<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Using same password for extracting multiple files]]></title><description><![CDATA[<p dir="auto">I wish there could be an an option that PowerArchiver uses the same password if I want to extract multiple files over the shell menu which all have the same password.</p>
]]></description><link>https://forums.powerarchiver.com/topic/3129/using-same-password-for-extracting-multiple-files</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 11:36:49 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3129.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 Aug 2008 14:42:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Using same password for extracting multiple files on Mon, 01 Dec 2008 17:19:58 GMT]]></title><description><![CDATA[<p dir="auto">I extract via right-click and then “extract here” or extract to".</p>
<p dir="auto">Same problem is via main GUI.</p>
]]></description><link>https://forums.powerarchiver.com/post/18861</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18861</guid><dc:creator><![CDATA[ACE135]]></dc:creator><pubDate>Mon, 01 Dec 2008 17:19:58 GMT</pubDate></item><item><title><![CDATA[Reply to Using same password for extracting multiple files on Mon, 01 Dec 2008 16:46:38 GMT]]></title><description><![CDATA[<p dir="auto">yes, this was supposed to be fixed in final version… how exactly are you extracting files? thanks</p>
]]></description><link>https://forums.powerarchiver.com/post/18858</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18858</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 01 Dec 2008 16:46:38 GMT</pubDate></item><item><title><![CDATA[Reply to Using same password for extracting multiple files on Mon, 01 Dec 2008 16:21:05 GMT]]></title><description><![CDATA[<p dir="auto">Works good so far, but is it possible, that, if PA shows the error message because of wrong password, that I can reenter the password for this file?</p>
<p dir="auto">PA is skipping the first file with incorrect passwort.</p>
<p dir="auto">For example:</p>
<p dir="auto">I have 10 files.<br />
Files 1 - 5 have the password “test1” and the files 6 - 10 have the password “test2”.</p>
<p dir="auto">When I Select all files and extract via shell then I enter the password “test1” and PA extract files 1 - 5.<br />
On file 6 PA shows error because of wrong password.</p>
<p dir="auto">And then PA gives me the option to enter a new password. But PA will use the new password beginning at file 7, So that file 6 will not be extracted.</p>
<p dir="auto">I want that the new entered password will be used for file 6 too.</p>
<p dir="auto">I hope you can understand what I mean.</p>
]]></description><link>https://forums.powerarchiver.com/post/18857</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18857</guid><dc:creator><![CDATA[ACE135]]></dc:creator><pubDate>Mon, 01 Dec 2008 16:21:05 GMT</pubDate></item><item><title><![CDATA[Reply to Using same password for extracting multiple files on Sat, 29 Nov 2008 13:09:09 GMT]]></title><description><![CDATA[<p dir="auto">added to 11.03 - if you select multiple files to extract, password will be stored for that session (make sure save session password option is checked in config, if it does not work)… you can get 11.03 via web update.</p>
]]></description><link>https://forums.powerarchiver.com/post/18835</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18835</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sat, 29 Nov 2008 13:09:09 GMT</pubDate></item></channel></rss>
