<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Tempfolder for every *.zip File]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">since PA2007 i get hundreds of Temp Folder in:</p>
<p dir="auto">C:\Users\USERNAME\AppData\Local\Temp</p>
<p dir="auto">for each *.zip File i ever unzipped with PA2007.</p>
<p dir="auto">Why are they not deleted after using them??? :cool:</p>
<p dir="auto">Every Week i clear my TMP Folders and PA leaves sometime over 100k Files in them.</p>
<p dir="auto">Vista 32bit</p>
]]></description><link>https://forums.powerarchiver.com/topic/2925/tempfolder-for-every-zip-file</link><generator>RSS for Node</generator><lastBuildDate>Mon, 14 Sep 2026 03:26:57 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/2925.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 19 Jun 2008 05:40:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Tempfolder for every *.zip File on Wed, 25 Jun 2008 13:14:19 GMT]]></title><description><![CDATA[<p dir="auto">PA should not create those temp files - ours are created differently.</p>
<p dir="auto">I am thinking it might be Windows Defender scanning those files automatically.</p>
]]></description><link>https://forums.powerarchiver.com/post/17107</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/17107</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 25 Jun 2008 13:14:19 GMT</pubDate></item><item><title><![CDATA[Reply to Tempfolder for every *.zip File on Wed, 25 Jun 2008 04:31:22 GMT]]></title><description><![CDATA[<p dir="auto">No - not sure.</p>
<p dir="auto">The Filenames are as Example:</p>
<p dir="auto">Temp60_FILENAME<br />
Temp61_FILENAME</p>
<p dir="auto">and so on ….</p>
<p dir="auto">Using KIS2009 (Kaspersky Internet Security V9.0)<br />
<img src="/uploads/_imported_attachments/attachment_p_14710_0_greenshot_2008-06-25_06-40-50.jpg" alt="attachment_p_14710_0_greenshot_2008-06-25_06-40-50.jpg" class=" img-fluid img-markdown" /><br />
<img src="/uploads/_imported_attachments/attachment_p_14710_1_greenshot_2008-06-25_06-41-21.jpg" alt="attachment_p_14710_1_greenshot_2008-06-25_06-41-21.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forums.powerarchiver.com/post/17104</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/17104</guid><dc:creator><![CDATA[redlabour]]></dc:creator><pubDate>Wed, 25 Jun 2008 04:31:22 GMT</pubDate></item><item><title><![CDATA[Reply to Tempfolder for every *.zip File on Thu, 19 Jun 2008 09:41:24 GMT]]></title><description><![CDATA[<p dir="auto">are you sure there are from PA and not some antivirus application that is checking those files?</p>
<p dir="auto">What are the names of the folders?</p>
]]></description><link>https://forums.powerarchiver.com/post/17075</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/17075</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Thu, 19 Jun 2008 09:41:24 GMT</pubDate></item></channel></rss>
