<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Compress to iso option does not work]]></title><description><![CDATA[<p dir="auto">what ‘type’ of files constitute a ‘Compress to ISO’ option?<br />
I added the option to the ‘shell extensions’ but after testing I’ve still yet to see it show in the actual ‘shell’…I guess I’m doing something wrong.</p>
<p dir="auto">strange…it’s now showing but it would only do so after I added several others to the ‘shell’…<br />
must be a vista thing again…if I added it on it’s own it refused to display.</p>
<p dir="auto">apologies for ‘hijacking’…I thought it had some relevance.</p>
]]></description><link>https://forums.powerarchiver.com/topic/3687/compress-to-iso-option-does-not-work</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Jul 2026 09:01:00 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3687.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 31 Jul 2009 00:20:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Compress to iso option does not work on Mon, 24 Aug 2009 02:58:30 GMT]]></title><description><![CDATA[<p dir="auto">seems to be working fine in this release thank you.</p>
]]></description><link>https://forums.powerarchiver.com/post/21233</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21233</guid><dc:creator><![CDATA[moles42]]></dc:creator><pubDate>Mon, 24 Aug 2009 02:58:30 GMT</pubDate></item><item><title><![CDATA[Reply to Compress to iso option does not work on Fri, 21 Aug 2009 22:27:58 GMT]]></title><description><![CDATA[<p dir="auto">p.s. if anyone has trouble with explorer view, please reset settings to default and it should be corrected… thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/21209</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21209</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 21 Aug 2009 22:27:58 GMT</pubDate></item><item><title><![CDATA[Reply to Compress to iso option does not work on Fri, 21 Aug 2009 22:05:05 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">please check following release:<br />
<a href="http://dl.powerarchiver.com/2010/powarc1160rc1.exe" target="_blank" rel="noopener noreferrer nofollow ugc">http://dl.powerarchiver.com/2010/powarc1160rc1.exe</a></p>
<p dir="auto">and let us know how it works now.</p>
<p dir="auto">thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/21205</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21205</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 21 Aug 2009 22:05:05 GMT</pubDate></item><item><title><![CDATA[Reply to Compress to iso option does not work on Sat, 08 Aug 2009 11:22:00 GMT]]></title><description><![CDATA[<p dir="auto">it should be fixed in next update.</p>
]]></description><link>https://forums.powerarchiver.com/post/21071</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21071</guid><dc:creator><![CDATA[ivan]]></dc:creator><pubDate>Sat, 08 Aug 2009 11:22:00 GMT</pubDate></item><item><title><![CDATA[Reply to Compress to iso option does not work on Fri, 31 Jul 2009 03:13:43 GMT]]></title><description><![CDATA[<p dir="auto">tested it again and I can’t get the option to show in the ‘shell’</p>
]]></description><link>https://forums.powerarchiver.com/post/21024</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21024</guid><dc:creator><![CDATA[moles42]]></dc:creator><pubDate>Fri, 31 Jul 2009 03:13:43 GMT</pubDate></item><item><title><![CDATA[Reply to Compress to iso option does not work on Fri, 31 Jul 2009 00:40:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/moles42" aria-label="Profile: moles42">@<bdi>moles42</bdi></a>:</p>
<p dir="auto">seems like an bug</p>
]]></description><link>https://forums.powerarchiver.com/post/21023</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21023</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 31 Jul 2009 00:40:28 GMT</pubDate></item></channel></rss>
