<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Feature Request: Delete files after extraction.]]></title><description><![CDATA[<p dir="auto">Hi</p>
<p dir="auto">I was wondering if it was possible to have a feature that would optionally delete the files added to an archive after the archiving process has been completed. Does not have to be secure delete (Recycling bin works too :D)</p>
<p dir="auto">Mame</p>
]]></description><link>https://forums.powerarchiver.com/topic/3955/feature-request-delete-files-after-extraction</link><generator>RSS for Node</generator><lastBuildDate>Sun, 08 Nov 2026 16:55:32 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3955.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 30 Mar 2010 01:55:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Feature Request: Delete files after extraction. on Tue, 30 Mar 2010 20:43:43 GMT]]></title><description><![CDATA[<p dir="auto">My apologies :(</p>
<p dir="auto">I am not sure how I missed the move to archive option.</p>
<p dir="auto">Please lock and/or delete this thread.</p>
]]></description><link>https://forums.powerarchiver.com/post/22952</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/22952</guid><dc:creator><![CDATA[Mameluke]]></dc:creator><pubDate>Tue, 30 Mar 2010 20:43:43 GMT</pubDate></item><item><title><![CDATA[Reply to Feature Request: Delete files after extraction. on Tue, 30 Mar 2010 19:02:31 GMT]]></title><description><![CDATA[<p dir="auto">The discussion referring to safety/security still applies and so does the optionality :p</p>
<p dir="auto">Problem then becomes how many options you have to select from just to add/extract a file.</p>
<p dir="auto">However, I was referring to the title of this thread “Delete files after extraction”<br />
deleting after adding would be to “move to archive” rather than “add to archive”.</p>
]]></description><link>https://forums.powerarchiver.com/post/22951</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/22951</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Tue, 30 Mar 2010 19:02:31 GMT</pubDate></item><item><title><![CDATA[Reply to Feature Request: Delete files after extraction. on Tue, 30 Mar 2010 18:15:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mameluke" aria-label="Profile: Mameluke">@<bdi>Mameluke</bdi></a>:</p>
<p dir="auto">Hi<br />
I was wondering if it was possible to have a feature that would optionally delete the files added to an archive after the archiving process has been completed.</p>
<p dir="auto">The thread TBGBe refers to is about deleting the archive after successful extraction. This is about delete the files adding to an archive after the archiving process has been completed.</p>
<p dir="auto">Personally I don’t want this feature in PA for the same reason I don’t want the option to delete archives after successful extraction. It will increase the risk of loosing data for the user.</p>
<p dir="auto">Deleting of files and archives should be done manually by the user and if something goes wrong, then PA can’t be blamed for loosing data.</p>
<p dir="auto">That’s my opinion</p>
<p dir="auto">Kind Regards<br />
Micke</p>
]]></description><link>https://forums.powerarchiver.com/post/22949</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/22949</guid><dc:creator><![CDATA[Micke]]></dc:creator><pubDate>Tue, 30 Mar 2010 18:15:28 GMT</pubDate></item><item><title><![CDATA[Reply to Feature Request: Delete files after extraction. on Tue, 30 Mar 2010 18:08:23 GMT]]></title><description><![CDATA[<p dir="auto">Did you miss the other thread on this?<br />
<a href="http://www.powerarchiver.com/forums/showthread.php?t=4422" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.powerarchiver.com/forums/showthread.php?t=4422</a></p>
]]></description><link>https://forums.powerarchiver.com/post/22948</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/22948</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Tue, 30 Mar 2010 18:08:23 GMT</pubDate></item></channel></rss>
