archive Compression Utility -- ZIP,ZIPX,7-ZIP,CAB,LHA,BH,JAR,TAR,GZIP,BZIP2
  Internet: http://www.powerarchiver.com  Email: support@conexware.com
Archive: C:\Programs\PACL_Test\T4_FullPathDrive.zip
  preparing to compress...
  adding: C:\Programs\PACL_Test\issue40_en.pdf   --&gt; Done. [17%]
  adding: C:\Programs\PACL_Test\issue41_en.pdf   --&gt; Done. [29%]
  adding: C:\Programs\PACL_Test\issue42_en.pdf   --&gt; Done. [40%]
  adding: C:\Programs\PACL_Test\issue43_en.pdf   --&gt; Done. [51%]
  adding: C:\Programs\PACL_Test\issue44_en.pdf   --&gt; Done. [60%]
  adding: C:\Programs\PACL_Test\issue45_en.pdf   --&gt; Done. [72%]
  adding: C:\Programs\PACL_Test\issue46_en.pdf   --&gt; Done. [89%]
  adding: C:\Programs\PACL_Test\issue4_en.pdf   --&gt; Done. [100%]
All OK
C:\Programs\PACL_Test&gt;&lt;/enter&gt;
</code></pre>
<p dir="auto"><em>List the contents of T4_FullPathDrive.zip</em></p>
<pre><code>C:\Programs\PACL_Test&gt;paext -v T4_FullPathDrive.zip
Archive Extr.---ZIP,ZIPX,7Z,CAB,LHA,ARJ,RAR,ACE,TAR,GZ,BZ2,UUE,ZOO,B64,YENC,...
Archive --&gt; C:\Programs\PACL_Test\T4_FullPathDrive.zip [ZIP       ]
Name            Length   Method   Ratio      Size      Date &amp; Time      CRC-32
               9571656    DFLT-N    7%    8863706  08-29-2010 18:09:14 66b5badb
               6178934    DFLT-N    9%    5620586  09-26-2010 04:34:22 efc85625
               6129678    DFLT-N    9%    5607040  11-07-2010 17:44:00 17ae3698
               5902195    DFLT-N    9%    5373646  11-27-2010 21:53:30 7db0c564
               4760023    DFLT-N    8%    4399486  12-31-2010 18:41:22 6e782948
               6268390    DFLT-N    8%    5752164  01-27-2011 20:51:46 648123fa
               9060835    DFLT-N    5%    8605504  02-25-2011 23:27:32 7efbfcaf
               5668696    DFLT-N   11%    5047967  09-06-2007 04:15:00 47eac3f0
*Totals    8  53540407              8%   49271303  05-13-2012 22:02:50
</code></pre>
<p dir="auto"><em>Content of listfile deletelist4.txt</em></p>
<pre><code>C:\Programs\PACL_Test\issue40_en.pdf
C:\Programs\PACL_Test\issue47_en.pdf
</code></pre>
<p dir="auto"><strong>Expected results from the test:</strong> The named files in the listfile will be removed from the archive except <strong>issue47_en.pdf</strong> that doesn’t exists in the archive.</p>
<p dir="auto"><em>Remove the files from T4_FullPathDrive.zip</em></p>
<pre><code>C:\Programs\PACL_Test&gt;pacomp -d T4_FullPathDrive.zip @deletelist4.txt
  deleting: C:\Programs\PACL_Test\issue40_en.pdf
  deleting: C:\Programs\PACL_Test\issue42_en.pdf
  deleting: C:\Programs\PACL_Test\issue46_en.pdf
All OK
</code></pre>
<p dir="auto"><em>List the contents of T4_FullPathDrive.zip after removing the files</em></p>
*Totals    5  28778238              9%   26194609  05-13-2012 22:06:50
</code></pre>
<p dir="auto"><strong>Test result:</strong> Success</p>
Micke</p>
]]></description><link>https://forums.powerarchiver.com/post/28532</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/28532</guid><dc:creator><![CDATA[Micke]]></dc:creator><pubDate>Mon, 14 May 2012 18:28:19 GMT</pubDate></item><item><title><![CDATA[Reply to Remove many files from Archive with one command on Mon, 14 May 2012 18:26:00 GMT]]></title><description><![CDATA[<p dir="auto"><strong>Test 3 - Archive with full paths to the files inside</strong></p>
