<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Queued Compressions]]></title><description><![CDATA[<p dir="auto">Hi all</p>
<p dir="auto">I use the queue a lot and was wondering if it would be possible to default the minimizing to the tray for a zip in progress.</p>
<p dir="auto">In general the minimize to tray would be nice if it was defaultable to one or the other instead of it being a 2 click process every time.</p>
<p dir="auto">Also the zip in progress icon is fine if using 7zip but when using the standard zip compression and compressing a single large file as the progress is always at 0% the icon does not display any meaningful information instead it just looks like it’s not working.</p>
<p dir="auto">Also would it be possible to not display the pa icon in the tray but still have queue enabled</p>
]]></description><link>https://forums.powerarchiver.com/topic/2346/queued-compressions</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 08:36:22 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/2346.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 18 Jun 2007 08:41:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Queued Compressions on Mon, 18 Jun 2007 16:29:01 GMT]]></title><description><![CDATA[<p dir="auto">probably just me being fussy and trying to save my tray space :)</p>
]]></description><link>https://forums.powerarchiver.com/post/14981</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14981</guid><dc:creator><![CDATA[fatboy]]></dc:creator><pubDate>Mon, 18 Jun 2007 16:29:01 GMT</pubDate></item><item><title><![CDATA[Reply to Queued Compressions on Mon, 18 Jun 2007 16:00:30 GMT]]></title><description><![CDATA[<p dir="auto">what would be the benefit of that? right now you can also open PA, open archives and backups right simple click, as well as turning it off with simple click…</p>
]]></description><link>https://forums.powerarchiver.com/post/14980</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14980</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 18 Jun 2007 16:00:30 GMT</pubDate></item><item><title><![CDATA[Reply to Queued Compressions on Mon, 18 Jun 2007 13:10:34 GMT]]></title><description><![CDATA[<p dir="auto">could the queue not run as a service or an application that does not show an icon in the tray</p>
]]></description><link>https://forums.powerarchiver.com/post/14979</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14979</guid><dc:creator><![CDATA[fatboy]]></dc:creator><pubDate>Mon, 18 Jun 2007 13:10:34 GMT</pubDate></item><item><title><![CDATA[Reply to Queued Compressions on Mon, 18 Jun 2007 11:51:52 GMT]]></title><description><![CDATA[<p dir="auto">PA Starter is application that monitors if PA has any queues and then sends it to work. Without it, PA queue will not function.</p>
]]></description><link>https://forums.powerarchiver.com/post/14978</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14978</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 18 Jun 2007 11:51:52 GMT</pubDate></item></channel></rss>
