<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Win7] Different extract behavior context menu vs. open]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">System specs:</p>
<ul>
<li>Windows 7 Professional RTM x64 (MSDNAA version, German)</li>
<li>Intel Core 2 Duo E6750 (2x 2.66GHz)</li>
<li>4GB RAM</li>
<li>PA 2010 PRO, Version 11.60.10 (08/2009) English w/ International reg. code.</li>
</ul>
<p dir="auto">I’m currently dealing with several splitted and password protected 7zip archives (filename.7z.001 - filename.7z.00X).</p>
<p dir="auto">filename.7z.001 is recognized as a “general” archive regarding the shown icon.</p>
<p dir="auto"><img src="http://imghost.glorp.de/i/88f840076f99.png" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">If I perform a right-click on it and choose “Extract here” PA quits with an “invalid archive” error:</p>
<p dir="auto"><a href="http://imghost.glorp.de/i/9a1df58575d3.png" target="_blank" rel="noopener noreferrer nofollow ugc"><img src="http://imghost.glorp.de/i/t/9a1df58575d3.png" alt="" class=" img-fluid img-markdown" /></a>(click to enlarge)</p>
<p dir="auto">But if I perform a double click, PA opens the archive and recognizes it as a valid password protected 7zip archive and I can extract it.</p>
]]></description><link>https://forums.powerarchiver.com/topic/3734/win7-different-extract-behavior-context-menu-vs-open</link><generator>RSS for Node</generator><lastBuildDate>Mon, 12 Oct 2026 14:52:25 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3734.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 29 Aug 2009 18:34:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Win7] Different extract behavior context menu vs. open on Fri, 11 Sep 2009 16:38:28 GMT]]></title><description><![CDATA[<p dir="auto">Bug fixed with latest v11.60.15 release, thanks :)</p>
]]></description><link>https://forums.powerarchiver.com/post/21455</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21455</guid><dc:creator><![CDATA[H4ndy]]></dc:creator><pubDate>Fri, 11 Sep 2009 16:38:28 GMT</pubDate></item><item><title><![CDATA[Reply to [Win7] Different extract behavior context menu vs. open on Thu, 03 Sep 2009 14:30:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: Mili">@<bdi>Mili</bdi></a>:</p>
<p dir="auto">Reproduced, thanks for the details H4ndy!</p>
<p dir="auto">No problem :)</p>
]]></description><link>https://forums.powerarchiver.com/post/21360</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21360</guid><dc:creator><![CDATA[H4ndy]]></dc:creator><pubDate>Thu, 03 Sep 2009 14:30:37 GMT</pubDate></item><item><title><![CDATA[Reply to [Win7] Different extract behavior context menu vs. open on Thu, 03 Sep 2009 14:26:28 GMT]]></title><description><![CDATA[<p dir="auto">Reproduced, thanks for the details H4ndy!</p>
]]></description><link>https://forums.powerarchiver.com/post/21359</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21359</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Thu, 03 Sep 2009 14:26:28 GMT</pubDate></item><item><title><![CDATA[Reply to [Win7] Different extract behavior context menu vs. open on Thu, 03 Sep 2009 14:00:21 GMT]]></title><description><![CDATA[<p dir="auto">i think it could be that it wasnt fixed in 64bit shell, we are looking into it.</p>
]]></description><link>https://forums.powerarchiver.com/post/21358</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21358</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Thu, 03 Sep 2009 14:00:21 GMT</pubDate></item><item><title><![CDATA[Reply to [Win7] Different extract behavior context menu vs. open on Thu, 03 Sep 2009 13:58:51 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">They were created using the “original” 7zip application (v4.65 I guess, Windows XP):</p>
<p dir="auto"><a href="http://imghost.glorp.de/i/489defc44f71.png" target="_blank" rel="noopener noreferrer nofollow ugc"><img src="http://imghost.glorp.de/i/t/489defc44f71.png" alt="" class=" img-fluid img-markdown" /></a><br />
(click to enlarge, Sorry only in German)</p>
<p dir="auto">I think the most important settings:<br />
Ultra/LZMA, Splitted, Password encrypted incl. encr. filenames using AES.</p>
]]></description><link>https://forums.powerarchiver.com/post/21357</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21357</guid><dc:creator><![CDATA[H4ndy]]></dc:creator><pubDate>Thu, 03 Sep 2009 13:58:51 GMT</pubDate></item><item><title><![CDATA[Reply to [Win7] Different extract behavior context menu vs. open on Thu, 03 Sep 2009 13:36:23 GMT]]></title><description><![CDATA[<p dir="auto">Thank you.</p>
<p dir="auto">And which settings did you use to create the 7z file?</p>
]]></description><link>https://forums.powerarchiver.com/post/21355</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21355</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Thu, 03 Sep 2009 13:36:23 GMT</pubDate></item><item><title><![CDATA[Reply to [Win7] Different extract behavior context menu vs. open on Wed, 02 Sep 2009 21:37:38 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I’ve rebooted several times and I even tried to reinstall PA.</p>
<p dir="auto">Here’s the file info:<br />
C:\Program Files (x86)\PowerArchiver\PASHLEXT.DLL<br />
Created: Sunday, August 23th 2009, 12:25:00<br />
Modified: Sunday, August 23th 2009, 12:25:00</p>
]]></description><link>https://forums.powerarchiver.com/post/21354</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21354</guid><dc:creator><![CDATA[H4ndy]]></dc:creator><pubDate>Wed, 02 Sep 2009 21:37:38 GMT</pubDate></item><item><title><![CDATA[Reply to [Win7] Different extract behavior context menu vs. open on Wed, 02 Sep 2009 15:26:18 GMT]]></title><description><![CDATA[<p dir="auto">Hey H4andy!</p>
<p dir="auto">Did you restart your computer after installing that version of PA? If not, please do so and give it a try.</p>
<p dir="auto">Also, please let us know the creation/modification date that you have for PASHLEXT.DLL<br />
Found in C:\Program Files\PowerArchiver</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forums.powerarchiver.com/post/21353</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21353</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Wed, 02 Sep 2009 15:26:18 GMT</pubDate></item></channel></rss>
