<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error while writing to selected drive&#x2F;media]]></title><description><![CDATA[<p dir="auto">just purchased PA2010 and am trying to burn an ISO image to a DVD using the image burner. PA2010 is installed on my laptop which has a removable DVD drive and I also have an external DVD burner (Plextor PX-755UF) attached.<br />
PA seems to have problems detecting the drives internal or external in so far that PA does not list a drive as available if there is a blank CD/DVD inserted. The drive must be empty to be recognised.<br />
If I start the Image Burner with empty drives I can selected a drive, select the image I want to burn, insert a blank CD/DVD and click the burn button. I immediately receive an error message: “There was an error while writing to selected drive/media. On the screen I can see the progress information box where the last entry is " Testing unit ready”<br />
This happens regardless which drive I use. Any idea what I am doing wrong?</p>
]]></description><link>https://forums.powerarchiver.com/topic/3896/error-while-writing-to-selected-drive-media</link><generator>RSS for Node</generator><lastBuildDate>Mon, 14 Sep 2026 03:24:48 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3896.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 20 Jan 2010 14:24:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Error while writing to selected drive&#x2F;media on Wed, 20 Jan 2010 16:20:44 GMT]]></title><description><![CDATA[<p dir="auto">Ok, so in Config&gt; Misc, try manually selecting those other 2 methods… and if none work, please email us at support @ conexware dot com, and we will send you special logging burner application which will record errors so we can see whats going on there.</p>
<p dir="auto">thanks a lot!</p>
]]></description><link>https://forums.powerarchiver.com/post/22498</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/22498</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 20 Jan 2010 16:20:44 GMT</pubDate></item><item><title><![CDATA[Reply to Error while writing to selected drive&#x2F;media on Wed, 20 Jan 2010 16:04:31 GMT]]></title><description><![CDATA[<p dir="auto">Did as you requested. Even re-booted my laptop afterwards, …. no change.</p>
]]></description><link>https://forums.powerarchiver.com/post/22497</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/22497</guid><dc:creator><![CDATA[amiinbayern]]></dc:creator><pubDate>Wed, 20 Jan 2010 16:04:31 GMT</pubDate></item><item><title><![CDATA[Reply to Error while writing to selected drive&#x2F;media on Wed, 20 Jan 2010 14:45:37 GMT]]></title><description><![CDATA[<p dir="auto">try download Virtual Drive drivers via Burner&gt; Virtual Drive, and then let us know how it works.</p>
<p dir="auto">It adds additional method of controlling the drive - SPTD, which is selectable in Config&gt; Misc. screen, after installation.</p>
]]></description><link>https://forums.powerarchiver.com/post/22496</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/22496</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 20 Jan 2010 14:45:37 GMT</pubDate></item></channel></rss>
