<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Not handling multi-part .rar archives properly]]></title><description><![CDATA[<p dir="auto">v10.10.09</p>
<p dir="auto">If you have a multi-part .rar archive which is using the ‘old style volume names’ i.e.:</p>
<p dir="auto">my_archive.r00<br />
my_archive.r01<br />
my_archive.r02<br />
my_archive.r03<br />
my_archive.r04<br />
my_archive.r05<br />
my_archive.r06<br />
my_archive.r07<br />
my_archive.r08<br />
my_archive.r09<br />
my_archive.r10<br />
my_archive.r11<br />
my_archive.r12<br />
my_archive.rar</p>
<p dir="auto">…and you right-click my_archive.r00 or my_archive.r01 (both file extensions are associated with PA) and choose to ‘Extract Here’ - PA just bombs out.</p>
<p dir="auto">However, if you right-click my_archive.rar and choose to ‘Extract Here’ - PA handles that file extension fine and will extract the archive contents to the current directory.</p>
<p dir="auto">Can you allow PA to do the same for *.r00 and *.r01 files?</p>
]]></description><link>https://forums.powerarchiver.com/topic/2291/not-handling-multi-part-rar-archives-properly</link><generator>RSS for Node</generator><lastBuildDate>Tue, 11 Aug 2026 08:18:19 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/2291.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 19 May 2007 21:44:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Not handling multi-part .rar archives properly on Tue, 22 May 2007 14:00:32 GMT]]></title><description><![CDATA[<p dir="auto">I tested extracting from both the *.r00 and *.r01 file from a couple different multi-part archives and it worked ok. Before this was reproducible every time so this seems to be fixed. I’ll advise if I notice it again and give details. Nice job on the fix btw.</p>
]]></description><link>https://forums.powerarchiver.com/post/14695</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14695</guid><dc:creator><![CDATA[crunch]]></dc:creator><pubDate>Tue, 22 May 2007 14:00:32 GMT</pubDate></item><item><title><![CDATA[Reply to Not handling multi-part .rar archives properly on Tue, 22 May 2007 11:06:40 GMT]]></title><description><![CDATA[<p dir="auto">This should be fixed in latest version:<br />
<a href="http://www.powerarchiver.com/test/release10/powarc1010.exe" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.powerarchiver.com/test/release10/powarc1010.exe</a></p>
<p dir="auto">Please let us know…</p>
<p dir="auto">thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/14682</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14682</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 22 May 2007 11:06:40 GMT</pubDate></item><item><title><![CDATA[Reply to Not handling multi-part .rar archives properly on Mon, 21 May 2007 14:27:46 GMT]]></title><description><![CDATA[<p dir="auto">Some more info to report about this:</p>
<p dir="auto">If you have a 2-piece multi-part archive e.g.:</p>
my_archive.rar</p>
<p dir="auto">…and you right-click my_archive.r00 and select Power Archiver 2007 &gt; Extract Here, you’ll get an error message stating that there was a CRC error, continue?</p>
<p dir="auto">If you do this with the my_archive.rar file it extracts the archive contents to the current directory, as expected.</p>
<p dir="auto">If you have a larger multi-part archive and try to extract from the *.r00 or *.r01 file then PA just crashes without giving the CRC error popup.</p>
<p dir="auto">It seems to not be loading all parts of a multi-part archive during extraction <em>unless</em> you begin with the *.rar file.</p>
]]></description><link>https://forums.powerarchiver.com/post/14677</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14677</guid><dc:creator><![CDATA[crunch]]></dc:creator><pubDate>Mon, 21 May 2007 14:27:46 GMT</pubDate></item><item><title><![CDATA[Reply to Not handling multi-part .rar archives properly on Sun, 20 May 2007 19:01:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/deity" aria-label="Profile: deity">@<bdi>deity</bdi></a>:</p>
<p dir="auto">I find out links…<br />
It alpha version…<br />
Why so complicated author do?</p>
<p dir="auto">alphas are not posted as betas until they become betas… so no, you wont see that version up on the site until we think it is ready.</p>
]]></description><link>https://forums.powerarchiver.com/post/14675</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14675</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 20 May 2007 19:01:34 GMT</pubDate></item><item><title><![CDATA[Reply to Not handling multi-part .rar archives properly on Sun, 20 May 2007 17:31:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tbgbe" aria-label="Profile: TBGBe">@<bdi>TBGBe</bdi></a>:</p>
<p dir="auto">10.10.09 is a test version of beta 2.<br />
So it is not available via Update (at least not yet).<br />
Check other threads if you must try it.</p>
]]></description><link>https://forums.powerarchiver.com/post/14673</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14673</guid><dc:creator><![CDATA[deity]]></dc:creator><pubDate>Sun, 20 May 2007 17:31:03 GMT</pubDate></item><item><title><![CDATA[Reply to Not handling multi-part .rar archives properly on Sun, 20 May 2007 17:25:13 GMT]]></title><description><![CDATA[<p dir="auto">10.10.09 is a test version of beta 2.<br />
]]></description><link>https://forums.powerarchiver.com/post/14672</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14672</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Sun, 20 May 2007 17:25:13 GMT</pubDate></item><item><title><![CDATA[Reply to Not handling multi-part .rar archives properly on Sun, 20 May 2007 13:19:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunch" aria-label="Profile: crunch">@<bdi>crunch</bdi></a>:</p>
my_archive.rar</p>
<p dir="auto">hmm…v10.10.09???<br />
<img src="http://img81.imageshack.us/img81/5408/20070520171939cg2.jpg" alt="" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forums.powerarchiver.com/post/14666</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14666</guid><dc:creator><![CDATA[deity]]></dc:creator><pubDate>Sun, 20 May 2007 13:19:25 GMT</pubDate></item><item><title><![CDATA[Reply to Not handling multi-part .rar archives properly on Sun, 20 May 2007 11:58:12 GMT]]></title><description><![CDATA[<p dir="auto">it worked before… so we will check it out</p>
]]></description><link>https://forums.powerarchiver.com/post/14665</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14665</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 20 May 2007 11:58:12 GMT</pubDate></item></channel></rss>
