<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Wrong password makes PB4 go crazy]]></title><description><![CDATA[<p dir="auto">1. I have encrypted a file resulting in *.pae<br />
2. entered a wrong password when trying to open it<br />
3. a message opened saying just that<br />
4. I input a password again (do not know whether it was correct this time)<br />
5. the name of the file disappeared from the left screen<br />
6. clicking into the left screen resulted in the random opening of blue rectangulars, etc and PA became totally unresponsive</p>
]]></description><link>https://forums.powerarchiver.com/topic/3110/wrong-password-makes-pb4-go-crazy</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 13:51:39 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3110.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 14 Aug 2008 21:26:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Wrong password makes PB4 go crazy on Sun, 17 Aug 2008 13:40:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/prouser" aria-label="Profile: ProUser">@<bdi>ProUser</bdi></a>:</p>
<p dir="auto">what kind of pae file is it? zip, etc? How are you opening it?</p>
<p dir="auto">We tried to reproduce it but it works fine, so more details needed.</p>
]]></description><link>https://forums.powerarchiver.com/post/18038</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18038</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 17 Aug 2008 13:40:13 GMT</pubDate></item><item><title><![CDATA[Reply to Wrong password makes PB4 go crazy on Sun, 17 Aug 2008 13:22:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/davidsplash" aria-label="Profile: davidsplash">@<bdi>davidsplash</bdi></a>:</p>
<p dir="auto">basically i can fonfirm this if you enter the wrong password powerarchiver tries to extract the file then tells you that the password is wrong shouldn’t it tell you before it extracts the file or even tried too. even though nothing is extracted at the end result.</p>
<p dir="auto">thank you for your valuable input david!</p>
]]></description><link>https://forums.powerarchiver.com/post/18037</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18037</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 17 Aug 2008 13:22:15 GMT</pubDate></item><item><title><![CDATA[Reply to Wrong password makes PB4 go crazy on Sun, 17 Aug 2008 12:19:30 GMT]]></title><description><![CDATA[<p dir="auto">basically i can confirm this if you enter the wrong password powerarchiver tries to extract the file then tells you that the password is wrong shouldn’t it tell you before it extracts the file or even tried too. even though nothing is extracted at the end result.</p>
]]></description><link>https://forums.powerarchiver.com/post/18036</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18036</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Sun, 17 Aug 2008 12:19:30 GMT</pubDate></item><item><title><![CDATA[Reply to Wrong password makes PB4 go crazy on Fri, 15 Aug 2008 12:31:31 GMT]]></title><description><![CDATA[<p dir="auto">4.74 KB (4860 bytes)</p>
]]></description><link>https://forums.powerarchiver.com/post/18009</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18009</guid><dc:creator><![CDATA[ProUser]]></dc:creator><pubDate>Fri, 15 Aug 2008 12:31:31 GMT</pubDate></item><item><title><![CDATA[Reply to Wrong password makes PB4 go crazy on Fri, 15 Aug 2008 12:28:10 GMT]]></title><description><![CDATA[<p dir="auto">how big is the pae file?</p>
]]></description><link>https://forums.powerarchiver.com/post/18008</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/18008</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 15 Aug 2008 12:28:10 GMT</pubDate></item></channel></rss>