<p dir="auto"><em>Begin with create the archive T3_FullPath.zip</em></p>
<pre><code>C:\Programs\PACL_Test&gt;pacomp -a -P T3_FullPath.zip issue3*_en.pdf
Archive: C:\Programs\PACL_Test\T3_FullPath.zip
  adding: Programs\PACL_Test\issue30_en.pdf   --&gt; Done. [11%]
  adding: Programs\PACL_Test\issue31_en.pdf   --&gt; Done. [19%]
  adding: Programs\PACL_Test\issue32_en.pdf   --&gt; Done. [25%]
  adding: Programs\PACL_Test\issue33_en.pdf   --&gt; Done. [33%]
  adding: Programs\PACL_Test\issue34_en.pdf   --&gt; Done. [43%]
  adding: Programs\PACL_Test\issue35_en.pdf   --&gt; Done. [57%]
  adding: Programs\PACL_Test\issue36_en.pdf   --&gt; Done. [67%]
  adding: Programs\PACL_Test\issue37_en.pdf   --&gt; Done. [74%]
  adding: Programs\PACL_Test\issue38_en.pdf   --&gt; Done. [84%]
  adding: Programs\PACL_Test\issue39_en.pdf   --&gt; Done. [94%]
  adding: Programs\PACL_Test\issue3_en.pdf   --&gt; Done. [100%]
All OK
</code></pre>
<p dir="auto"><em>List the contents of T3_FullPath.zip</em></p>
<pre><code>C:\Programs\PACL_Test&gt;paext -v T3_FullPath.zip
Archive --&gt; C:\Programs\PACL_Test\T3_FullPath.zip [ZIP       ]
               9972280    DFLT-N    4%    9540376  10-31-2009 01:24:40 fef8e384
               6548726    DFLT-N    7%    6099978  11-28-2009 04:09:52 e139460e
               5634148    DFLT-N    7%    5241368  01-01-2010 09:00:54 0b921e4b
               6742995    DFLT-N    8%    6192159  01-31-2010 00:01:42 e749acf7
               8410553    DFLT-N    4%    8037455  02-27-2010 18:58:54 4118b5ef
              12558118    DFLT-N    3%   12133782  03-28-2010 01:26:32 08444294
               8377704    DFLT-N    5%    7969068  04-30-2010 01:38:10 ecccc46d
               6038837    DFLT-N    7%    5620668  05-28-2010 23:26:24 d26224b4
               8771414    DFLT-N    5%    8363225  06-27-2010 01:53:20 9b399973
               8699322    DFLT-N    6%    8179294  07-31-2010 18:57:42 11341c8e
               4625448    DFLT-N   12%    4084809  09-06-2007 04:15:00 6ea71c54
*Totals   11  86379545              6%   81463764  05-13-2012 22:02:18
</code></pre>
<p dir="auto"><em>Content of listfile deletelist3.txt</em></p>
<pre><code>Programs\PACL_Test\issue30_en.pdf
</code></pre>
<p dir="auto"><strong>Expected results from the test:</strong> The named files in the listfile will be removed from the archive.</p>
<p dir="auto"><em>Remove the files from T3_FullPath.zip</em></p>
<pre><code>C:\Programs\PACL_Test&gt;pacomp -d T3_FullPath.zip @deletelist3.txt
  deleting: Programs\PACL_Test\issue30_en.pdf
  deleting: Programs\PACL_Test\issue32_en.pdf
  deleting: Programs\PACL_Test\issue36_en.pdf
  deleting: Programs\PACL_Test\issue37_en.pdf
All OK
</code></pre>
<p dir="auto"><em>List the contents of T3_FullPath.zip after removing the files</em></p>
*Totals    7  56356576              6%   53091716  05-13-2012 22:06:08
</code></pre>
Micke</p>
]]></description><link>https://forums.powerarchiver.com/post/28531</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/28531</guid><dc:creator><![CDATA[Micke]]></dc:creator><pubDate>Mon, 14 May 2012 18:26:00 GMT</pubDate></item><item><title><![CDATA[Reply to Remove many files from Archive with one command on Mon, 14 May 2012 18:17:10 GMT]]></title><description><![CDATA[<p dir="auto"><strong>Test 2 - Archive with relative paths to the files inside</strong></p>
