<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[7-Zip - Optimized compression]]></title><description><![CDATA[<p dir="auto">First time in 7-Zip - Optimized compression that automatically selects best method between lzma and ppmd, for up to 40% smaller archive size….<br />
How it work? Should I on “optimized compression” in 7-zip profile?</p>
]]></description><link>https://forums.powerarchiver.com/topic/3029/7-zip-optimized-compression</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Nov 2026 14:53:59 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/3029.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 25 Jul 2008 11:35:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 7-Zip - Optimized compression on Sun, 03 Aug 2008 18:24:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bulat" aria-label="Profile: bulat">@<bdi>bulat</bdi></a>:</p>
<p dir="auto">i think it only activate PPMd compr.</p>
<p dir="auto">b2 just contains outdated tooltip for this option, remained from old versions where Enable PPMD checkbox was at this place. hopefully, this tooltip will be fixed before release</p>
<p dir="auto">thanks again for explanation</p>
]]></description><link>https://forums.powerarchiver.com/post/17777</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/17777</guid><dc:creator><![CDATA[deity]]></dc:creator><pubDate>Sun, 03 Aug 2008 18:24:55 GMT</pubDate></item><item><title><![CDATA[Reply to 7-Zip - Optimized compression on Sun, 03 Aug 2008 18:21:49 GMT]]></title><description><![CDATA[<blockquote>
]]></description><link>https://forums.powerarchiver.com/post/17776</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/17776</guid><dc:creator><![CDATA[bulat]]></dc:creator><pubDate>Sun, 03 Aug 2008 18:21:49 GMT</pubDate></item><item><title><![CDATA[Reply to 7-Zip - Optimized compression on Sun, 03 Aug 2008 17:06:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a>:</p>
<p dir="auto">no, it does what I said it does :)</p>
<p dir="auto">ok</p>
]]></description><link>https://forums.powerarchiver.com/post/17775</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/17775</guid><dc:creator><![CDATA[deity]]></dc:creator><pubDate>Sun, 03 Aug 2008 17:06:15 GMT</pubDate></item><item><title><![CDATA[Reply to 7-Zip - Optimized compression on Sun, 03 Aug 2008 17:05:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/deity" aria-label="Profile: deity">@<bdi>deity</bdi></a>:</p>
<p dir="auto">hmm… strange…i think it only activate PPMd compr.</p>
]]></description><link>https://forums.powerarchiver.com/post/17774</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/17774</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 03 Aug 2008 17:05:16 GMT</pubDate></item><item><title><![CDATA[Reply to 7-Zip - Optimized compression on Sun, 03 Aug 2008 17:02:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a>:</p>
<p dir="auto">yes, turn it on… it will be fine tuned by the end of beta period and automatic, but for now you have to manually turn it on.</p>
<p dir="auto">It detects file and determines if it is better to use PPMd/LZMA on file by file basis, something that 7zip currently does not do. PPMD is only used for text files as thats where it is better than LZMA.</p>
<p dir="auto">First time this has been done in any 7zip app.</p>
]]></description><link>https://forums.powerarchiver.com/post/17773</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/17773</guid><dc:creator><![CDATA[deity]]></dc:creator><pubDate>Sun, 03 Aug 2008 17:02:09 GMT</pubDate></item><item><title><![CDATA[Reply to 7-Zip - Optimized compression on Fri, 25 Jul 2008 12:56:17 GMT]]></title><description><![CDATA[<p dir="auto">p.s. anyone else likes 7zip updates? Update, Rename, Delete files from archives, filename encryption support and optimized compression?</p>
<p dir="auto">More to come in upcoming months :-).</p>
<p dir="auto">And who says Standard users arent getting anything? :P</p>
]]></description><link>https://forums.powerarchiver.com/post/17607</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/17607</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 25 Jul 2008 12:56:17 GMT</pubDate></item><item><title><![CDATA[Reply to 7-Zip - Optimized compression on Fri, 25 Jul 2008 12:55:06 GMT]]></title><description><![CDATA[<p dir="auto">yes, turn it on… it will be fine tuned by the end of beta period and automatic, but for now you have to manually turn it on.</p>
]]></description><link>https://forums.powerarchiver.com/post/17606</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/17606</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 25 Jul 2008 12:55:06 GMT</pubDate></item></channel></rss>
