<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Duplicate &quot;Compression Profile&quot; names allowed]]></title><description><![CDATA[<p dir="auto">I found out (accidentally, I assure you) that PA allows more than one compression profile of a given name. Needless to say this can be confusing when you go to use one of them.</p>
<p dir="auto">I was in there and copied/pasted one profile name, intending to change the name “ZIP (Save full paths)” to “ZIP (Save no paths)”. (Yeah, I’m lazy. That’s why I want a <a href="http://www.powerarchiver.com/forums/showthread.php?t=3982" target="_blank" rel="noopener noreferrer nofollow ugc">“Configuration” toolbar button"</a>!) But I forgot to change the name, then later went to use the profile…</p>
<p dir="auto">Now, I’m not saying this is <a href="http://www.powerarchiver.com/forums/showthread.php?p=19419#post19419" target="_blank" rel="noopener noreferrer nofollow ugc">bug “2 of 2”</a>, but… Well let’s just say I’m hoping! :)</p>
]]></description><link>https://forums.powerarchiver.com/topic/3658/duplicate-compression-profile-names-allowed</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 06:57:50 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3658.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 Jul 2009 03:28:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Duplicate &quot;Compression Profile&quot; names allowed on Fri, 17 Jul 2009 23:53:13 GMT]]></title><description><![CDATA[<p dir="auto">seems to be some confusion here over MY post maybe?..methinks nameless has seen it as an attack on his original post when in actual fact I was just stipulating the fact that I use the context menu…I saw no mention of that in his original post which is why I aimed my wish at the context menu having the additional options.</p>
<p dir="auto">do I now have to make sure my posts are politically correct people ?..or am I now labeled as ‘opinionated’ ?<br />
it seems I will have to construct my replies more diligently so as not to offend anyone in future…sheesh!<br />
and here was me thinking all I was doing was testing a piece of software.</p>
<p dir="auto">apologies ‘nameless’ if you thought I was making light of your post…it wasn’t my intention.<br />
I was just airing my views and wishes on the topic in question.</p>
]]></description><link>https://forums.powerarchiver.com/post/20926</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20926</guid><dc:creator><![CDATA[moles42]]></dc:creator><pubDate>Fri, 17 Jul 2009 23:53:13 GMT</pubDate></item><item><title><![CDATA[Reply to Duplicate &quot;Compression Profile&quot; names allowed on Fri, 17 Jul 2009 21:26:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nameless" aria-label="Profile: nameless">@<bdi>nameless</bdi></a>:</p>
<p dir="auto">It didn’t make sense though; I access compression profiles via the context menu.</p>
<p dir="auto">most people use default explorer shell options, and dont go into the options screen :). Thats probably what he meant… but thats why we are here and we take in mind that we have wide range of users that are using PA in different ways :P</p>
]]></description><link>https://forums.powerarchiver.com/post/20921</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20921</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 17 Jul 2009 21:26:22 GMT</pubDate></item><item><title><![CDATA[Reply to Duplicate &quot;Compression Profile&quot; names allowed on Fri, 17 Jul 2009 18:22:17 GMT]]></title><description><![CDATA[<p dir="auto">It didn’t make sense though; I access compression profiles via the context menu.</p>
]]></description><link>https://forums.powerarchiver.com/post/20918</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20918</guid><dc:creator><![CDATA[nameless]]></dc:creator><pubDate>Fri, 17 Jul 2009 18:22:17 GMT</pubDate></item><item><title><![CDATA[Reply to Duplicate &quot;Compression Profile&quot; names allowed on Fri, 17 Jul 2009 18:07:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nameless" aria-label="Profile: nameless">@<bdi>nameless</bdi></a>:</p>
<p dir="auto">I use these compression profiles from the context menu as well. I’m not sure why every post I make becomes an indictment of me as a computer user.</p>
<p dir="auto">dont take it personally, people have opinions, thats just all :).</p>
