<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[&quot;don&#x27;t extract pathnames&quot; in shell extraction doesn&#x27;t work]]></title><description><![CDATA[<p dir="auto">The option “don’t exract pathnames” in the “extract to…” dialouge via shell doesn’t work.<br />
When I have an archive that has stored pathnames in it and I want to extract the archive without pathnames PA still extract the archive with pathnames.</p>
<p dir="auto">It happens with .rar and cab. files. Zip and .7zip files extract correctly.</p>
<p dir="auto">When I extract via main PA and check the option “don’t extract pathnames” then it works for .rar and .cab files but doesn’t via shell.</p>
]]></description><link>https://forums.powerarchiver.com/topic/3173/don-t-extract-pathnames-in-shell-extraction-doesn-t-work</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Nov 2026 00:20:48 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3173.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 18 Sep 2008 18:20:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to &quot;don&#x27;t extract pathnames&quot; in shell extraction doesn&#x27;t work on Wed, 24 Sep 2008 16:41:21 GMT]]></title><description><![CDATA[<p dir="auto">The shell extension bug will be fixed.</p>
<p dir="auto">I just tried extracting form main and creating empty folders worked fine for RAR files. I think extracting empty folders doesn’t work for CAB because CAB cannot save empty folders.</p>
]]></description><link>https://forums.powerarchiver.com/post/18372</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18372</guid><dc:creator><![CDATA[ivan]]></dc:creator><pubDate>Wed, 24 Sep 2008 16:41:21 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;don&#x27;t extract pathnames&quot; in shell extraction doesn&#x27;t work on Wed, 24 Sep 2008 14:40:03 GMT]]></title><description><![CDATA[<p dir="auto">Yes, I did. I also deinstalled PA and then reinstalled it.</p>
]]></description><link>https://forums.powerarchiver.com/post/18371</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18371</guid><dc:creator><![CDATA[ACE135]]></dc:creator><pubDate>Wed, 24 Sep 2008 14:40:03 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;don&#x27;t extract pathnames&quot; in shell extraction doesn&#x27;t work on Wed, 24 Sep 2008 13:14:02 GMT]]></title><description><![CDATA[<p dir="auto">did you restart your computer for new shell extensions to be installed? thanks</p>
]]></description><link>https://forums.powerarchiver.com/post/18369</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18369</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 24 Sep 2008 13:14:02 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;don&#x27;t extract pathnames&quot; in shell extraction doesn&#x27;t work on Wed, 24 Sep 2008 13:10:46 GMT]]></title><description><![CDATA[<p dir="auto">In main PA he now doesn’t create empty folders.<br />
But via shell it’s the same problem as before. It only doesn’t work for .cab and .rar files.</p>
]]></description><link>https://forums.powerarchiver.com/post/18368</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18368</guid><dc:creator><![CDATA[ACE135]]></dc:creator><pubDate>Wed, 24 Sep 2008 13:10:46 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;don&#x27;t extract pathnames&quot; in shell extraction doesn&#x27;t work on Tue, 23 Sep 2008 23:06:12 GMT]]></title><description><![CDATA[<p dir="auto">Please try with final pre-release version:<br />
<a href="http://www.powerarchiver.com/test/release10/powarc1100rc5.exe" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.powerarchiver.com/test/release10/powarc1100rc5.exe</a></p>
<p dir="auto">And let us know if this has been improved right away.</p>
<p dir="auto">thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/18348</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18348</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 23 Sep 2008 23:06:12 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;don&#x27;t extract pathnames&quot; in shell extraction doesn&#x27;t work on Thu, 18 Sep 2008 21:06:06 GMT]]></title><description><![CDATA[<p dir="auto">thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/18320</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18320</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Thu, 18 Sep 2008 21:06:06 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;don&#x27;t extract pathnames&quot; in shell extraction doesn&#x27;t work on Thu, 18 Sep 2008 20:06:57 GMT]]></title><description><![CDATA[<p dir="auto">I have just noticed that when I extract via main PA with this option that PA extracts the files without pathname but he creates an empty folder with the name of the folders that are in the archive.</p>
]]></description><link>https://forums.powerarchiver.com/post/18318</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18318</guid><dc:creator><![CDATA[ACE135]]></dc:creator><pubDate>Thu, 18 Sep 2008 20:06:57 GMT</pubDate></item></channel></rss>
