<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[SFX Enhancements]]></title><description><![CDATA[<p dir="auto">I don’t know if anybody suggested it before because I cannot use “search forum” option.</p>
<p dir="auto">I suggest:</p>
<ul>
<li>allowing use of all system variables during self-extraction creation (not “program files” only)</li>
</ul>
<p dir="auto">and optionallly…</p>
<ul>
<li>add a “before extraction action”</li>
</ul>
<p dir="auto">In that way it is possible to create a sort of mini Installation program or whatever you want!</p>
<p dir="auto">Bye</p>
]]></description><link>https://forums.powerarchiver.com/topic/2339/sfx-enhancements</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 16:39:20 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/2339.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 13 Jun 2007 11:20:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to SFX Enhancements on Thu, 14 Jun 2007 16:41:59 GMT]]></title><description><![CDATA[<p dir="auto">yes, help is helpful :-)</p>
]]></description><link>https://forums.powerarchiver.com/post/14967</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14967</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Thu, 14 Jun 2007 16:41:59 GMT</pubDate></item><item><title><![CDATA[Reply to SFX Enhancements on Thu, 14 Jun 2007 07:54:55 GMT]]></title><description><![CDATA[<p dir="auto">Thank you. I didn’t see all of them before but it is not easy to understand if you don’t use the help. I suggest you to insert a little tip in the caption such as<br />
Default “UnZip to” folder (see help for a system variables):<br />
or similar</p>
]]></description><link>https://forums.powerarchiver.com/post/14965</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14965</guid><dc:creator><![CDATA[netsurfer]]></dc:creator><pubDate>Thu, 14 Jun 2007 07:54:55 GMT</pubDate></item><item><title><![CDATA[Reply to SFX Enhancements on Wed, 13 Jun 2007 22:36:42 GMT]]></title><description><![CDATA[<p dir="auto">you can use pretty much all of the system variables, check help when in SFX menu.</p>
]]></description><link>https://forums.powerarchiver.com/post/14960</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14960</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 13 Jun 2007 22:36:42 GMT</pubDate></item></channel></rss>