<p dir="auto"><em>Begin with create the archive T2_RelPath.zip</em></p>
<pre><code>C:\Programs\PACL_Test&gt;pacomp -a -p -r T2_RelPath.zip issue2*_en.pdf
Archive: C:\Programs\PACL_Test\T2_RelPath.zip
  adding: issue20_en.pdf   --&gt; Done. [3%]
  adding: issue21_en.pdf   --&gt; Done. [9%]
  adding: issue22_en.pdf   --&gt; Done. [12%]
  adding: issue23_en.pdf   --&gt; Done. [15%]
  adding: issue24_en.pdf   --&gt; Done. [22%]
  adding: issue25_en.pdf   --&gt; Done. [28%]
  adding: issue26_en.pdf   --&gt; Done. [32%]
  adding: issue27_en.pdf   --&gt; Done. [39%]
  adding: issue29_en.pdf   --&gt; Done. [45%]
  adding: issue2_en.pdf   --&gt; Done. [49%]
  adding: Sub\issue20_en.pdf   --&gt; Done. [53%]
  adding: Sub\issue21_en.pdf   --&gt; Done. [59%]
  adding: Sub\issue22_en.pdf   --&gt; Done. [62%]
  adding: Sub\issue23_en.pdf   --&gt; Done. [65%]
  adding: Sub\issue24_en.pdf   --&gt; Done. [72%]
  adding: Sub\issue25_en.pdf   --&gt; Done. [78%]
  adding: Sub\issue26_en.pdf   --&gt; Done. [82%]
  adding: Sub\issue27_en.pdf   --&gt; Done. [89%]
  adding: Sub\issue29_en.pdf   --&gt; Done. [95%]
  adding: Sub\issue2_en.pdf   --&gt; Done. [100%]
All OK
</code></pre>
<p dir="auto"><em>List the contents of T2_RelPath.zip</em></p>
<pre><code>C:\Programs\PACL_Test&gt;paext -v T2_RelPath.zip
Archive --&gt; C:\Programs\PACL_Test\T2_RelPath.zip [ZIP       ]
issue20_en.pdf
               5100971    DFLT-N    8%    4689771  12-29-2008 18:33:12 7886ed7b
issue21_en.pdf
               6918345    DFLT-N   10%    6200716  02-02-2009 18:02:22 1a15573e
issue22_en.pdf
               4198112    DFLT-N    8%    3868238  02-28-2009 19:00:48 29b825bf
issue23_en.pdf
               4142902    DFLT-N    7%    3841598  03-28-2009 18:07:12 5858f373
issue24_en.pdf
               9579999    DFLT-N    8%    8854714  04-25-2009 17:53:28 180995ed
issue25_en.pdf
               7470190    DFLT-N    8%    6846805  05-30-2009 05:20:32 387318a8
issue26_en.pdf
               5975834    DFLT-N    8%    5493708  06-28-2009 18:27:32 1d0df4ef
issue27_en.pdf
               9205949    DFLT-N    9%    8391698  08-03-2009 00:52:22 ddbb77c4
issue29_en.pdf
               7619151    DFLT-N    6%    7197273  09-26-2009 06:53:10 777a9735
issue2_en.pdf
               6504476    DFLT-N    8%    5987655  06-30-2007 18:13:20 c0c31444
Sub\issue20_en.pdf
Sub\issue21_en.pdf
Sub\issue22_en.pdf
Sub\issue23_en.pdf
Sub\issue24_en.pdf
Sub\issue25_en.pdf
Sub\issue26_en.pdf
Sub\issue27_en.pdf
Sub\issue29_en.pdf
Sub\issue2_en.pdf
*Totals   20 133431858              8%  122746530  05-13-2012 22:01:32
</code></pre>
<p dir="auto"><em>Content of listfile deletelist2.txt</em></p>
<pre><code>issue20_en.pdf
issue22_en.pdf
issue26_en.pdf
issue27_en.pdf
</code></pre>
<p dir="auto"><strong>Expected results from the test:</strong> The named files in the listfile will be removed from the archive. The files in the folder named <strong>Sub</strong> won’t be removed.</p>
<p dir="auto"><em>Remove the files from T2_RelPath.zip</em></p>
<pre><code>C:\Programs\PACL_Test&gt;pacomp -d T2_RelPath.zip @deletelist2.txt
  deleting: issue20_en.pdf
  deleting: issue22_en.pdf
  deleting: issue26_en.pdf
  deleting: issue27_en.pdf
