<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem with relative path in PBS]]></title><description><![CDATA[<p dir="auto">I’ve created a PBS to archive (to a ZIP) all files in a folder and its subfolders. In the PBS, ‘Store relative folder information (not full location)’ is turned ON. The folder looks like this, conceptually:</p>
<p dir="auto">folder<br />
–file1<br />
–file2<br />
–file3<br />
–subfolder<br />
----file4<br />
----file5</p>
<p dir="auto">What I want is for the ZIP file to contain this:</p>
<p dir="auto">file1<br />
file2<br />
file3<br />
subfolder<br />
–file4<br />
–file5</p>
<p dir="auto">But instead, the ZIP file contains this:</p>
–file1<br />
–file2<br />
–file3<br />
–subfolder<br />
----file4<br />
----file5</p>
<p dir="auto">I’ve run this PBS both when the ‘Use normal relative path’ setting in PA itself is turned OFF and ON, and the result is the same.</p>
<p dir="auto">Is there any way I can get the PBS to do what I want?</p>
<p dir="auto">FWIW, when I use PA to create this ZIP “manually,” the ‘Use normal relative path’ DOES make a difference. When it’s OFF, I get the result I want. When it’s ON, the root folder gets stored in the ZIP. But that setting does not seem to affect PBS-created ZIPs.</p>
<p dir="auto">Jeff Jansen</p>
<p dir="auto">Addendum: The same problem occurs even when the folder has no subfolder. Correction from original in red.</p>
]]></description><link>https://forums.powerarchiver.com/topic/3462/problem-with-relative-path-in-pbs</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 17:14:59 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3462.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 27 Mar 2009 01:49:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem with relative path in PBS on Fri, 27 Mar 2009 18:22:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jsjansen" aria-label="Profile: jsjansen">@<bdi>jsjansen</bdi></a>:</p>
<p dir="auto">By which I meant to say:</p>
<p dir="auto">When I:</p>
<ol>
<li>have this file structure:</li>
</ol>
–file1<br />
–file2<br />
–file3</p>
<ol start="2">
<li>Configure PA with ‘Use normal relative path’ OFF</li>
</ol>
<p dir="auto">and</p>
<ol start="3">
<li>Create a PBS to backup ‘folder’ with ‘Include subfolders’ ON or OFF, and ‘Store relative folder information’ ON,</li>
</ol>
<p dir="auto">then the resulting zip file contains this:</p>
–file1<br />
–file2<br />
–file3</p>
<p dir="auto">and not this:</p>
file2<br />
file3</p>
<p dir="auto">yeah, of course - it does not respect that option right now. I was just commenting that in the future, only difference would be exactly that situation that you are commenting :-)</p>
]]></description><link>https://forums.powerarchiver.com/post/19974</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/19974</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 27 Mar 2009 18:22:38 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with relative path in PBS on Fri, 27 Mar 2009 18:08:47 GMT]]></title><description><![CDATA[<p dir="auto">By which I meant to say:</p>
<ol>
</ol>
–file1<br />
–file2<br />
–file3</p>
<ol start="2">
</ol>
<ol start="3">
</ol>
–file1<br />
–file2<br />
–file3</p>
file2<br />
file3</p>
]]></description><link>https://forums.powerarchiver.com/post/19973</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/19973</guid><dc:creator><![CDATA[jsjansen]]></dc:creator><pubDate>Fri, 27 Mar 2009 18:08:47 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with relative path in PBS on Fri, 27 Mar 2009 10:58:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jsjansen" aria-label="Profile: jsjansen">@<bdi>jsjansen</bdi></a>:</p>
<p dir="auto">Actually, I find that the PBS does <em>not</em> work even if I have only a single folder added.</p>
<p dir="auto">dont work?</p>
]]></description><link>https://forums.powerarchiver.com/post/19948</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/19948</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 27 Mar 2009 10:58:08 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with relative path in PBS on Fri, 27 Mar 2009 07:58:29 GMT]]></title><description><![CDATA[<p dir="auto">Actually, I find that the PBS does <em>not</em> work even if I have only a single folder added.</p>
]]></description><link>https://forums.powerarchiver.com/post/19940</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/19940</guid><dc:creator><![CDATA[jsjansen]]></dc:creator><pubDate>Fri, 27 Mar 2009 07:58:29 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with relative path in PBS on Fri, 27 Mar 2009 04:19:49 GMT]]></title><description><![CDATA[<p dir="auto">we will take an look, but you do understand that this will work if you have only single folder aded? Just like in main PA.</p>
]]></description><link>https://forums.powerarchiver.com/post/19939</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/19939</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 27 Mar 2009 04:19:49 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with relative path in PBS on Fri, 27 Mar 2009 04:00:56 GMT]]></title><description><![CDATA[<p dir="auto">Great! So are you saying that will go on the list of changes to make?</p>
<p dir="auto">Jeff</p>
]]></description><link>https://forums.powerarchiver.com/post/19938</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/19938</guid><dc:creator><![CDATA[jsjansen]]></dc:creator><pubDate>Fri, 27 Mar 2009 04:00:56 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with relative path in PBS on Fri, 27 Mar 2009 03:52:56 GMT]]></title><description><![CDATA[<p dir="auto">i guess we can apply same option as in main pa for relative paths.</p>
]]></description><link>https://forums.powerarchiver.com/post/19937</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/19937</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 27 Mar 2009 03:52:56 GMT</pubDate></item></channel></rss>
