<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Option to back up to USB stick]]></title><description><![CDATA[<p dir="auto">At present I use Syncback, Comodo, Allways, etc. to back up to one or more USB sticks. This works well. I fond that backing up to a re-writable DVD is unsatisfactory as the DVD fills up fairly quickly (even when using incremental backup). Once the DVD is full it is completely useless.</p>
]]></description><link>https://forums.powerarchiver.com/topic/3592/option-to-back-up-to-usb-stick</link><generator>RSS for Node</generator><lastBuildDate>Wed, 18 Nov 2026 08:16:15 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3592.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 08 Jun 2009 00:22:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Option to back up to USB stick on Mon, 08 Jun 2009 11:52:00 GMT]]></title><description><![CDATA[<p dir="auto">You can backup to USB stick in PA Backup as well, up to 3 different drives (including USB sticks) at the same time, plus dvd and plus ftp. Just select drive that USB stick is and it will back it up there.</p>
]]></description><link>https://forums.powerarchiver.com/post/20543</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20543</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 08 Jun 2009 11:52:00 GMT</pubDate></item><item><title><![CDATA[Reply to Option to back up to USB stick on Mon, 08 Jun 2009 11:48:29 GMT]]></title><description><![CDATA[<p dir="auto">Yes. With Syncback, for example, I have the option of backing up to a DVD or to a USB stick. Syncback in the first instance backs up the nominated files to a USB stick. later on, after you have worked on files, SyncBack synchronises the files on the USB stick with the original files. I should add that the files are not compressed.</p>
]]></description><link>https://forums.powerarchiver.com/post/20542</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20542</guid><dc:creator><![CDATA[kafka]]></dc:creator><pubDate>Mon, 08 Jun 2009 11:48:29 GMT</pubDate></item><item><title><![CDATA[Reply to Option to back up to USB stick on Mon, 08 Jun 2009 00:55:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kafka" aria-label="Profile: kafka">@<bdi>kafka</bdi></a>:</p>
<p dir="auto">how do you mean? you can backup to usb stick right now? I am sure i am missing something….</p>
]]></description><link>https://forums.powerarchiver.com/post/20540</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20540</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 08 Jun 2009 00:55:02 GMT</pubDate></item></channel></rss>
