<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Skin switch failure]]></title><description><![CDATA[<p dir="auto">With PA 50.11.57 I tried to switch skin from Modern Blue to Modern Black.</p>
<p dir="auto">This is the resulting screen (Mix of Classic and Modern Blue) “Modern_Black.png”</p>
<p dir="auto">And after restarting PA it is still weird “Modern_Black2.png”</p>
<p dir="auto">Windows XP SP3<br />
<img src="/uploads/_imported_attachments/attachment_t_3932_0_modern_black.png" alt="attachment_t_3932_0_modern_black.png" class=" img-fluid img-markdown" /><br />
<img src="/uploads/_imported_attachments/attachment_t_3932_1_modern_black2.png" alt="attachment_t_3932_1_modern_black2.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forums.powerarchiver.com/topic/3619/skin-switch-failure</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Apr 2026 04:03:19 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3619.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 Jul 2009 10:15:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Skin switch failure on Tue, 07 Jul 2009 21:35:31 GMT]]></title><description><![CDATA[<p dir="auto">Can not reproduce with 50.11.58.<br />
Closing PA is also “fixed” :p</p>
]]></description><link>https://forums.powerarchiver.com/post/20733</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20733</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Tue, 07 Jul 2009 21:35:31 GMT</pubDate></item><item><title><![CDATA[Reply to Skin switch failure on Tue, 07 Jul 2009 15:23:50 GMT]]></title><description><![CDATA[<p dir="auto">New version is up:<br />
<a href="http://www.powerarchiver.com/test/release10/powarc1150final.exe" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.powerarchiver.com/test/release10/powarc1150final.exe</a></p>
<p dir="auto">check it out and see if that fixes it. Thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/20729</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20729</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 07 Jul 2009 15:23:50 GMT</pubDate></item><item><title><![CDATA[Reply to Skin switch failure on Tue, 07 Jul 2009 13:35:36 GMT]]></title><description><![CDATA[<p dir="auto">terry can you send us reg key for that? (where both interfaces are on)</p>
]]></description><link>https://forums.powerarchiver.com/post/20727</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20727</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 07 Jul 2009 13:35:36 GMT</pubDate></item><item><title><![CDATA[Reply to Skin switch failure on Tue, 07 Jul 2009 10:21:37 GMT]]></title><description><![CDATA[<p dir="auto">No skin options available so used set defautls - PA restarted in Classic Toolbar.<br />
Then was able to switch to Modern Blue.</p>
<p dir="auto">Note: PA is very slow closing/restarting as well.</p>
<p dir="auto">Edit Can’t see how to separate the two previous images??</p>
]]></description><link>https://forums.powerarchiver.com/post/20722</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20722</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Tue, 07 Jul 2009 10:21:37 GMT</pubDate></item></channel></rss>