All OK
</code></pre>
<p dir="auto"><em>List the contents of T2_RelPath.zip after removing the files</em></p>
issue21_en.pdf
issue23_en.pdf
issue24_en.pdf
issue25_en.pdf
issue29_en.pdf
issue2_en.pdf
Sub\issue20_en.pdf
Sub\issue21_en.pdf
Sub\issue22_en.pdf
Sub\issue23_en.pdf
Sub\issue24_en.pdf
Sub\issue25_en.pdf
Sub\issue26_en.pdf
Sub\issue27_en.pdf
Sub\issue29_en.pdf
Sub\issue2_en.pdf
*Totals   16 108950992              8%  100302699  05-13-2012 22:04:42
</code></pre>
Micke</p>
]]></description><link>https://forums.powerarchiver.com/post/28530</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/28530</guid><dc:creator><![CDATA[Micke]]></dc:creator><pubDate>Mon, 14 May 2012 18:17:10 GMT</pubDate></item><item><title><![CDATA[Reply to Remove many files from Archive with one command on Mon, 14 May 2012 18:15:42 GMT]]></title><description><![CDATA[<p dir="auto">Hi!<br />
Now I’m finished with my testing of PACL 7.00 [May 11 2012]. I’ve made 4 different tests of removing files from an archive using a listfile.</p>
<p dir="auto">Each test will be in a separate post in this thread</p>
<p dir="auto"><strong>Test 1 - Archive with no paths to the files inside</strong></p>
<p dir="auto"><em>Begin with create the archive T1_NoPath.zip</em></p>
<pre><code>C:\Programs\PACL_Test&gt;pacomp -a T1_NoPath.zip issue1*_en.pdf
Archive: C:\Programs\PACL_Test\T1_NoPath.zip
  adding: issue10_en.pdf   --&gt; Done. [8%]
  adding: issue11_en.pdf   --&gt; Done. [16%]
  adding: issue12_en.pdf   --&gt; Done. [27%]
  adding: issue13_en.pdf   --&gt; Done. [36%]
  adding: issue14_en.pdf   --&gt; Done. [43%]
  adding: issue15_en.pdf   --&gt; Done. [52%]
  adding: issue16_en.pdf   --&gt; Done. [60%]
  adding: issue17_en.pdf   --&gt; Done. [70%]
  adding: issue18_en.pdf   --&gt; Done. [79%]
  adding: issue19_en.pdf   --&gt; Done. [90%]
  adding: issue1_en.pdf   --&gt; Done. [100%]
All OK
</code></pre>
<p dir="auto"><em>List the contents of T1_NoPath.zip</em></p>
<pre><code>C:\Programs\PACL_Test&gt;paext -v T1_NoPath.zip
Archive --&gt; C:\Programs\PACL_Test\T1_NoPath.zip [ZIP       ]
issue10_en.pdf
               5397705    DFLT-N    9%    4917615  02-29-2008 02:17:18 57056248
issue11_en.pdf
               5357464    DFLT-N   11%    4751261  03-28-2008 02:42:10 86a33c50
issue12_en.pdf
               7536694    DFLT-N   10%    6786765  04-25-2008 04:04:48 7f450459
issue13_en.pdf
               6043586    DFLT-N    7%    5637885  05-31-2008 00:49:00 be7f39b6
issue14_en.pdf
               4867559    DFLT-N    7%    4507529  06-27-2008 03:47:06 3c60e08c
issue15_en.pdf
               5406917    DFLT-N   11%    4822067  07-25-2008 17:50:10 f263d610
issue16_en.pdf
               5631112    DFLT-N    8%    5192912  08-30-2008 03:09:20 2b82378a
issue17_en.pdf
               6802691    DFLT-N    9%    6216014  11-02-2008 18:47:56 9e38fd6b
issue18_en.pdf
               5612632    DFLT-N   11%    5019494  11-02-2008 03:47:54 b0a98880
issue19_en.pdf
               7192716    DFLT-N   10%    6490518  11-30-2008 02:35:18 7e2cf9cc
issue1_en.pdf
               6629883    DFLT-N    5%    6318565  06-08-2007 02:45:06 69255866
*Totals   11  66478959              9%   60661789  05-13-2012 22:01:10
</code></pre>
<p dir="auto"><em>Content of listfile deletelist1.txt</em></p>
