<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Bug with the context Menu]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">First, excuse me if i made some mistake in my english, i am a french user of Power Archiver</p>
<p dir="auto">Since i update to power archiver v10.10.10 fr, i have a bug with the context menu.<br />
The options i select in the program …</p>
<p dir="auto">For compression :<br />
In a sub menu,<br />
Compress in ( for each format aivaible )</p>
<p dir="auto">For extraction :<br />
Ine a sub menu,<br />
Extract here<br />
Extract in separate folders<br />
Create sfx<br />
Test Archive<br />
Convert</p>
<p dir="auto">And no handlers out of the sub menu.</p>
<p dir="auto">… Doesn’t match with the option avaible in the context menu, i have always the context menu configured by défault mixed with my own programed menu, even if my own menu is présent and writted in the options of the programm.</p>
<p dir="auto">And for exemple, when i click on extract to ‘path &amp; folder’ this is the compress with option menu who apear…</p>
<p dir="auto">I tried to uninstall power archiver, reboot, réinstall it but the problem is the same.</p>
<p dir="auto">Note that when i come back to the previous version ( v10.01.03 fr ) all is good in my context menu.</p>
<p dir="auto">i tried too to disable other context menu handlers from other compression programs as winrar to avoid a conflict, but this act didn’t correct the problem.</p>
<p dir="auto">I am under win xp home french sp2, not tested under windows vista, the time is missing to me<br />
And now works with the v10.01.03 version :( …</p>
<p dir="auto">Anibody have an idea ?</p>
]]></description><link>https://forums.powerarchiver.com/topic/2329/bug-with-the-context-menu</link><generator>RSS for Node</generator><lastBuildDate>Tue, 17 Nov 2026 12:14:43 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/2329.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 04 Jun 2007 23:03:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Bug with the context Menu on Tue, 05 Jun 2007 19:41:43 GMT]]></title><description><![CDATA[<p dir="auto">to be more specific copy from 10.01 Languages\PASHELL_FR.PLF to 10.10 to Languages\PASHELL_FR.PLF, restart Windows and check.</p>
]]></description><link>https://forums.powerarchiver.com/post/14859</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14859</guid><dc:creator><![CDATA[ivan]]></dc:creator><pubDate>Tue, 05 Jun 2007 19:41:43 GMT</pubDate></item><item><title><![CDATA[Reply to Bug with the context Menu on Tue, 05 Jun 2007 17:48:09 GMT]]></title><description><![CDATA[<p dir="auto">try copying shell.plf file from translations folder of 10.01 to 10.10… see if that works. It seems as if 10.10 translation has issue - please confirm so we know.</p>
<p dir="auto">thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/14855</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14855</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 05 Jun 2007 17:48:09 GMT</pubDate></item><item><title><![CDATA[Reply to Bug with the context Menu on Tue, 05 Jun 2007 11:31:49 GMT]]></title><description><![CDATA[<p dir="auto">so the problem is that when you click on something in shell extensions, it doesnt do what it is supposed to?</p>
]]></description><link>https://forums.powerarchiver.com/post/14846</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14846</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 05 Jun 2007 11:31:49 GMT</pubDate></item></channel></rss>
