<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PA2010 bug&#x5C;spanned archive]]></title><description><![CDATA[<p dir="auto">I just noticed this with PA2010 Pro 11.50.20. After creating a spanned archive I get an error when trying to extract it.</p>
<p dir="auto">I created the archive using the following settings…<br />
<a href="http://img14.imageshack.us/my.php?image=pa2010ag2.jpg" target="_blank" rel="noopener noreferrer nofollow ugc"><img src="http://img14.imageshack.us/img14/1506/pa2010ag2.th.jpg" alt="" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">All seems well until I try to extract it…<br />
<a href="http://img17.imageshack.us/my.php?image=pa20103lw7.jpg" target="_blank" rel="noopener noreferrer nofollow ugc"><img src="http://img17.imageshack.us/img17/7200/pa20103lw7.th.jpg" alt="" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">When I try to open the archive I get this….<br />
<a href="http://img21.imageshack.us/my.php?image=pa20101mz5.jpg" target="_blank" rel="noopener noreferrer nofollow ugc"><img src="http://img21.imageshack.us/img21/2599/pa20101mz5.th.jpg" alt="" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">If I open the archive by clicking on the smallest file it opens fine, but I still cannot extract it properly…<br />
<a href="http://img24.imageshack.us/my.php?image=pa20102fv3.jpg" target="_blank" rel="noopener noreferrer nofollow ugc"><img src="http://img24.imageshack.us/img24/9346/pa20102fv3.th.jpg" alt="" class=" img-fluid img-markdown" /></a></p>
<p dir="auto">The PP presentation works fine and is not corrupted. I’m using vista 64 with office 2007. Thanks.</p>
]]></description><link>https://forums.powerarchiver.com/topic/3409/pa2010-bug-spanned-archive</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Apr 2026 09:45:33 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3409.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 04 Mar 2009 22:45:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PA2010 bug&#x5C;spanned archive on Tue, 10 Mar 2009 15:06:53 GMT]]></title><description><![CDATA[<p dir="auto">more than welcome :)…</p>
]]></description><link>https://forums.powerarchiver.com/post/19623</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/19623</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 10 Mar 2009 15:06:53 GMT</pubDate></item><item><title><![CDATA[Reply to PA2010 bug&#x5C;spanned archive on Tue, 10 Mar 2009 15:05:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a>:</p>
<p dir="auto">please check with official beta 1, and let us know if this has been fixed… thank you!</p>
<p dir="auto">Checked it last night and it working! Thank you. :D</p>
]]></description><link>https://forums.powerarchiver.com/post/19622</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/19622</guid><dc:creator><![CDATA[skypx]]></dc:creator><pubDate>Tue, 10 Mar 2009 15:05:44 GMT</pubDate></item><item><title><![CDATA[Reply to PA2010 bug&#x5C;spanned archive on Tue, 10 Mar 2009 14:16:13 GMT]]></title><description><![CDATA[<p dir="auto">please check with official beta 1, and let us know if this has been fixed… thank you!</p>
]]></description><link>https://forums.powerarchiver.com/post/19617</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/19617</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 10 Mar 2009 14:16:13 GMT</pubDate></item><item><title><![CDATA[Reply to PA2010 bug&#x5C;spanned archive on Thu, 05 Mar 2009 21:21:38 GMT]]></title><description><![CDATA[<p dir="auto">Thanks. :D Looking forward to the next beta.</p>
]]></description><link>https://forums.powerarchiver.com/post/19547</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/19547</guid><dc:creator><![CDATA[skypx]]></dc:creator><pubDate>Thu, 05 Mar 2009 21:21:38 GMT</pubDate></item><item><title><![CDATA[Reply to PA2010 bug&#x5C;spanned archive on Thu, 05 Mar 2009 19:24:13 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">There are (were) few problems. We hopefully detected and solved them all:</p>
<ol>
<li>Creating spanned zip archives had problem - corrupted spanned archive or archives with wrong naming were created</li>
<li>Extracting spanned zip archives had problem - crc error while extracting correct spanned archives</li>
<li>we now added a feature to detect “last” - smallest part of zip archive and open that part when you try to open any part either in main interface using “open” button, or in Windows Explorer.</li>
</ol>
]]></description><link>https://forums.powerarchiver.com/post/19537</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/19537</guid><dc:creator><![CDATA[ivan]]></dc:creator><pubDate>Thu, 05 Mar 2009 19:24:13 GMT</pubDate></item><item><title><![CDATA[Reply to PA2010 bug&#x5C;spanned archive on Wed, 04 Mar 2009 23:20:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/skypx" aria-label="Profile: skypx">@<bdi>skypx</bdi></a>:</p>
<p dir="auto">If I open the archive from PA and select the first file it opens fine, if I select any of the other parts it won’t open and no error message is shown.</p>
<p dir="auto">ok, so its problem with new drag and drop stuff… thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/19511</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/19511</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 04 Mar 2009 23:20:28 GMT</pubDate></item><item><title><![CDATA[Reply to PA2010 bug&#x5C;spanned archive on Wed, 04 Mar 2009 23:09:39 GMT]]></title><description><![CDATA[<p dir="auto">If I open the archive from PA and select the first file it opens fine, if I select any of the other parts it won’t open and no error message is shown.</p>
]]></description><link>https://forums.powerarchiver.com/post/19508</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/19508</guid><dc:creator><![CDATA[skypx]]></dc:creator><pubDate>Wed, 04 Mar 2009 23:09:39 GMT</pubDate></item><item><title><![CDATA[Reply to PA2010 bug&#x5C;spanned archive on Wed, 04 Mar 2009 22:58:02 GMT]]></title><description><![CDATA[<p dir="auto">ok so when you open it with open button instead of doubleclick what happnes? Works?</p>
]]></description><link>https://forums.powerarchiver.com/post/19506</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/19506</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 04 Mar 2009 22:58:02 GMT</pubDate></item></channel></rss>
