<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Updating archives]]></title><description><![CDATA[<p dir="auto">PA 2009 Pro 11.00.55<br />
Win XP SP3<br />
I have a ZIP archive in which I keep files which are being edited elsewhere. I like to keep these up to date, and would normally use the Update or Freshen options. However, in both advanced and Basic add windows, I am offered only Add (and replace) and Move. This applies both to existing archives and new ones when I test this out.</p>
<p dir="auto">I note also that if I wish to create a custom Profile for ZIP just to Update or Freshen, I am offered only Add or Move.</p>
<p dir="auto">It occurred to me that Update/Freshen had for some reason been removed, but they are described in the current Help. I am NOT using the Modern Toolbar</p>
<p dir="auto">Advice please.</p>
]]></description><link>https://forums.powerarchiver.com/topic/3125/updating-archives</link><generator>RSS for Node</generator><lastBuildDate>Wed, 11 Mar 2026 07:35:34 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3125.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 27 Aug 2008 11:26:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Updating archives on Fri, 12 Sep 2008 11:03:03 GMT]]></title><description><![CDATA[<p dir="auto">Thanks. Just downloaded and installed 11.00.65 which seems to have fixed this. Good work all.</p>
]]></description><link>https://forums.powerarchiver.com/post/18273</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18273</guid><dc:creator><![CDATA[PA_Fan]]></dc:creator><pubDate>Fri, 12 Sep 2008 11:03:03 GMT</pubDate></item><item><title><![CDATA[Reply to Updating archives on Fri, 12 Sep 2008 10:36:47 GMT]]></title><description><![CDATA[<p dir="auto">You need to check RC1 - this issue should be fixed now (replacing files while add directly to zip option is checked)… thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/18270</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18270</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 12 Sep 2008 10:36:47 GMT</pubDate></item><item><title><![CDATA[Reply to Updating archives on Fri, 12 Sep 2008 07:08:49 GMT]]></title><description><![CDATA[<p dir="auto">Thanks. I do appreciate that Freshen and Update have the effect of updating a file already in the archive provided that the parameters are identical i.e. it didn’t update if the original file was stored with no path but the “freshen-update” instruction asked to store the path,which added the same file with path alongside the existing file in the archive.</p>
<p dir="auto">However, I pose this problem.</p>
<p dir="auto">I have a zip archive containing a dozen Word files which I originally moved to the archive - they no longer exist in their original folder. They are stored without path.<br />
I decide that one needs editing, so I extract it to a “dump” folder and alter it - thus changing the file date to today’s from one back in May and the size also. (Note-I have done this because I don’t want to edit the file direct from the archive as I have a number of alterations to make over the day).</p>
<p dir="auto">I then want to update the file in the archive, so using advanced add I select the file (no path) and am offered Add (and Replace) or Move. I select Add. PA then processes the file, but the file in the archive remains the same (old date and size). I refresh the screen just in case, and then open the file with Word direct from the archive-to find that my edits are not there, which confirms that Add (and Replace) has not replaced the archive file with the external edited version. The same thing happens if I select Move.</p>
]]></description><link>https://forums.powerarchiver.com/post/18265</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18265</guid><dc:creator><![CDATA[PA_Fan]]></dc:creator><pubDate>Fri, 12 Sep 2008 07:08:49 GMT</pubDate></item><item><title><![CDATA[Reply to Updating archives on Fri, 12 Sep 2008 00:02:22 GMT]]></title><description><![CDATA[<p dir="auto">hm - let me restate - update and freshen will only update files you have in the zip already - it will not add other files you tried. Thats why we have Add and replace - which you could also name Add and Update or Add and Refresh :)</p>
]]></description><link>https://forums.powerarchiver.com/post/18259</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18259</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 12 Sep 2008 00:02:22 GMT</pubDate></item><item><title><![CDATA[Reply to Updating archives on Wed, 27 Aug 2008 14:10:54 GMT]]></title><description><![CDATA[<p dir="auto">there is some problem with that option - expect it back in b6/rc1</p>
]]></description><link>https://forums.powerarchiver.com/post/18165</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18165</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 27 Aug 2008 14:10:54 GMT</pubDate></item></channel></rss>