<pre><code>issue10_en.pdf
issue12_en.pdf
issue16_en.pdf
issue17_en.pdf
</code></pre>
<p dir="auto"><em>Remove the files from T1_NoPath.zip</em></p>
<pre><code>C:\Programs\PACL_Test&gt;pacomp -d T1_NoPath.zip @deletelist1.txt
  deleting: issue10_en.pdf
  deleting: issue12_en.pdf
  deleting: issue16_en.pdf
  deleting: issue17_en.pdf
All OK
</code></pre>
<p dir="auto"><em>List the contents of T1_NoPath.zip after removing the files</em></p>
issue11_en.pdf
issue13_en.pdf
issue14_en.pdf
issue15_en.pdf
issue18_en.pdf
issue19_en.pdf
issue1_en.pdf
*Totals    7  41110757              9%   37548067  05-13-2012 22:03:24
</code></pre>
Micke</p>
]]></description><link>https://forums.powerarchiver.com/post/28529</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/28529</guid><dc:creator><![CDATA[Micke]]></dc:creator><pubDate>Mon, 14 May 2012 18:15:42 GMT</pubDate></item><item><title><![CDATA[Reply to Remove many files from Archive with one command on Sun, 13 May 2012 03:02:25 GMT]]></title><description><![CDATA[<p dir="auto">ok, thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/28520</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/28520</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 13 May 2012 03:02:25 GMT</pubDate></item><item><title><![CDATA[Reply to Remove many files from Archive with one command on Sat, 12 May 2012 20:15:44 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the update. I’ll test the new version and get back with the result from that test.</p>
Micke</p>
]]></description><link>https://forums.powerarchiver.com/post/28518</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/28518</guid><dc:creator><![CDATA[Micke]]></dc:creator><pubDate>Sat, 12 May 2012 20:15:44 GMT</pubDate></item><item><title><![CDATA[Reply to Remove many files from Archive with one command on Fri, 11 May 2012 16:24:20 GMT]]></title><description><![CDATA[<p dir="auto">PACL 7.00:<br />
<a href="http://www.powerarchiver.com/test/alpha125/pacl700.exe" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.powerarchiver.com/test/alpha125/pacl700.exe</a></p>
<p dir="auto">check with this release please…. thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/28509</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/28509</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 11 May 2012 16:24:20 GMT</pubDate></item><item><title><![CDATA[Reply to Remove many files from Archive with one command on Thu, 29 Mar 2012 19:53:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a>:</p>
<p dir="auto">Try with PACL 6.02 and lets see what happens :)</p>
<p dir="auto">I’m just curious if you have plans to implement support for removing more than one file at a time from an archive using PACL? It’s not working in 6.02 and when testing in 7.00 RC1, the result is the same as in 6.01 and 6.02.</p>
Micke</p>
]]></description><link>https://forums.powerarchiver.com/post/28137</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/28137</guid><dc:creator><![CDATA[Micke]]></dc:creator><pubDate>Thu, 29 Mar 2012 19:53:09 GMT</pubDate></item><item><title><![CDATA[Reply to Remove many files from Archive with one command on Thu, 22 Mar 2012 15:33:15 GMT]]></title><description><![CDATA[<p dir="auto">Hello!<br />
I’ve tested removing files from an archive using a listfile, but it still doesn’t work.</p>
