<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[The longer the better?]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">this is just a shot in the dark but maybe someone could help me. :) The thing is that earlier this week I needed to packed batch of files and put a password on it. And so I did. I didn’t use any compression it was all about password. And because I needed it to be safe I used a citation from a book (exactly 972 symbols), copy-paste method. Well, when it was packed I tried again copy-paste method and unpacked. Everything worked, so I deleted the original files.<br />
But today (after hdd format and winXP reinstall) I tried to unpack the archive just like I did few days before … and it just won’t work.<br />
When I copy the pass PA just creates an empty folder and that’s it no other actvity or error message. I also tried to use older version - the same I used for creating the archiv - but it’s all the same.<br />
When I try to use first 128 symbols of the pass it says that password is wrong. When entered 129 and more -does nothing, like I said before.<br />
Well I know that it was stupid to use such a long password (don’t judge, I’m only human), but I hope that someone might have something to say and help me. :o</p>
<p dir="auto">Another thing just crossed my mind - the password is composed of some special symbols (á,č,š,ř,ž…) I’m from CZE … but first time it worked, so …<br />
Anyway, thx for every idea…</p>
<p dir="auto">Born</p>
]]></description><link>https://forums.powerarchiver.com/topic/3336/the-longer-the-better</link><generator>RSS for Node</generator><lastBuildDate>Mon, 12 Oct 2026 15:56:21 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3336.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 23 Jan 2009 18:00:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to The longer the better? on Fri, 23 Jan 2009 18:34:42 GMT]]></title><description><![CDATA[<p dir="auto">check your Control Panel&gt; Regional and Language&gt; Formats, and see if something there could be done differently now from then…</p>
]]></description><link>https://forums.powerarchiver.com/post/19164</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/19164</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 23 Jan 2009 18:34:42 GMT</pubDate></item><item><title><![CDATA[Reply to The longer the better? on Fri, 23 Jan 2009 18:27:17 GMT]]></title><description><![CDATA[<p dir="auto">The only thing I can think about is new RAM modules, OS is same, language settings was probably the same as it’s now - I’m not aware of changing it … so I guess now it’s just a big pack of trash :)</p>
]]></description><link>https://forums.powerarchiver.com/post/19162</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/19162</guid><dc:creator><![CDATA[Born]]></dc:creator><pubDate>Fri, 23 Jan 2009 18:27:17 GMT</pubDate></item><item><title><![CDATA[Reply to The longer the better? on Fri, 23 Jan 2009 18:04:35 GMT]]></title><description><![CDATA[<p dir="auto">did something else changed as well? maybe you had different computer/os? Thinking about those special symbols and maybe different language setting that may have affected it…</p>
<p dir="auto">and yeah, long, long, long, long! I will enter it as an bug (support for too many letters).</p>
]]></description><link>https://forums.powerarchiver.com/post/19158</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/19158</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 23 Jan 2009 18:04:35 GMT</pubDate></item></channel></rss>
