<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[&quot;As Web Page&quot; Bug]]></title><description><![CDATA[<p dir="auto">When “As Web Page” option is set, I can’t select files (using mouse)<br />
in the Main PA window! I can open them only…</p>
<p dir="auto">Is it Normal? :rolleyes:</p>
<p dir="auto">Thanks,<br />
=-=-=-=-=-=-=-=-=<br />
NTFS<br />
<a href="http://www.gorosoft.narod.ru" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.gorosoft.narod.ru</a><br />
=-=-=-=-=-=-=-=-=</p>
]]></description><link>https://forums.powerarchiver.com/topic/230/as-web-page-bug</link><generator>RSS for Node</generator><lastBuildDate>Sat, 14 Nov 2026 09:37:14 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/230.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 01 Oct 2004 11:43:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to &quot;As Web Page&quot; Bug on Tue, 05 Oct 2004 16:50:46 GMT]]></title><description><![CDATA[<p dir="auto">Inside of archive - I dont see any difference in how mouse selection works between As Web Page and Explorer mode… On the other hand, in Classic mode, to select something with a mouse, your mouse pointer needs to be outside of any of file info columns - to do it properly with larger archives, you can narrow the last column so you can click on area outside of columns to select them.</p>
<p dir="auto">I hope I was clear enough, was I? Outside archives, in Explorer mode, it does not work at all and thats one of the updates planned for 9.1 as talked about previously….</p>
<p dir="auto">thanks,</p>
]]></description><link>https://forums.powerarchiver.com/post/6404</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/6404</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 05 Oct 2004 16:50:46 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;As Web Page&quot; Bug on Fri, 01 Oct 2004 14:36:16 GMT]]></title><description><![CDATA[<p dir="auto">you are right, the mouse selection just works INSIDE of archives.</p>
]]></description><link>https://forums.powerarchiver.com/post/6379</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/6379</guid><dc:creator><![CDATA[klumy]]></dc:creator><pubDate>Fri, 01 Oct 2004 14:36:16 GMT</pubDate></item></channel></rss>
