<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Directory properties inheritance]]></title><description><![CDATA[<p dir="auto">Whenever I drag a file from an archive in a PA window, and drop it into a compressed directory, the extracted file is never compressed. I always have to manually compress the extracted file(s) afterward.</p>
<p dir="auto">When I do the same using WinRAR, the file is compressed properly. This is as expected since the file(s) should inherit the compressed flag from the directory.</p>
]]></description><link>https://forums.powerarchiver.com/topic/3705/directory-properties-inheritance</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Nov 2026 15:25:46 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3705.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 08 Sep 2009 19:50:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Directory properties inheritance on Wed, 30 Sep 2009 18:40:55 GMT]]></title><description><![CDATA[<p dir="auto">i should have said we reproduced it long time ago :-). Sorry for the trouble.</p>
]]></description><link>https://forums.powerarchiver.com/post/21575</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21575</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 30 Sep 2009 18:40:55 GMT</pubDate></item><item><title><![CDATA[Reply to Directory properties inheritance on Wed, 30 Sep 2009 17:02:33 GMT]]></title><description><![CDATA[<p dir="auto">Here’s a video (in a 7-Zip archive) that shows it very clearly. Note that I had to give the attached file (which, again, is actually a 7-Zip archive) the XLS extension in order to post it, because of the forum attachment size limit configuration. Obviously, change the extension to 7Z to make it work.</p>
<p dir="auto">The default video size may not be ideal. On my system, I have to maximize the video window to see it clearly.</p>
<p dir="auto">This was extremely easy to reproduce it. While I used PA, I encountered this every day.<br />
<a href="/uploads/_imported_attachments/attachment_p_20349_0_demovid.7z.xls">attachment_p_20349_0_demovid.7z.xls</a></p>
]]></description><link>https://forums.powerarchiver.com/post/21574</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21574</guid><dc:creator><![CDATA[nameless]]></dc:creator><pubDate>Wed, 30 Sep 2009 17:02:33 GMT</pubDate></item><item><title><![CDATA[Reply to Directory properties inheritance on Wed, 30 Sep 2009 16:42:51 GMT]]></title><description><![CDATA[<p dir="auto">I’m talking about extracting files from PA to directories that have NTFS compression enabled. When I do this with PA, the files do <em>not</em> become (NTFS) compressed automatically, as they should. When I drag from WinRAR–same file, from the same archive, to the same directory–the files are compressed as they should be.</p>
<p dir="auto">I’ll see if I can create a video of this…</p>
]]></description><link>https://forums.powerarchiver.com/post/21573</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21573</guid><dc:creator><![CDATA[nameless]]></dc:creator><pubDate>Wed, 30 Sep 2009 16:42:51 GMT</pubDate></item><item><title><![CDATA[Reply to Directory properties inheritance on Wed, 30 Sep 2009 15:01:30 GMT]]></title><description><![CDATA[<p dir="auto">what exactly do you mean by a compressed folder?</p>
<p dir="auto">in Windows explorer or within an archive in PA?</p>
]]></description><link>https://forums.powerarchiver.com/post/21572</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21572</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Wed, 30 Sep 2009 15:01:30 GMT</pubDate></item><item><title><![CDATA[Reply to Directory properties inheritance on Wed, 30 Sep 2009 12:59:27 GMT]]></title><description><![CDATA[<p dir="auto">Isn’t this a semi-serious problem? I often extract to compressed folders, and I’m constantly having to manually compress the files after I’ve extracted them.</p>
]]></description><link>https://forums.powerarchiver.com/post/21571</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21571</guid><dc:creator><![CDATA[nameless]]></dc:creator><pubDate>Wed, 30 Sep 2009 12:59:27 GMT</pubDate></item></channel></rss>
