<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PA 2010 stops responding]]></title><description><![CDATA[<p dir="auto">I downloaded and installed the recommended update last week. Version 11.50.41. When running a backup, during the compressing, 1 hr 3 min 36 seconds into the routine, PA stops responding. I need to get a backup done, haven’t had one since last week.</p>
<p dir="auto">Any ideas?</p>
<p dir="auto">TIA</p>
]]></description><link>https://forums.powerarchiver.com/topic/3515/pa-2010-stops-responding</link><generator>RSS for Node</generator><lastBuildDate>Sun, 08 Nov 2026 05:41:53 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3515.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 29 Apr 2009 16:39:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PA 2010 stops responding on Mon, 11 May 2009 17:51:15 GMT]]></title><description><![CDATA[<p dir="auto">please check pre-RC1 release:<br />
<a href="http://www.powerarchiver.com/test/alpha115/powarc1150rc1.exe" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.powerarchiver.com/test/alpha115/powarc1150rc1.exe</a></p>
<p dir="auto">and let us know if this has been fixed :).</p>
<p dir="auto">thanks</p>
]]></description><link>https://forums.powerarchiver.com/post/20260</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20260</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 11 May 2009 17:51:15 GMT</pubDate></item><item><title><![CDATA[Reply to PA 2010 stops responding on Thu, 30 Apr 2009 14:49:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a>:</p>
<p dir="auto">and now we have to figure out why optimize didnt work - are you using ultra for deflate as well?</p>
<p dir="auto">No, I used normal.</p>
]]></description><link>https://forums.powerarchiver.com/post/20194</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20194</guid><dc:creator><![CDATA[mentorcaptl]]></dc:creator><pubDate>Thu, 30 Apr 2009 14:49:01 GMT</pubDate></item><item><title><![CDATA[Reply to PA 2010 stops responding on Thu, 30 Apr 2009 14:30:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mentorcaptl" aria-label="Profile: mentorcaptl">@<bdi>mentorcaptl</bdi></a>:</p>
<p dir="auto">We have success. Thank you so much. It must have needed the change from optimize to deflate. Now I will let it run tonight while no one is here. Thanks again!</p>
]]></description><link>https://forums.powerarchiver.com/post/20193</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20193</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Thu, 30 Apr 2009 14:30:35 GMT</pubDate></item><item><title><![CDATA[Reply to PA 2010 stops responding on Thu, 30 Apr 2009 14:19:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a>:</p>
<p dir="auto">ok, please let us know tomorrow… thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/20192</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20192</guid><dc:creator><![CDATA[mentorcaptl]]></dc:creator><pubDate>Thu, 30 Apr 2009 14:19:40 GMT</pubDate></item><item><title><![CDATA[Reply to PA 2010 stops responding on Wed, 29 Apr 2009 18:15:57 GMT]]></title><description><![CDATA[<p dir="auto">ok, please let us know tomorrow… thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/20191</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20191</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 29 Apr 2009 18:15:57 GMT</pubDate></item><item><title><![CDATA[Reply to PA 2010 stops responding on Wed, 29 Apr 2009 17:56:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a>:</p>
<p dir="auto">also try changing to:</p>
<ol>
<li></li>
</ol>
<p dir="auto">Compression Method = Optimized<br />
Compression Strenght = Normal</p>
<ol start="2">
<li></li>
</ol>
<p dir="auto">Compression Method = Deflate<br />
<p dir="auto">lets see if that makes an difference.</p>
<p dir="auto">thanks!</p>
<p dir="auto">I will give that a try…</p>
<p dir="auto">Yes the compressing shows progression, but stopped at green bar #14 of approx 26,000 files/folders. I may not get to respond on this until tomorrow. Thanks again for being there and so prompt to help, I do appreciate it!<br />
Tammy</p>
]]></description><link>https://forums.powerarchiver.com/post/20190</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20190</guid><dc:creator><![CDATA[mentorcaptl]]></dc:creator><pubDate>Wed, 29 Apr 2009 17:56:01 GMT</pubDate></item><item><title><![CDATA[Reply to PA 2010 stops responding on Wed, 29 Apr 2009 17:50:31 GMT]]></title><description><![CDATA[<p dir="auto">also try changing to:</p>
<ol>
<li></li>
</ol>
<ol start="2">
<li></li>
</ol>
]]></description><link>https://forums.powerarchiver.com/post/20189</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20189</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 29 Apr 2009 17:50:31 GMT</pubDate></item><item><title><![CDATA[Reply to PA 2010 stops responding on Wed, 29 Apr 2009 17:45:35 GMT]]></title><description><![CDATA[<p dir="auto">does the compression run at all? do you see progress indicator at start? At what % does it stop running?</p>
]]></description><link>https://forums.powerarchiver.com/post/20188</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20188</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 29 Apr 2009 17:45:35 GMT</pubDate></item><item><title><![CDATA[Reply to PA 2010 stops responding on Wed, 29 Apr 2009 17:36:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a>:</p>
<p dir="auto">is HDD doing anything or? Send us that pbs script please.</p>
<p dir="auto">I zipped it so I could attach for you.<br />
<a href="/uploads/_imported_attachments/attachment_p_18463_0_daily-new.zip">attachment_p_18463_0_daily-new.zip</a></p>
]]></description><link>https://forums.powerarchiver.com/post/20187</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20187</guid><dc:creator><![CDATA[mentorcaptl]]></dc:creator><pubDate>Wed, 29 Apr 2009 17:36:48 GMT</pubDate></item><item><title><![CDATA[Reply to PA 2010 stops responding on Wed, 29 Apr 2009 17:24:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a>:</p>
<p dir="auto">Hard drive is quiet, but I can access it.</p>
<p dir="auto">How do I send you the pbs?</p>
]]></description><link>https://forums.powerarchiver.com/post/20186</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20186</guid><dc:creator><![CDATA[mentorcaptl]]></dc:creator><pubDate>Wed, 29 Apr 2009 17:24:50 GMT</pubDate></item><item><title><![CDATA[Reply to PA 2010 stops responding on Wed, 29 Apr 2009 17:08:42 GMT]]></title><description><![CDATA[<p dir="auto">is HDD doing anything or? Send us that pbs script please.</p>
]]></description><link>https://forums.powerarchiver.com/post/20185</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20185</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 29 Apr 2009 17:08:42 GMT</pubDate></item><item><title><![CDATA[Reply to PA 2010 stops responding on Wed, 29 Apr 2009 17:01:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a>:</p>
<p dir="auto">did you leave it be for a while?</p>
<p dir="auto">It’s been sitting at the same screen with the same time for over 2 hours….</p>
]]></description><link>https://forums.powerarchiver.com/post/20184</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20184</guid><dc:creator><![CDATA[mentorcaptl]]></dc:creator><pubDate>Wed, 29 Apr 2009 17:01:18 GMT</pubDate></item><item><title><![CDATA[Reply to PA 2010 stops responding on Wed, 29 Apr 2009 16:56:44 GMT]]></title><description><![CDATA[<p dir="auto">did you leave it be for a while?</p>
]]></description><link>https://forums.powerarchiver.com/post/20183</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/20183</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 29 Apr 2009 16:56:44 GMT</pubDate></item></channel></rss>
