<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mounting other type of image files]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">As PowerArchiver Pro is able to mount ISO file thank to Virtual drives, what about using this facility to mount other archive type as .NRG for example ?</p>
]]></description><link>https://forums.powerarchiver.com/topic/3321/mounting-other-type-of-image-files</link><generator>RSS for Node</generator><lastBuildDate>Sat, 08 Aug 2026 18:47:39 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3321.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 20 Jan 2009 18:38:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mounting other type of image files on Fri, 12 Feb 2010 21:21:45 GMT]]></title><description><![CDATA[<p dir="auto">@Claude:</p>
<p dir="auto">You know what tool is excellent for that? Virtual Clone Drive. It’s free also.</p>
]]></description><link>https://forums.powerarchiver.com/post/22651</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/22651</guid><dc:creator><![CDATA[AluminumHaste]]></dc:creator><pubDate>Fri, 12 Feb 2010 21:21:45 GMT</pubDate></item><item><title><![CDATA[Reply to Mounting other type of image files on Sun, 31 Jan 2010 06:09:26 GMT]]></title><description><![CDATA[<p dir="auto">I very vaguely remembered that someone told me about this a long time ago, so I already gave that a try.<br />
PA gave some kind of warning and cud not handle the file (I forgot what kind of warning though).</p>
<p dir="auto">Assuming I got it wrong after all, went on to search and install an ‘ISO-program’ to handle the bin-files.<br />
As far as I cud see my installed Nero cud only handle iso files.</p>
<p dir="auto">Yes, I confess…<br />
I still have Nero installed. I have not thoroughly tested PA enough to see whether it could replace Nero, for burning video DVD’s and audio CD’s. :o</p>
<p dir="auto">80-90% of the Nero I don’t need (all the multimedia-stuff): I use its burning features only. Am using v.8.x and don’t update it anymore. Already slightly doubted when updating fm 6 to 7. It got bloatware and most of the reactions on the lite version are negative.</p>
<p dir="auto">So, maybe at the next fresh Windows-install, I skip it and see whether PA can handle all the burning.</p>
<p dir="auto">Anyway, that aside… not handling the bin-file triggered me to post a comment again on this thread.</p>
<p dir="auto">=</p>
]]></description><link>https://forums.powerarchiver.com/post/22557</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/22557</guid><dc:creator><![CDATA[wulffra]]></dc:creator><pubDate>Sun, 31 Jan 2010 06:09:26 GMT</pubDate></item><item><title><![CDATA[Reply to Mounting other type of image files on Sat, 30 Jan 2010 22:00:06 GMT]]></title><description><![CDATA[<p dir="auto">there will be some cool changes to VD for PA 2011…</p>
<p dir="auto">… as to the bin, most of them will work if you renamed .bin file to .iso… forgot the details, maybe multisession ones will not…</p>
]]></description><link>https://forums.powerarchiver.com/post/22551</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/22551</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sat, 30 Jan 2010 22:00:06 GMT</pubDate></item><item><title><![CDATA[Reply to Mounting other type of image files on Sat, 30 Jan 2010 11:54:54 GMT]]></title><description><![CDATA[<p dir="auto">Any developmonts on mounting other filetypes, like .bin, .nrg ?</p>
<h1>thanks</h1>
]]></description><link>https://forums.powerarchiver.com/post/22546</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/22546</guid><dc:creator><![CDATA[wulffra]]></dc:creator><pubDate>Sat, 30 Jan 2010 11:54:54 GMT</pubDate></item><item><title><![CDATA[Reply to Mounting other type of image files on Tue, 10 Nov 2009 20:31:20 GMT]]></title><description><![CDATA[<p dir="auto">Yes, that would be great…! Hoped it was available in the 2010 version.<br />
Anyway, let’s cross our fingers it will be available someone in the near future.</p>
]]></description><link>https://forums.powerarchiver.com/post/21881</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/21881</guid><dc:creator><![CDATA[wulffra]]></dc:creator><pubDate>Tue, 10 Nov 2009 20:31:20 GMT</pubDate></item></channel></rss>
