<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mount as &#x27;Virtual Drive&#x27;]]></title><description><![CDATA[<p dir="auto">I find the new ‘shell’ extension very handy indeed…<br />
how big a task would it be however to give us a similar option to ‘unmount’ them?</p>
<p dir="auto">just curious.</p>
]]></description><link>https://forums.powerarchiver.com/topic/3708/mount-as-virtual-drive</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Jul 2026 09:54:36 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3708.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 22 Aug 2009 03:22:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mount as &#x27;Virtual Drive&#x27; on Mon, 24 Aug 2009 22:13:32 GMT]]></title><description><![CDATA[<p dir="auto">i know, but as starter already has that option, doesnt make sense in creating two system tray apps.</p>
]]></description><link>https://forums.powerarchiver.com/post/21240</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21240</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 24 Aug 2009 22:13:32 GMT</pubDate></item><item><title><![CDATA[Reply to Mount as &#x27;Virtual Drive&#x27; on Mon, 24 Aug 2009 03:22:43 GMT]]></title><description><![CDATA[<p dir="auto">yes understood.<br />
I’m not a user of the ‘starter’ option though…most of my work is done via ‘shell’…just thought it may have been an option for the future.</p>
]]></description><link>https://forums.powerarchiver.com/post/21236</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21236</guid><dc:creator><![CDATA[moles42]]></dc:creator><pubDate>Mon, 24 Aug 2009 03:22:43 GMT</pubDate></item><item><title><![CDATA[Reply to Mount as &#x27;Virtual Drive&#x27; on Sat, 22 Aug 2009 03:38:10 GMT]]></title><description><![CDATA[<p dir="auto">you can do that with Starter, why another icon?</p>
]]></description><link>https://forums.powerarchiver.com/post/21226</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21226</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sat, 22 Aug 2009 03:38:10 GMT</pubDate></item><item><title><![CDATA[Reply to Mount as &#x27;Virtual Drive&#x27; on Sat, 22 Aug 2009 03:31:03 GMT]]></title><description><![CDATA[<p dir="auto">I was thinking of some way whereby a ‘mounted’ image would be indicated by a disc icon in ‘systray’ and ‘right’ clicking on it or hovering over it would display the mounted images giving you the opportunity to unmount.</p>
<p dir="auto">it’s just a thought…:)</p>
]]></description><link>https://forums.powerarchiver.com/post/21225</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21225</guid><dc:creator><![CDATA[moles42]]></dc:creator><pubDate>Sat, 22 Aug 2009 03:31:03 GMT</pubDate></item><item><title><![CDATA[Reply to Mount as &#x27;Virtual Drive&#x27; on Sat, 22 Aug 2009 03:27:45 GMT]]></title><description><![CDATA[<p dir="auto">PA Starter has unmount option, and one of the next versions will get Mount/Unmount for Win7 jumplists too.</p>
<p dir="auto">Not sure about unmount in shell though, presumably it would have to detect if anything is mounted first and i dont know if that might take some time or not (if it does then it couldnt be used)</p>
]]></description><link>https://forums.powerarchiver.com/post/21224</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21224</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sat, 22 Aug 2009 03:27:45 GMT</pubDate></item></channel></rss>
