<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Pa 2010 v11.50.49 - update error]]></title><description><![CDATA[<p dir="auto">Hi Team,</p>
<p dir="auto">Hope you are all well?,</p>
<p dir="auto">Not sure if you are aware of this or if anyone else has this same problem but I personaly am having an issue where my current PA is reporting that I can update to version 11.50.66 when selecting update it connects to the server and downloads to my specified location. However, completion I go to install the applicaton and its the same version as the one I currently had.</p>
<p dir="auto">I uninstalled and restarted my system downloaded the latest Version RC direct from your side and again on check for update there was the newer version but allas it would download the same version?? odd…</p>
<p dir="auto">AMD Athlon X2 QL-64, 3 gb RAM</p>
]]></description><link>https://forums.powerarchiver.com/topic/3630/pa-2010-v11-50-49-update-error</link><generator>RSS for Node</generator><lastBuildDate>Mon, 12 Oct 2026 16:55:28 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3630.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 08 Jul 2009 22:04:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Pa 2010 v11.50.49 - update error on Fri, 10 Jul 2009 18:09:00 GMT]]></title><description><![CDATA[<p dir="auto">Its out :)</p>
]]></description><link>https://forums.powerarchiver.com/post/20770</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20770</guid><dc:creator><![CDATA[RJWaring]]></dc:creator><pubDate>Fri, 10 Jul 2009 18:09:00 GMT</pubDate></item><item><title><![CDATA[Reply to Pa 2010 v11.50.49 - update error on Thu, 09 Jul 2009 19:15:57 GMT]]></title><description><![CDATA[<p dir="auto">When is the final release expected?</p>
]]></description><link>https://forums.powerarchiver.com/post/20763</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20763</guid><dc:creator><![CDATA[Keith Weisshar]]></dc:creator><pubDate>Thu, 09 Jul 2009 19:15:57 GMT</pubDate></item><item><title><![CDATA[Reply to Pa 2010 v11.50.49 - update error on Thu, 09 Jul 2009 17:59:56 GMT]]></title><description><![CDATA[<p dir="auto">Ahh I can see now! thanks Spwolf! your a star!!!<br />
PS: Powerarchiver really is the beez knees! im trying to introduce it into the Brakes Group. Currently under review at the momment!</p>
]]></description><link>https://forums.powerarchiver.com/post/20762</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20762</guid><dc:creator><![CDATA[RJWaring]]></dc:creator><pubDate>Thu, 09 Jul 2009 17:59:56 GMT</pubDate></item><item><title><![CDATA[Reply to Pa 2010 v11.50.49 - update error on Wed, 08 Jul 2009 22:21:31 GMT]]></title><description><![CDATA[<p dir="auto">@Sir:</p>
<p dir="auto">we were testing the updates for final release :)</p>
]]></description><link>https://forums.powerarchiver.com/post/20751</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20751</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 08 Jul 2009 22:21:31 GMT</pubDate></item></channel></rss>
