<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PA shell extensions missing in Total Commander]]></title><description><![CDATA[<p dir="auto">Running Vista Ultimate SP1, shell extensions don’t show up when right-clicking associated files in Total Commander. They do when using the Windows Explorer interface. Could a PA programmer reply stating whether this is TC or PA that needs to be fixed please? Thank you.</p>
]]></description><link>https://forums.powerarchiver.com/topic/2771/pa-shell-extensions-missing-in-total-commander</link><generator>RSS for Node</generator><lastBuildDate>Mon, 14 Sep 2026 02:11:43 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/2771.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 09 Mar 2008 08:42:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PA shell extensions missing in Total Commander on Wed, 12 Mar 2008 14:43:27 GMT]]></title><description><![CDATA[<p dir="auto">Sorry crunch. I’m Using Vista 32-bit here, no SP1 installed yet.<br />
Free Commander is also 32-bit and as far as I know there is no 64-bit version of that yet.</p>
]]></description><link>https://forums.powerarchiver.com/post/16489</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/16489</guid><dc:creator><![CDATA[Luxor]]></dc:creator><pubDate>Wed, 12 Mar 2008 14:43:27 GMT</pubDate></item><item><title><![CDATA[Reply to PA shell extensions missing in Total Commander on Wed, 12 Mar 2008 13:50:41 GMT]]></title><description><![CDATA[<p dir="auto">My error, I failed to state that this is 64-bit Vista SP1.</p>
<p dir="auto">Luxor: Are you using Vista 64-bit? Yes? Is it SP1? Yes? Is your Free Commander 64-bit?</p>
<p dir="auto">Thanks ahead of time and again, my bad for not giving complete details at first. This issue has me arsed. :x</p>
]]></description><link>https://forums.powerarchiver.com/post/16486</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/16486</guid><dc:creator><![CDATA[crunch]]></dc:creator><pubDate>Wed, 12 Mar 2008 13:50:41 GMT</pubDate></item><item><title><![CDATA[Reply to PA shell extensions missing in Total Commander on Tue, 11 Mar 2008 18:24:01 GMT]]></title><description><![CDATA[<p dir="auto">I agree with David’s comments. I use Free Commander and PA’s shell extensions work fine in that so it must be a problem with total commander</p>
]]></description><link>https://forums.powerarchiver.com/post/16485</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/16485</guid><dc:creator><![CDATA[Luxor]]></dc:creator><pubDate>Tue, 11 Mar 2008 18:24:01 GMT</pubDate></item><item><title><![CDATA[Reply to PA shell extensions missing in Total Commander on Tue, 11 Mar 2008 15:49:23 GMT]]></title><description><![CDATA[<p dir="auto">this is down to total commander though you might like to have a word with total commander programer to see if this can be corrected. Explorer is the standard on windows so what works in explorer should work on total commander unless the author doesn’t want it to for some reason.</p>
]]></description><link>https://forums.powerarchiver.com/post/16484</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/16484</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Tue, 11 Mar 2008 15:49:23 GMT</pubDate></item></channel></rss>