<p dir="auto">Tested with PACL 7.00 RC1.</p>
<p dir="auto">Is this something that will be fixed in 7.00?</p>
<p dir="auto">Right now it’s not possible to remove more than one file at a time from an archive using PACL. This is a big limitation of the program.</p>
Micke</p>
]]></description><link>https://forums.powerarchiver.com/post/28049</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/28049</guid><dc:creator><![CDATA[Micke]]></dc:creator><pubDate>Thu, 22 Mar 2012 15:33:15 GMT</pubDate></item><item><title><![CDATA[Reply to Remove many files from Archive with one command on Tue, 19 Oct 2010 13:51:26 GMT]]></title><description><![CDATA[<p dir="auto">I agree with you Micke</p>
]]></description><link>https://forums.powerarchiver.com/post/24020</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/24020</guid><dc:creator><![CDATA[barettpaula336]]></dc:creator><pubDate>Tue, 19 Oct 2010 13:51:26 GMT</pubDate></item><item><title><![CDATA[Reply to Remove many files from Archive with one command on Mon, 18 Oct 2010 21:15:11 GMT]]></title><description><![CDATA[<p dir="auto">Hi!<br />
I have tested removing more than one file from a Archive by using a listfile. Here’s the results from this test.</p>
<p dir="auto">Contents of Listfile.txt</p>
</code></pre>
<p dir="auto">Create a archive with full pathname and using a listfile to add the files to the archive</p>
<pre><code>D:\PACL_Test&gt;pacomp -a -P PACL_Test_P.zip @Listfile.txt
PowerArchiver Command Line (PACL)              Version 6.02       [Oct 10 2010]
Copyright(c) 1999-2010 ConeXware, Inc.  All Rights Reserved. Registered Version
This product is licensed to:
Archive: D:\PACL_Test\PACL_Test_P.zip
  adding: PA_Test\IMG_01.jpg   --&gt; Done. [3%]
  adding: PA_Test\IMG_02.jpg   --&gt; Done. [6%]
  adding: PA_Test\IMG_03.jpg   --&gt; Done. [13%]
  adding: PA_Test\IMG_04.jpg   --&gt; Done. [17%]
  adding: PA_Test\IMG_05.jpg   --&gt; Done. [21%]
  adding: PA_Test\IMG_06.jpg   --&gt; Done. [27%]
  adding: PA_Test\IMG_07.jpg   --&gt; Done. [31%]
  adding: PA_Test\IMG_08.jpg   --&gt; Done. [36%]
  adding: PA_Test\IMG_09.jpg   --&gt; Done. [40%]
  adding: PA_Test\IMG_10.jpg   --&gt; Done. [45%]
  adding: PA_Test\IMG_11.jpg   --&gt; Done. [49%]
  adding: PA_Test\IMG_12.jpg   --&gt; Done. [54%]
  adding: PA_Test\IMG_13.jpg   --&gt; Done. [57%]
  adding: PA_Test\IMG_14.jpg   --&gt; Done. [61%]
  adding: PA_Test\IMG_15.jpg   --&gt; Done. [65%]
  adding: PA_Test\IMG_16.jpg   --&gt; Done. [69%]
  adding: PA_Test\IMG_17.jpg   --&gt; Done. [73%]
  adding: PA_Test\IMG_18.jpg   --&gt; Done. [77%]
  adding: PA_Test\IMG_19.jpg   --&gt; Done. [82%]
  adding: PA_Test\IMG_20.jpg   --&gt; Done. [87%]
  adding: PA_Test\IMG_21.jpg   --&gt; Done. [92%]
  adding: PA_Test\IMG_22.jpg   --&gt; Done. [96%]
  adding: PA_Test\IMG_23.jpg   --&gt; Done. [100%]
All OK
D:\PACL_Test&gt;
</code></pre>
<p dir="auto">List the contents of the created archive</p>
<pre><code>D:\PACL_Test&gt;paext -v PACL_Test_P.zip
Archive --&gt; D:\PACL_Test\PACL_Test_P.zip [ZIP]
                161789    DFLT-N   29%     114454  08-03-2010 23:07:24 ef81e275
                138233    DFLT-N   32%      94385  08-03-2010 23:07:58 e3b93b26
                261775    DFLT-N   17%     217479  08-03-2010 23:09:48 7457e2e9
