<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Slow display of files + high CPU]]></title><description><![CDATA[<p dir="auto">I think this may be similar to what I posted in this thread.<br />
<a href="http://www.powerarchiver.com/forums/showthread.php?t=3275" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.powerarchiver.com/forums/showthread.php?t=3275</a><br />
But thought I had better start a new thread in case it’s not.</p>
<p dir="auto">The attached screen-shot probably explains it better.<br />
If I click on the folder full of archives in the left explorer window, all my files appear instantly in the main window.</p>
<p dir="auto">If I click on the + sign next to the folder or on the folder in the main window then there is a Over 30-40 seconds delay and CPU usage goes to about 50% before the files show.</p>
<p dir="auto">There are about 30 pae files in the folder all around 90Mb in size, so you might need something similar to duplicate it, or maybe not.</p>
<p dir="auto">Luxor<br />
<img src="/uploads/_imported_attachments/attachment_t_3289_0_pa4filedisplaydelay.png" alt="attachment_t_3289_0_pa4filedisplaydelay.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forums.powerarchiver.com/topic/3117/slow-display-of-files-high-cpu</link><generator>RSS for Node</generator><lastBuildDate>Wed, 09 Sep 2026 03:45:48 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3117.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 15 Aug 2008 19:39:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Slow display of files + high CPU on Tue, 26 Aug 2008 16:43:09 GMT]]></title><description><![CDATA[<p dir="auto">No sub-folders in there spywolf, so I guess it is working as intended.<br />
So that’s a fix then. :)</p>
]]></description><link>https://forums.powerarchiver.com/post/18157</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18157</guid><dc:creator><![CDATA[Luxor]]></dc:creator><pubDate>Tue, 26 Aug 2008 16:43:09 GMT</pubDate></item><item><title><![CDATA[Reply to Slow display of files + high CPU on Tue, 26 Aug 2008 12:33:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/luxor" aria-label="Profile: Luxor">@<bdi>Luxor</bdi></a>:</p>
<p dir="auto">Opening the folder in the main window files appear instantly.</p>
<p dir="auto">Clicking on the + sign next to the folder in tree view and it disappears and no files appear below it.</p>
<p dir="auto">Is that the expected behaviour now ?</p>
<p dir="auto">are there any subfolders there? If not, thats how it should be… it should not show zip and cab files there anymore, that was the slow down, not only in explorer view, but also any add folder window in PA.</p>
]]></description><link>https://forums.powerarchiver.com/post/18153</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18153</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 26 Aug 2008 12:33:56 GMT</pubDate></item><item><title><![CDATA[Reply to Slow display of files + high CPU on Tue, 26 Aug 2008 11:54:45 GMT]]></title><description><![CDATA[<p dir="auto">Opening the folder in the main window files appear instantly.</p>
]]></description><link>https://forums.powerarchiver.com/post/18151</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18151</guid><dc:creator><![CDATA[Luxor]]></dc:creator><pubDate>Tue, 26 Aug 2008 11:54:45 GMT</pubDate></item><item><title><![CDATA[Reply to Slow display of files + high CPU on Mon, 25 Aug 2008 21:26:10 GMT]]></title><description><![CDATA[<p dir="auto">Please check Beta 5 via web update and see if this issue is still happening… Thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/18135</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18135</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 25 Aug 2008 21:26:10 GMT</pubDate></item></channel></rss>
