<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Definition of Add, Update, Freshen]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Could someone define exactly what -a, -u and -f do in PACL 6?</p>
<p dir="auto">This is in respect to the following?</p>
<p dir="auto">File not in archive<br />
File in archive but with timestamp same as on disk<br />
File in archive but with timestamp earlier than on disk<br />
File in archive but with timestamp later than on disk</p>
<p dir="auto">Here are my thoughts:</p>
<p dir="auto">-a Adds new files to archive (what happens to files already in the archive? Do they get updated? Only if they’re different? Only if they’re newer?)</p>
<p dir="auto">-u same as -a but doesn’t add new ones</p>
<p dir="auto">-f same as -u but only if they are newer</p>
<p dir="auto">Thanks,<br />
Badders</p>
]]></description><link>https://forums.powerarchiver.com/topic/3943/definition-of-add-update-freshen</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 08:31:57 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3943.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 18 Mar 2010 12:34:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Definition of Add, Update, Freshen on Mon, 22 Mar 2010 11:33:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a>:</p>
<p dir="auto">using archive flags is the best way to do any update.</p>
<p dir="auto">True - that’s certainly an option. Thanks.</p>
]]></description><link>https://forums.powerarchiver.com/post/22877</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/22877</guid><dc:creator><![CDATA[Badders]]></dc:creator><pubDate>Mon, 22 Mar 2010 11:33:26 GMT</pubDate></item><item><title><![CDATA[Reply to Definition of Add, Update, Freshen on Fri, 19 Mar 2010 18:00:08 GMT]]></title><description><![CDATA[<p dir="auto">using archive flags is the best way to do any update.</p>
]]></description><link>https://forums.powerarchiver.com/post/22857</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/22857</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 19 Mar 2010 18:00:08 GMT</pubDate></item><item><title><![CDATA[Reply to Definition of Add, Update, Freshen on Fri, 19 Mar 2010 13:01:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/badders" aria-label="Profile: Badders">@<bdi>Badders</bdi></a>:</p>
<p dir="auto">… I don’t want it to spend time needlessly re-archiving all the other databases which haven’t changed. The database files are between 5GB and 25GB but compact down to a couple of GB.</p>
<p dir="auto">Why not use the “archive flags” control ( -aa ) - in combination with “clear flag” (-ca)?<br />
Then if a file hasn’t changed the flag will not be set and PACL won’t re-compress it.</p>
]]></description><link>https://forums.powerarchiver.com/post/22856</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/22856</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Fri, 19 Mar 2010 13:01:16 GMT</pubDate></item><item><title><![CDATA[Reply to Definition of Add, Update, Freshen on Thu, 18 Mar 2010 18:31:19 GMT]]></title><description><![CDATA[<p dir="auto">It’s not quite the same as an add. I want it to add new files - yes, but not re-archive files which haven’t changed.</p>
<p dir="auto">I realise it won’t remove any files from the archive.</p>
<p dir="auto">The background is that I have many large database files in the archive which don’t change very often. Occasionally a new database comes along which needs to be added to the archive. I don’t want it to spend time needlessly re-archiving all the other databases which haven’t changed. The database files are between 5GB and 25GB but compact down to a couple of GB.</p>
<p dir="auto">I don’t mind running PACOMP twice. Once with -h and once with -an (new option for (a)dd (n)ew only).</p>
]]></description><link>https://forums.powerarchiver.com/post/22846</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/22846</guid><dc:creator><![CDATA[Badders]]></dc:creator><pubDate>Thu, 18 Mar 2010 18:31:19 GMT</pubDate></item><item><title><![CDATA[Reply to Definition of Add, Update, Freshen on Thu, 18 Mar 2010 17:16:55 GMT]]></title><description><![CDATA[<p dir="auto">That is the same result as add - it won’t remove existing files if that is what you’re concerned about.</p>
]]></description><link>https://forums.powerarchiver.com/post/22845</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/22845</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Thu, 18 Mar 2010 17:16:55 GMT</pubDate></item><item><title><![CDATA[Reply to Definition of Add, Update, Freshen on Thu, 18 Mar 2010 16:16:16 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">-f : folders : don’t add empty folders</p>
<p dir="auto">:eek: (makes mental note - don’t use command parameters of competitors products :D )</p>
<p dir="auto">So, I guess my real question is:</p>
<p dir="auto">Is it possible to freshen the existing files in the archive and add any new files?</p>
]]></description><link>https://forums.powerarchiver.com/post/22844</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/22844</guid><dc:creator><![CDATA[Badders]]></dc:creator><pubDate>Thu, 18 Mar 2010 16:16:16 GMT</pubDate></item><item><title><![CDATA[Reply to Definition of Add, Update, Freshen on Thu, 18 Mar 2010 13:27:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/badders" aria-label="Profile: Badders">@<bdi>Badders</bdi></a>:</p>
<p dir="auto">I (almost) agree…<br />
-a : add : Adds new and replaces any existing (no checks)</p>
<p dir="auto">-u : update : re-adds only existing files (no checks)</p>
<p dir="auto">-h : freshen : only adds existing which have been modified or later date than in archive.</p>
<p dir="auto">-f : folders : don’t add empty folders :p</p>
]]></description><link>https://forums.powerarchiver.com/post/22843</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/22843</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Thu, 18 Mar 2010 13:27:27 GMT</pubDate></item></channel></rss>
