<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Compress to ISO problem]]></title><description><![CDATA[<p dir="auto">I’m using the latest version 11,60.23</p>
<p dir="auto">I have the Compress to ISO context menu turned on when ever I select a bunch of files &amp; hit compress to ISO</p>
<p dir="auto">It brings up the CD Burning Window</p>
<p dir="auto">I don’t wanna burn it I just wanna compress it It used to work But now it doesn’t maybe a bug?</p>
<p dir="auto">Also I forgot to mention I’m using Windows 7</p>
]]></description><link>https://forums.powerarchiver.com/topic/3765/compress-to-iso-problem</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 04:10:48 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3765.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 18 Oct 2009 01:52:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Compress to ISO problem on Mon, 19 Oct 2009 14:52:19 GMT]]></title><description><![CDATA[<p dir="auto">@PowerAngel:</p>
<p dir="auto">Interesting</p>
<p dir="auto">I tried with other folders &amp; the iso window shows up like normal but the specific folder I was trying to compress to Iso it would bring up the burning window when attempting to compress</p>
<p dir="auto">Ok What I was trying to compress was My Copy of Windows XP Professional</p>
<p dir="auto">I drug all the folders &amp; files off the CD onto the desktop was going to compress in &amp; keep it for back up purposes</p>
<p dir="auto">but Power PA wouldn’t do it</p>
<p dir="auto">so I started removing folders &amp; files piece by piece to see what was cousing the burn wizard to come up &amp; not the ISO Compression wizard</p>
<p dir="auto">in that Windows XP Professional folder I was attempting to compress is a folder named I386</p>
<p dir="auto">Once I removed that folder the iso window poped up like its supposed to</p>
<p dir="auto">When I try to compress the 1386 folder it would bring up the Burn wizard for some odd reason</p>
<p dir="auto">Dunno why</p>
<p dir="auto">But it might make sense to others</p>
<p dir="auto">thanks on info on how to reproduce it…</p>
]]></description><link>https://forums.powerarchiver.com/post/21733</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21733</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 19 Oct 2009 14:52:19 GMT</pubDate></item><item><title><![CDATA[Reply to Compress to ISO problem on Mon, 19 Oct 2009 10:49:02 GMT]]></title><description><![CDATA[<p dir="auto">works OK here too<br />
If possible, please send a screenshot</p>
]]></description><link>https://forums.powerarchiver.com/post/21732</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21732</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Mon, 19 Oct 2009 10:49:02 GMT</pubDate></item><item><title><![CDATA[Reply to Compress to ISO problem on Mon, 19 Oct 2009 03:27:17 GMT]]></title><description><![CDATA[<p dir="auto">I wish I could change my “Power Angel” name I musta been stoned when I made that …</p>
]]></description><link>https://forums.powerarchiver.com/post/21730</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21730</guid><dc:creator><![CDATA[MrAngelus]]></dc:creator><pubDate>Mon, 19 Oct 2009 03:27:17 GMT</pubDate></item><item><title><![CDATA[Reply to Compress to ISO problem on Mon, 19 Oct 2009 02:49:55 GMT]]></title><description><![CDATA[<p dir="auto">the option works fine for me in Windows 7 but I haven’t tested it on XP files as ‘PowerAngel’ did.</p>
]]></description><link>https://forums.powerarchiver.com/post/21729</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21729</guid><dc:creator><![CDATA[moles42]]></dc:creator><pubDate>Mon, 19 Oct 2009 02:49:55 GMT</pubDate></item><item><title><![CDATA[Reply to Compress to ISO problem on Mon, 19 Oct 2009 01:58:23 GMT]]></title><description><![CDATA[<p dir="auto">Interesting</p>
]]></description><link>https://forums.powerarchiver.com/post/21728</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21728</guid><dc:creator><![CDATA[MrAngelus]]></dc:creator><pubDate>Mon, 19 Oct 2009 01:58:23 GMT</pubDate></item><item><title><![CDATA[Reply to Compress to ISO problem on Mon, 19 Oct 2009 01:52:24 GMT]]></title><description><![CDATA[<p dir="auto">i am not sure what am I doing wrong, but i cant reproduce this - so any help would be very apperciated!</p>
]]></description><link>https://forums.powerarchiver.com/post/21727</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21727</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 19 Oct 2009 01:52:24 GMT</pubDate></item><item><title><![CDATA[Reply to Compress to ISO problem on Sun, 18 Oct 2009 23:18:47 GMT]]></title><description><![CDATA[<p dir="auto">so create iso window shows properly, but it does not add folders, just files?</p>
<p dir="auto">thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/21726</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21726</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 18 Oct 2009 23:18:47 GMT</pubDate></item><item><title><![CDATA[Reply to Compress to ISO problem on Sun, 18 Oct 2009 23:16:14 GMT]]></title><description><![CDATA[<p dir="auto">If I select one folder to bring up the ISO Burning window<br />
then you use the add folder &amp; add file button it seems to work</p>
<p dir="auto">If I just select a folder &amp; with the context menu click compress to ISO it seems to bring up the burning window atleast for me</p>
]]></description><link>https://forums.powerarchiver.com/post/21725</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21725</guid><dc:creator><![CDATA[MrAngelus]]></dc:creator><pubDate>Sun, 18 Oct 2009 23:16:14 GMT</pubDate></item><item><title><![CDATA[Reply to Compress to ISO problem on Sun, 18 Oct 2009 22:36:30 GMT]]></title><description><![CDATA[<p dir="auto">Yes one file beings up the Iso Window</p>
<p dir="auto">But when that window is open if I select a bunch of folders<br />
it ignores the folders &amp; just does whats not in folders</p>
]]></description><link>https://forums.powerarchiver.com/post/21724</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21724</guid><dc:creator><![CDATA[MrAngelus]]></dc:creator><pubDate>Sun, 18 Oct 2009 22:36:30 GMT</pubDate></item><item><title><![CDATA[Reply to Compress to ISO problem on Sun, 18 Oct 2009 15:10:31 GMT]]></title><description><![CDATA[<p dir="auto">(btw build iso window looks similar to burning window)</p>
]]></description><link>https://forums.powerarchiver.com/post/21722</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21722</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 18 Oct 2009 15:10:31 GMT</pubDate></item><item><title><![CDATA[Reply to Compress to ISO problem on Sun, 18 Oct 2009 14:49:42 GMT]]></title><description><![CDATA[<p dir="auto">try selecting one file and then compress to iso - does it work?</p>
<p dir="auto">i have tried on my win7, seems to be working fine.</p>
]]></description><link>https://forums.powerarchiver.com/post/21721</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21721</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 18 Oct 2009 14:49:42 GMT</pubDate></item></channel></rss>
