<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Use self-extracting exe: extract to a user&#x27;s profile?]]></title><description><![CDATA[<p dir="auto">Basically I’m trying to create a self extracting exe that will extract to c:\Documents and Settings&lt;username&gt;\Application Data\Microsoft\…</p>
<p dir="auto">However, I can’t seem to find a sysvariable that’ll work with PA which resolves to a username! Help!&lt;/username&gt;</p>
]]></description><link>https://forums.powerarchiver.com/topic/2325/use-self-extracting-exe-extract-to-a-user-s-profile</link><generator>RSS for Node</generator><lastBuildDate>Sat, 17 Oct 2026 12:03:08 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/2325.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 04 Jun 2007 19:28:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Use self-extracting exe: extract to a user&#x27;s profile? on Mon, 11 Jun 2007 16:55:52 GMT]]></title><description><![CDATA[<p dir="auto">Haha I actually googled it on my own and figured it out this morning. I didn’t even know the reply. I came to find my answer.</p>
<p dir="auto">Here’s the key I had to build:<br />
HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders\AppData|Microsoft\Stationery</p>
]]></description><link>https://forums.powerarchiver.com/post/14929</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14929</guid><dc:creator><![CDATA[tacos]]></dc:creator><pubDate>Mon, 11 Jun 2007 16:55:52 GMT</pubDate></item><item><title><![CDATA[Reply to Use self-extracting exe: extract to a user&#x27;s profile? on Fri, 08 Jun 2007 07:03:03 GMT]]></title><description><![CDATA[<p dir="auto">Here you go:<br />
<a href="http://windowsxp.mvps.org/usershellfolders.htm" target="_blank" rel="noopener noreferrer nofollow ugc">http://windowsxp.mvps.org/usershellfolders.htm</a></p>
<p dir="auto">Google is your friend :-)</p>
]]></description><link>https://forums.powerarchiver.com/post/14883</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14883</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 08 Jun 2007 07:03:03 GMT</pubDate></item><item><title><![CDATA[Reply to Use self-extracting exe: extract to a user&#x27;s profile? on Fri, 08 Jun 2007 04:03:04 GMT]]></title><description><![CDATA[<p dir="auto">I looked in that registry area. I didn’t see anything for documents and settings :(</p>
]]></description><link>https://forums.powerarchiver.com/post/14882</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14882</guid><dc:creator><![CDATA[tacos]]></dc:creator><pubDate>Fri, 08 Jun 2007 04:03:04 GMT</pubDate></item><item><title><![CDATA[Reply to Use self-extracting exe: extract to a user&#x27;s profile? on Fri, 08 Jun 2007 00:10:47 GMT]]></title><description><![CDATA[<p dir="auto">you can pick up folders from registry:</p>
<p dir="auto">example from help:</p>
<p dir="auto">Default UnZip To folder: HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\CommonFilesDir|MySoftware</p>
<p dir="auto">Typically: C:\Program Files\Common Files\MySoftware</p>
<p dir="auto">this will work with ZIP SFX for sure.</p>
<p dir="auto">thanks,</p>
]]></description><link>https://forums.powerarchiver.com/post/14881</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14881</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 08 Jun 2007 00:10:47 GMT</pubDate></item><item><title><![CDATA[Reply to Use self-extracting exe: extract to a user&#x27;s profile? on Tue, 05 Jun 2007 14:09:45 GMT]]></title><description><![CDATA[<p dir="auto">I’ve been using ZIP but can use whatever… this is with PA 2007 (paid copy)</p>
]]></description><link>https://forums.powerarchiver.com/post/14848</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14848</guid><dc:creator><![CDATA[tacos]]></dc:creator><pubDate>Tue, 05 Jun 2007 14:09:45 GMT</pubDate></item><item><title><![CDATA[Reply to Use self-extracting exe: extract to a user&#x27;s profile? on Tue, 05 Jun 2007 11:32:42 GMT]]></title><description><![CDATA[<p dir="auto">what SFX are you using?</p>
<p dir="auto">thanks</p>
]]></description><link>https://forums.powerarchiver.com/post/14847</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14847</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 05 Jun 2007 11:32:42 GMT</pubDate></item></channel></rss>
