<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Settings not saved]]></title><description><![CDATA[<p dir="auto">Two things I noticed in RC2 (and RC1, as well):<br />
In the compression profiles, one has to press okay after every change - else it won’t save.<br />
Also, in file formats - I couldn’t dissociate zipx. I finally managed to do it by also dissociating 7z at the same time, then coming back to the menu and re-associate 7z.</p>
<p dir="auto">As always, I’m using Vista Ultimate x64.</p>
]]></description><link>https://forums.powerarchiver.com/topic/3598/settings-not-saved</link><generator>RSS for Node</generator><lastBuildDate>Fri, 04 Sep 2026 17:43:40 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3598.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 31 May 2009 12:41:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Settings not saved on Sun, 07 Jun 2009 14:38:14 GMT]]></title><description><![CDATA[<p dir="auto">Say, spwolf, if you plan on releasing RC3, and make some modifications to it between now and then, could you make that release 11.50.51 or something (so I’ll know to download it again)?</p>
]]></description><link>https://forums.powerarchiver.com/post/20534</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20534</guid><dc:creator><![CDATA[yoniy0]]></dc:creator><pubDate>Sun, 07 Jun 2009 14:38:14 GMT</pubDate></item><item><title><![CDATA[Reply to Settings not saved on Sun, 07 Jun 2009 14:35:38 GMT]]></title><description><![CDATA[<p dir="auto">Yes, everything’s fine now (at least on my machine).<br />
Thanks</p>
]]></description><link>https://forums.powerarchiver.com/post/20532</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20532</guid><dc:creator><![CDATA[yoniy0]]></dc:creator><pubDate>Sun, 07 Jun 2009 14:35:38 GMT</pubDate></item><item><title><![CDATA[Reply to Settings not saved on Sun, 07 Jun 2009 14:11:19 GMT]]></title><description><![CDATA[<p dir="auto">This issue has been fixed in following pre-release:<br />
<a href="http://www.powerarchiver.com/test/alpha115/powarc1150rc3.exe" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.powerarchiver.com/test/alpha115/powarc1150rc3.exe</a></p>
<p dir="auto">Please let me know if it works fine now. Thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/20526</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20526</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 07 Jun 2009 14:11:19 GMT</pubDate></item><item><title><![CDATA[Reply to Settings not saved on Tue, 02 Jun 2009 12:28:58 GMT]]></title><description><![CDATA[<p dir="auto">Second one confirmed in XP also!</p>
<p dir="auto">thanks</p>
]]></description><link>https://forums.powerarchiver.com/post/20497</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20497</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Tue, 02 Jun 2009 12:28:58 GMT</pubDate></item></channel></rss>
