<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Show Backup Done - Doesn&#x27;t Appear]]></title><description><![CDATA[<p dir="auto">I have just upgraded to Power Archiver 2009 which I find an improvement over the 2007 version, however when I run a backup “Backup Done” does not appear when the backup is finished even though I have checked the appropriate box. I am using Vista Business and didn’t have this problem with Power Archiver 2007.</p>
]]></description><link>https://forums.powerarchiver.com/topic/3043/show-backup-done-doesn-t-appear</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 22:21:49 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3043.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 28 Jul 2008 23:15:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Show Backup Done - Doesn&#x27;t Appear on Sat, 09 Aug 2008 17:07:03 GMT]]></title><description><![CDATA[<p dir="auto">we changed this option so it doesnt try to be smart anymore… if you check it, it will always show :)</p>
]]></description><link>https://forums.powerarchiver.com/post/17900</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/17900</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sat, 09 Aug 2008 17:07:03 GMT</pubDate></item><item><title><![CDATA[Reply to Show Backup Done - Doesn&#x27;t Appear on Wed, 30 Jul 2008 12:36:25 GMT]]></title><description><![CDATA[<p dir="auto">difference is if you have PA starting as minimized or in try… in that case, it is running “silently” without backup done message… if you disable option how to start PBS from Windows (alert tab in backup wizard), it will show backup done option.</p>
]]></description><link>https://forums.powerarchiver.com/post/17713</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/17713</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 30 Jul 2008 12:36:25 GMT</pubDate></item><item><title><![CDATA[Reply to Show Backup Done - Doesn&#x27;t Appear on Wed, 30 Jul 2008 10:59:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kafka" aria-label="Profile: kafka">@<bdi>kafka</bdi></a>:</p>
<p dir="auto">I have created a shortcut icon and placed it on the desktop. To run the backup I click on the icon.</p>
<p dir="auto">That’s the setup I have running here and “Backup Done” appears at the end. Only difference between us is that you are using Vista Business and I am using Vista Home Premium. I wouldn’t have thought that would make a difference though.</p>
]]></description><link>https://forums.powerarchiver.com/post/17708</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/17708</guid><dc:creator><![CDATA[Luxor]]></dc:creator><pubDate>Wed, 30 Jul 2008 10:59:50 GMT</pubDate></item><item><title><![CDATA[Reply to Show Backup Done - Doesn&#x27;t Appear on Wed, 30 Jul 2008 09:49:29 GMT]]></title><description><![CDATA[<p dir="auto">I have created a shortcut icon and placed it on the desktop. To run the backup I click on the icon. I don’t know whether this means I am running the backup from Windows or PowerArchiver. Either way, I’m doing what I used to do with PA 2007 which told me when the backup was completed.</p>
]]></description><link>https://forums.powerarchiver.com/post/17706</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/17706</guid><dc:creator><![CDATA[kafka]]></dc:creator><pubDate>Wed, 30 Jul 2008 09:49:29 GMT</pubDate></item><item><title><![CDATA[Reply to Show Backup Done - Doesn&#x27;t Appear on Tue, 29 Jul 2008 13:20:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kafka" aria-label="Profile: kafka">@<bdi>kafka</bdi></a>:</p>
<p dir="auto">are you starting backup from Windows or from within PowerArchiver?</p>
]]></description><link>https://forums.powerarchiver.com/post/17694</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/17694</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 29 Jul 2008 13:20:17 GMT</pubDate></item><item><title><![CDATA[Reply to Show Backup Done - Doesn&#x27;t Appear on Tue, 29 Jul 2008 05:43:47 GMT]]></title><description><![CDATA[<p dir="auto">Im also running Vista Business and I get teh alerts. But it depends. If I choose the option to run from the system tray, I get a baloon tip. If I choose run minimize I get a dialog.</p>
<p dir="auto">But a problem I noticed is that when I run any backup from PA, it opens the config window every time. Very annoying.</p>
]]></description><link>https://forums.powerarchiver.com/post/17683</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/17683</guid><dc:creator><![CDATA[MarcFou]]></dc:creator><pubDate>Tue, 29 Jul 2008 05:43:47 GMT</pubDate></item></channel></rss>
