<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Openoffice documents show &quot;File Download&quot; dialog with preview enabled]]></title><description><![CDATA[<p dir="auto">For as long as I could remember, when Preview mode is set to Smart or Enabled, a Internet Explorer “File Download” dialog always pops up. When I disable the Preview pane, that dialog goes away.</p>
<p dir="auto">AFAIK, all Openoffice documents are affected by this bug</p>
<p dir="auto">Here’s a screenshot:</p>
<p dir="auto"><a href="http://img223.imageshack.us/my.php?image=problemss7.jpg" target="_blank" rel="noopener noreferrer nofollow ugc">http://img223.imageshack.us/my.php?image=problemss7.jpg</a></p>
]]></description><link>https://forums.powerarchiver.com/topic/3280/openoffice-documents-show-file-download-dialog-with-preview-enabled</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 23:21:42 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3280.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 14 Dec 2008 18:55:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Openoffice documents show &quot;File Download&quot; dialog with preview enabled on Mon, 15 Dec 2008 21:23:50 GMT]]></title><description><![CDATA[<p dir="auto">nice :-)</p>
]]></description><link>https://forums.powerarchiver.com/post/18940</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18940</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 15 Dec 2008 21:23:50 GMT</pubDate></item><item><title><![CDATA[Reply to Openoffice documents show &quot;File Download&quot; dialog with preview enabled on Sun, 14 Dec 2008 20:36:22 GMT]]></title><description><![CDATA[<p dir="auto">Never noticed that option before….</p>
<p dir="auto">all Openoffice filetypes are listed under ‘internet’ (which explains the IE file download box).</p>
<p dir="auto">edit&gt; Openoffice provides a ActiveX control, but it isn’t installed by default. Install that, and I bet it will work then.</p>
<p dir="auto">Openoffice setup doesn’t register the activeX control either. You have to do it manually:</p>
<p dir="auto">regsvr32 “C:\Program Files\OpenOffice.org 3\Basis\program\so_activex.dll”</p>
<p dir="auto"><strong>btw, it works :) A little cramped with the extra buttons that Openoffice provides, but works none-the-less</strong></p>
]]></description><link>https://forums.powerarchiver.com/post/18933</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18933</guid><dc:creator><![CDATA[Kribby]]></dc:creator><pubDate>Sun, 14 Dec 2008 20:36:22 GMT</pubDate></item><item><title><![CDATA[Reply to Openoffice documents show &quot;File Download&quot; dialog with preview enabled on Sun, 14 Dec 2008 20:17:38 GMT]]></title><description><![CDATA[<p dir="auto">What is set for the OpenOffice filetypes under “Configuration / Preview, Command Line” (ods etc.)?</p>
]]></description><link>https://forums.powerarchiver.com/post/18932</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18932</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Sun, 14 Dec 2008 20:17:38 GMT</pubDate></item></channel></rss>