]]></description><link>https://forums.powerarchiver.com/post/20916</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20916</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 17 Jul 2009 18:07:41 GMT</pubDate></item><item><title><![CDATA[Reply to Duplicate &quot;Compression Profile&quot; names allowed on Fri, 17 Jul 2009 16:12:10 GMT]]></title><description><![CDATA[<p dir="auto">I use these compression profiles from the context menu as well. I’m not sure why every post I make becomes an indictment of me as a computer user.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a>:</p>
<p dir="auto">i consider this an feature, not a bug… PA lets you name your profiles as you wish, no restrictions .</p>
<p dir="auto">There are real bugs you know, I have list, its big!</p>
<p dir="auto">Sorry, I thought this <em>was</em> a bug. Because you’re actually wrong; you can’t name profiles as you wish. I <em>wanted</em> to rename the default profiles, but could not. (Actually I wanted to delete them, but after finding I couldn’t, I tried renaming them.) In any case, it’s a real stretch trying to call the ability to have duplicate names a “feature”.</p>
]]></description><link>https://forums.powerarchiver.com/post/20914</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20914</guid><dc:creator><![CDATA[nameless]]></dc:creator><pubDate>Fri, 17 Jul 2009 16:12:10 GMT</pubDate></item><item><title><![CDATA[Reply to Duplicate &quot;Compression Profile&quot; names allowed on Fri, 17 Jul 2009 12:39:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/moles42" aria-label="Profile: moles42">@<bdi>moles42</bdi></a>:</p>
<p dir="auto">granted it probably is very useful to you but all my compression is always done via the context menu…it’s very rare I actually open PA in all it’s glory unless of course I’m examining archives.</p>
<p dir="auto">I wonder if there is any way a 'NEW" Profile can be added to the context menu<br />
or would that be something to perhaps wish for in a future release?</p>
<p dir="auto">too complicated, you can set defaults via default profile though….</p>
]]></description><link>https://forums.powerarchiver.com/post/20913</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20913</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 17 Jul 2009 12:39:59 GMT</pubDate></item><item><title><![CDATA[Reply to Duplicate &quot;Compression Profile&quot; names allowed on Fri, 17 Jul 2009 12:39:18 GMT]]></title><description><![CDATA[<p dir="auto">i consider this an feature, not a bug… PA lets you name your profiles as you wish, no restrictions :).</p>
<p dir="auto">There are real bugs you know, I have list, its big! :)</p>
]]></description><link>https://forums.powerarchiver.com/post/20912</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20912</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 17 Jul 2009 12:39:18 GMT</pubDate></item><item><title><![CDATA[Reply to Duplicate &quot;Compression Profile&quot; names allowed on Fri, 17 Jul 2009 09:51:56 GMT]]></title><description><![CDATA[<p dir="auto">granted it probably is very useful to you but all my compression is always done via the context menu…it’s very rare I actually open PA in all it’s glory unless of course I’m examining archives.</p>
]]></description><link>https://forums.powerarchiver.com/post/20911</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20911</guid><dc:creator><![CDATA[moles42]]></dc:creator><pubDate>Fri, 17 Jul 2009 09:51:56 GMT</pubDate></item><item><title><![CDATA[Reply to Duplicate &quot;Compression Profile&quot; names allowed on Fri, 17 Jul 2009 04:43:28 GMT]]></title><description><![CDATA[<p dir="auto">There’s nothing complicated about how I have it set up. I have two ZIP and two 7-ZIP profiles. I prefer to select profiles from a drop-down than to keep an eye on various settings, especially when those settings become the new default.</p>
]]></description><link>https://forums.powerarchiver.com/post/20910</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20910</guid><dc:creator><![CDATA[nameless]]></dc:creator><pubDate>Fri, 17 Jul 2009 04:43:28 GMT</pubDate></item><item><title><![CDATA[Reply to Duplicate &quot;Compression Profile&quot; names allowed on Fri, 17 Jul 2009 04:31:14 GMT]]></title><description><![CDATA[<p dir="auto">damn…I’m glad I keep things simple…:)</p>
]]></description><link>https://forums.powerarchiver.com/post/20909</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20909</guid><dc:creator><![CDATA[moles42]]></dc:creator><pubDate>Fri, 17 Jul 2009 04:31:14 GMT</pubDate></item></channel></rss>