                183436    DFLT-N   24%     138970  08-03-2010 23:10:34 ec974b2f
                175546    DFLT-N   25%     131279  08-03-2010 23:10:54 58dd4120
                283265    DFLT-N   17%     236153  08-03-2010 23:11:28 d2d582d0
                158403    DFLT-N   30%     110876  08-03-2010 23:12:02 b394d1d1
                208013    DFLT-N   23%     160622  08-03-2010 23:12:24 3bc9cda3
                195931    DFLT-N   21%     154721  08-03-2010 23:13:36 59815b19
                204451    DFLT-N   24%     154399  08-03-2010 23:14:38 351c82b3
                187594    DFLT-N   23%     144056  08-03-2010 23:14:58 fe0d02ed
                190967    DFLT-N   24%     144839  08-03-2010 23:15:28 411436ba
                138797    DFLT-N   32%      94621  08-03-2010 23:16:10 a19a1f7c
                175613    DFLT-N   25%     131688  08-03-2010 23:16:42 9b14cd22
                171813    DFLT-N   26%     127673  08-03-2010 23:23:34 1fb450a6
                182176    DFLT-N   24%     137901  08-03-2010 23:23:54 8cedea77
                176589    DFLT-N   25%     132412  08-03-2010 23:24:24 705c51f7
                146091    DFLT-N   33%      98556  08-03-2010 23:17:32 47a1097f
                229730    DFLT-N   21%     182631  08-03-2010 23:18:00 7229c032
                217430    DFLT-N   20%     173301  08-03-2010 23:18:40 7f7c88e6
                189525    DFLT-N   23%     145747  08-03-2010 23:19:00 85db48ce
                179442    DFLT-N   23%     138371  08-03-2010 23:19:24 b7d7507f
                162456    DFLT-N   27%     118401  08-03-2010 23:20:00 f44fb9eb
*Totals   23   4319065             24%    3286133  10-18-2010 22:23:54
D:\PACL_Test&gt;
</code></pre>
<p dir="auto">Contents of the listfile I’ll be using for removing files from the created archive. I have assumed that the filenames in the listfile should have the full pathname as they have in the archive.</p>
</code></pre>
<p dir="auto">Run the command to remove these 9 files from the archive.</p>
<pre><code>D:\PACL_Test&gt;pacomp -d PACL_Test_P.zip @Listfile_Del_P.txt
  deleting: PA_Test\IMG_01.jpg
   *** WARNING: Nothing to add or update...
All OK
D:\PACL_Test&gt;
</code></pre>
<p dir="auto">I then list the contents of the archive again.</p>
This product is licensed to: Mikael Hedman
</code></pre>
<p dir="auto">As you can see, only PA_Test\IMG_01.jpg was removed from the archive.</p>
<p dir="auto">Let me know if I have missed something in these tests. I’m looking forward this functionality and will do more tests of it when you have updated PACL with it.</p>
Micke</p>
]]></description><link>https://forums.powerarchiver.com/post/24014</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/24014</guid><dc:creator><![CDATA[Micke]]></dc:creator><pubDate>Mon, 18 Oct 2010 21:15:11 GMT</pubDate></item><item><title><![CDATA[Reply to Remove many files from Archive with one command on Fri, 08 Oct 2010 11:48:11 GMT]]></title><description><![CDATA[<p dir="auto">Try with PACL 6.02 and lets see what happens :)</p>
]]></description><link>https://forums.powerarchiver.com/post/23938</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/23938</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 08 Oct 2010 11:48:11 GMT</pubDate></item></channel></rss>
