<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Empty folder when extracted.]]></title><description><![CDATA[<p dir="auto">PowerArchiver 2007 10.20 Beta 2</p>
<p dir="auto">Folder is empty when extracting following file using PA</p>
<p dir="auto">test file<br />
<a href="http://www.protechsystems.us/stuff/mosproductsnap_1.1.0.tar.gz" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.protechsystems.us/stuff/mosproductsnap_1.1.0.tar.gz</a></p>
<p dir="auto">It works OK with Winzip and WinRAR</p>
]]></description><link>https://forums.powerarchiver.com/topic/2455/empty-folder-when-extracted</link><generator>RSS for Node</generator><lastBuildDate>Sat, 08 Aug 2026 18:32:57 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/2455.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 04 Aug 2007 02:52:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Empty folder when extracted. on Wed, 05 Sep 2007 00:58:15 GMT]]></title><description><![CDATA[<p dir="auto">Fixed in version 10.2 Beta 4</p>
]]></description><link>https://forums.powerarchiver.com/post/15565</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/15565</guid><dc:creator><![CDATA[aravot]]></dc:creator><pubDate>Wed, 05 Sep 2007 00:58:15 GMT</pubDate></item><item><title><![CDATA[Reply to Empty folder when extracted. on Sun, 19 Aug 2007 04:49:32 GMT]]></title><description><![CDATA[<p dir="auto">Try FireFox</p>
]]></description><link>https://forums.powerarchiver.com/post/15509</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/15509</guid><dc:creator><![CDATA[aravot]]></dc:creator><pubDate>Sun, 19 Aug 2007 04:49:32 GMT</pubDate></item><item><title><![CDATA[Reply to Empty folder when extracted. on Wed, 15 Aug 2007 16:25:50 GMT]]></title><description><![CDATA[<p dir="auto">simply right click on the link and select Save Target as, instead of clicking on Open… that will work around any IE issues…</p>
]]></description><link>https://forums.powerarchiver.com/post/15495</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/15495</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 15 Aug 2007 16:25:50 GMT</pubDate></item><item><title><![CDATA[Reply to Empty folder when extracted. on Wed, 15 Aug 2007 16:05:25 GMT]]></title><description><![CDATA[<p dir="auto">I suppose you have a problem with extension after downloading it. Make sure the filename on your Local drive is mosproductsnap_1.1.0.tar.gz . Then it works perfect!</p>
<p dir="auto">After downloading with IE from URL you post, I got mosproductsnap_1.1.0.tar.tar file, and this file couldn’t be extracted perfectly because we can’t know this is GZIPed TAR.</p>
]]></description><link>https://forums.powerarchiver.com/post/15494</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/15494</guid><dc:creator><![CDATA[ivan]]></dc:creator><pubDate>Wed, 15 Aug 2007 16:05:25 GMT</pubDate></item><item><title><![CDATA[Reply to Empty folder when extracted. on Tue, 14 Aug 2007 03:46:24 GMT]]></title><description><![CDATA[<p dir="auto">This issue is still present in v10.20.05 (08/2007)</p>
]]></description><link>https://forums.powerarchiver.com/post/15473</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/15473</guid><dc:creator><![CDATA[aravot]]></dc:creator><pubDate>Tue, 14 Aug 2007 03:46:24 GMT</pubDate></item><item><title><![CDATA[Reply to Empty folder when extracted. on Sat, 04 Aug 2007 10:04:59 GMT]]></title><description><![CDATA[<p dir="auto">Confirmed in Windows XP Pro SP2 Latest windows Update. PA10.20.02.</p>
<p dir="auto">You can open PA And view the files within the .tar.gz archive then drag and drop each one to a folder and that works.</p>
<p dir="auto">But the auto extract button doesnt seem to recognise it.</p>
<p dir="auto">I can also confirm this is not fixed in Beta 3 PA10.20.03</p>
]]></description><link>https://forums.powerarchiver.com/post/15366</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/15366</guid><dc:creator><![CDATA[RJWaring]]></dc:creator><pubDate>Sat, 04 Aug 2007 10:04:59 GMT</pubDate></item></channel></rss>
