<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[RAR problem]]></title><description><![CDATA[<p dir="auto">PA 2007 will not recognize RAR archives above *.R01. Is this a configuration thing? What needs to happen here?:confused:</p>
]]></description><link>https://forums.powerarchiver.com/topic/2432/rar-problem</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Nov 2026 17:36:51 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/2432.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 21 Jul 2007 21:44:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to RAR problem on Tue, 24 Jul 2007 08:40:01 GMT]]></title><description><![CDATA[<p dir="auto">Ah now I see… You were referring to extracting, not the assoicated icons etc.</p>
<p dir="auto">A misconception (they must be associated in order to extract) is not dumb by any means - but it sometimes helps to “Just try it first” ;)</p>
]]></description><link>https://forums.powerarchiver.com/post/15245</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/15245</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Tue, 24 Jul 2007 08:40:01 GMT</pubDate></item><item><title><![CDATA[Reply to RAR problem on Tue, 24 Jul 2007 02:54:02 GMT]]></title><description><![CDATA[<p dir="auto">Wow, I’m dumb…It handles it with even less BS than I could’ve imagined…open the .rar and it grabs the rest…duh…:o</p>
]]></description><link>https://forums.powerarchiver.com/post/15244</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/15244</guid><dc:creator><![CDATA[Imaginelane]]></dc:creator><pubDate>Tue, 24 Jul 2007 02:54:02 GMT</pubDate></item><item><title><![CDATA[Reply to RAR problem on Mon, 23 Jul 2007 20:34:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/davidsplash" aria-label="Profile: davidsplash">@<bdi>davidsplash</bdi></a>:</p>
<p dir="auto">… you can not extract files from an incomplete set of spanned rar files …</p>
<p dir="auto">Yep<br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/tbgbe" aria-label="Profile: TBGBe">@<bdi>TBGBe</bdi></a>:</p>
<p dir="auto">Besides, partial extraction is not supported.</p>
<p dir="auto">As I said. :p</p>
]]></description><link>https://forums.powerarchiver.com/post/15242</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/15242</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Mon, 23 Jul 2007 20:34:37 GMT</pubDate></item><item><title><![CDATA[Reply to RAR problem on Mon, 23 Jul 2007 12:20:34 GMT]]></title><description><![CDATA[<p dir="auto">what i think he is trying to say yes it would be nice to have them associated. However the point that he also made was that you can not extract files from an incomplete set of spanned rar files which you can do with the 7zip filke manager and why is this.</p>
<p dir="auto">when will this be fixed</p>
]]></description><link>https://forums.powerarchiver.com/post/15236</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/15236</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Mon, 23 Jul 2007 12:20:34 GMT</pubDate></item><item><title><![CDATA[Reply to RAR problem on Mon, 23 Jul 2007 06:52:23 GMT]]></title><description><![CDATA[<p dir="auto">But why is it necessary/needed :confused:<br />
*.rar. *.r00 and *.r01 are associated - I don’t see a benefit having “anyname.r28” associated.</p>
<p dir="auto">The work involved is to “bloat” the registry with 98 silly extension associations - this is why RAR changed their naming scheme in the first place.</p>
]]></description><link>https://forums.powerarchiver.com/post/15234</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/15234</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Mon, 23 Jul 2007 06:52:23 GMT</pubDate></item><item><title><![CDATA[Reply to RAR problem on Mon, 23 Jul 2007 02:59:36 GMT]]></title><description><![CDATA[<p dir="auto">I’m glad it’s not my ineptitude. If I went in to folder options and related all the file extensions to PA RAR files it would probably work, but c’mon…another option would be to rename all the files using a batch renamer utility like <a href="http://www.download.com/3000-2248_4-10703208.html" target="_blank" rel="noopener noreferrer nofollow ugc">File Renamer</a> to have *_part1.rar as a name instead of *.R01…etc. That I know would work. The question is how much work should one have to do for a product that says they support such file types?</p>
]]></description><link>https://forums.powerarchiver.com/post/15233</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/15233</guid><dc:creator><![CDATA[Imaginelane]]></dc:creator><pubDate>Mon, 23 Jul 2007 02:59:36 GMT</pubDate></item><item><title><![CDATA[Reply to RAR problem on Sun, 22 Jul 2007 17:21:03 GMT]]></title><description><![CDATA[<p dir="auto">this is a good point to make 7zip file manager supports this so why not pa, it can be done and is needed the other day at work i had to install the 7zip file manager cause of this program with pa. This will ecrtainmly drive custoimers away and towards winrar</p>
]]></description><link>https://forums.powerarchiver.com/post/15230</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/15230</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Sun, 22 Jul 2007 17:21:03 GMT</pubDate></item><item><title><![CDATA[Reply to RAR problem on Sun, 22 Jul 2007 12:16:01 GMT]]></title><description><![CDATA[<p dir="auto">There is no need/benefit in “recognising” R08, R67 etc.<br />
]]></description><link>https://forums.powerarchiver.com/post/15227</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/15227</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Sun, 22 Jul 2007 12:16:01 GMT</pubDate></item></channel></rss>
