<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Uninstalling Power Archiver]]></title><description><![CDATA[<p dir="auto">I downloaded the trial version of Power Archiver and would now like to uninstall it (I don’t have a need for it any more and don’t want/need it on my system), but for some reason it won’t let me uninstall it. Any help/suggestions?</p>
]]></description><link>https://forums.powerarchiver.com/topic/2474/uninstalling-power-archiver</link><generator>RSS for Node</generator><lastBuildDate>Wed, 09 Sep 2026 21:51:42 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/2474.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 15 Aug 2007 16:43:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Uninstalling Power Archiver on Fri, 17 Aug 2007 01:15:29 GMT]]></title><description><![CDATA[<p dir="auto">Here is how to do it:<br />
<a href="http://www.conexware.com/support/index.php?_m=knowledgebase&amp;_a=viewarticle&amp;kbarticleid=10" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.conexware.com/support/index.php?_m=knowledgebase&amp;_a=viewarticle&amp;kbarticleid=10</a></p>
<p dir="auto">after that you can install it again and then properly uninstall it.</p>
<p dir="auto">You probably deleted some parts of the install before running uninstallations, and Windows Installer does not like that.</p>
<p dir="auto">thanks,</p>
]]></description><link>https://forums.powerarchiver.com/post/15500</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/15500</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 17 Aug 2007 01:15:29 GMT</pubDate></item><item><title><![CDATA[Reply to Uninstalling Power Archiver on Thu, 16 Aug 2007 08:02:42 GMT]]></title><description><![CDATA[<p dir="auto">Try installing a new version trial of PowerArchiver, by default PA Uninstalls the old and re-installs…</p>
<p dir="auto">Then just uninstall the latest PA.</p>
<p dir="auto">If that doesnt work, you might need to manually delete the folder and clear the Registry.</p>
]]></description><link>https://forums.powerarchiver.com/post/15498</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/15498</guid><dc:creator><![CDATA[RJWaring]]></dc:creator><pubDate>Thu, 16 Aug 2007 08:02:42 GMT</pubDate></item><item><title><![CDATA[Reply to Uninstalling Power Archiver on Thu, 16 Aug 2007 00:50:06 GMT]]></title><description><![CDATA[<p dir="auto">Am running XP, Winzip’s installed, no software made in Delphi, and I do have administrator privileges.<br />
I’ll try dial-a-fix; thanks.</p>
]]></description><link>https://forums.powerarchiver.com/post/15497</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/15497</guid><dc:creator><![CDATA[Arkarian]]></dc:creator><pubDate>Thu, 16 Aug 2007 00:50:06 GMT</pubDate></item><item><title><![CDATA[Reply to Uninstalling Power Archiver on Wed, 15 Aug 2007 20:44:24 GMT]]></title><description><![CDATA[<p dir="auto">i’ve uninstalled it and reinstalled it so can not tell you why it doesn’t work. What operatiung system do you use and do you have any other archivers installed or more importantly any software m,ade in delphi</p>
<p dir="auto">just a thought have you admin privilages. the only other suggestion i can give is to try a program called dial-a-fix found on the internet and run that and then try and uninstall if that fails then reinstall pa and reboot and then try and uninstall and let us know.</p>
]]></description><link>https://forums.powerarchiver.com/post/15496</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/15496</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Wed, 15 Aug 2007 20:44:24 GMT</pubDate></item></channel></rss>
