<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Interface Not supported]]></title><description><![CDATA[<p dir="auto">Each time i try to compress files by right clicking and then Compress to zip i get the same error message and nothing happens.<br />
Does someone know what to do ??</p>
]]></description><link>https://forums.powerarchiver.com/topic/3248/interface-not-supported</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Nov 2026 15:26:40 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3248.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 12 Nov 2008 22:45:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Interface Not supported on Thu, 13 Nov 2008 17:59:33 GMT]]></title><description><![CDATA[<p dir="auto">what ISP do you use? We can let our download service check connectivity between your ISP and our download servers (there are 14 of them around the world, and you go to closest one to you).</p>
]]></description><link>https://forums.powerarchiver.com/post/18755</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18755</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Thu, 13 Nov 2008 17:59:33 GMT</pubDate></item><item><title><![CDATA[Reply to Interface Not supported on Thu, 13 Nov 2008 17:27:40 GMT]]></title><description><![CDATA[<p dir="auto">Ok Many thanks <strong>spwolf</strong>, my problem was solved by reinstalling like you’ve said !</p>
<p dir="auto">Used Stardownloader but needed to wait a long time because disconnections from your server , strange on other website i’ve no problems :confused:</p>
]]></description><link>https://forums.powerarchiver.com/post/18754</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18754</guid><dc:creator><![CDATA[schhub]]></dc:creator><pubDate>Thu, 13 Nov 2008 17:27:40 GMT</pubDate></item><item><title><![CDATA[Reply to Interface Not supported on Thu, 13 Nov 2008 12:51:50 GMT]]></title><description><![CDATA[<p dir="auto">doesnt seem so, try downloading with some download tool like <a href="http://getright.com" target="_blank" rel="noopener noreferrer nofollow ugc">getright.com</a>… that should help.</p>
<p dir="auto">thanks</p>
]]></description><link>https://forums.powerarchiver.com/post/18749</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18749</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Thu, 13 Nov 2008 12:51:50 GMT</pubDate></item><item><title><![CDATA[Reply to Interface Not supported on Thu, 13 Nov 2008 12:09:34 GMT]]></title><description><![CDATA[<p dir="auto">I’ll try to reinstall but at the moment i can’t download the new 11.02 version. Donwload starts and then i have an error message. Is there something wrong with your server ??</p>
]]></description><link>https://forums.powerarchiver.com/post/18748</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18748</guid><dc:creator><![CDATA[schhub]]></dc:creator><pubDate>Thu, 13 Nov 2008 12:09:34 GMT</pubDate></item><item><title><![CDATA[Reply to Interface Not supported on Wed, 12 Nov 2008 23:41:30 GMT]]></title><description><![CDATA[<p dir="auto">reinstall PA 2009 11.02 and restart your computer… It should work fine.</p>
]]></description><link>https://forums.powerarchiver.com/post/18747</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18747</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 12 Nov 2008 23:41:30 GMT</pubDate></item></channel></rss>
