<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Setup is run when I open archive]]></title><description><![CDATA[<p dir="auto">Under Vista, when I open an archive, PA runs always a command (“_pasetup.exe /paassociate”) and I need to enter my credentials.</p>
<p dir="auto">Where I can remove this command to reassociate the extensions?</p>
<p dir="auto">Thanks<br />
Eric</p>
]]></description><link>https://forums.powerarchiver.com/topic/2856/setup-is-run-when-i-open-archive</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 20:08:30 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/2856.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 21 Apr 2008 18:21:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Setup is run when I open archive on Mon, 21 Apr 2008 19:36:55 GMT]]></title><description><![CDATA[<p dir="auto">you lose only the warning…. all archives that you checked should work fine…</p>
<p dir="auto">thanks,</p>
]]></description><link>https://forums.powerarchiver.com/post/16786</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/16786</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 21 Apr 2008 19:36:55 GMT</pubDate></item><item><title><![CDATA[Reply to Setup is run when I open archive on Mon, 21 Apr 2008 19:02:41 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">you need to go to config, file formats and uncheck show associate window option. That should make it stop.</p>
<p dir="auto">thanks, seems to work. But are the choosen archives now associated or do I loose some functionality?</p>
]]></description><link>https://forums.powerarchiver.com/post/16784</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/16784</guid><dc:creator><![CDATA[EricSch]]></dc:creator><pubDate>Mon, 21 Apr 2008 19:02:41 GMT</pubDate></item><item><title><![CDATA[Reply to Setup is run when I open archive on Mon, 21 Apr 2008 18:55:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ericsch" aria-label="Profile: EricSch">@<bdi>EricSch</bdi></a>:</p>
Eric</p>
<p dir="auto">thank you,</p>
]]></description><link>https://forums.powerarchiver.com/post/16783</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/16783</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 21 Apr 2008 18:55:32 GMT</pubDate></item><item><title><![CDATA[Reply to Setup is run when I open archive on Mon, 21 Apr 2008 18:26:11 GMT]]></title><description><![CDATA[<p dir="auto">uninstall using revounistall and reinstall powerarchivber and if it happens again report what you have on your system</p>
]]></description><link>https://forums.powerarchiver.com/post/16780</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/16780</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Mon, 21 Apr 2008 18:26:11 GMT</pubDate></item></channel></rss>
