<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Removin Passwords From Files]]></title><description><![CDATA[<p dir="auto">the option thet i want to see is thet if let’s say<br />
i’m downloading a protected file and i have the<br />
password thet i would only have to type it<br />
once and then remove the password from the<br />
file so thet i wan’t have to retype it in the future<br />
and by doing this i want have to extract and<br />
recompress the contant of the file because it’s<br />
annoying to do tet all the time:)</p>
<p dir="auto">10X IN ADVANCE.:)</p>
]]></description><link>https://forums.powerarchiver.com/topic/2231/removin-passwords-from-files</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 14:13:49 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/2231.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 Apr 2007 17:19:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Removin Passwords From Files on Wed, 02 May 2007 22:30:49 GMT]]></title><description><![CDATA[<p dir="auto">of decomressing/recompressing the file every file<br />
i download thet comes with a password to<br />
no passworded file an automatic procedure thet would be great:)</p>
]]></description><link>https://forums.powerarchiver.com/post/14504</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14504</guid><dc:creator><![CDATA[aviramof]]></dc:creator><pubDate>Wed, 02 May 2007 22:30:49 GMT</pubDate></item><item><title><![CDATA[Reply to Removin Passwords From Files on Wed, 02 May 2007 14:02:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/aviramof" aria-label="Profile: aviramof">@<bdi>aviramof</bdi></a>:</p>
<p dir="auto">… you still want to keep the file as is you usually want it without a password and you don’t want to extract and then recompress because thet is just a awaist of time …</p>
<p dir="auto">Well obviously you cannot “keep the file as is” if you are decrypting it (removing password) :rolleyes:</p>
<p dir="auto">If you have an “automatic” process it would still be decompress / recompress but then you have added a seperate “rename/delete” difficulty.</p>
]]></description><link>https://forums.powerarchiver.com/post/14500</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14500</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Wed, 02 May 2007 14:02:00 GMT</pubDate></item><item><title><![CDATA[Reply to Removin Passwords From Files on Wed, 02 May 2007 10:19:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/davidsplash" aria-label="Profile: davidsplash">@<bdi>davidsplash</bdi></a>:</p>
<p dir="auto">pa can remember passwords for an archive.</p>
<p dir="auto">what u wnat is to turn an archive into a non passworded archive. This can be done but the whole point of passwords is to make it passworded. you could extract the files yourself and re archive them without password.</p>
<p dir="auto">it’s maybe the whole point to make it passworded when<br />
you upload the file or when someone eles upload the file but once you have already downloaded the file and you already know the password but<br />
you still want to keep the file as is you usually want it without<br />
a password and you don’t want to extract and then recompress<br />
because thet is just a awaist of time so if it’s possible to<br />
add this option thet would be great:)</p>
]]></description><link>https://forums.powerarchiver.com/post/14499</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14499</guid><dc:creator><![CDATA[aviramof]]></dc:creator><pubDate>Wed, 02 May 2007 10:19:28 GMT</pubDate></item><item><title><![CDATA[Reply to Removin Passwords From Files on Mon, 30 Apr 2007 08:54:36 GMT]]></title><description><![CDATA[<p dir="auto">No, davidsplash was suggesting that you extract the files using the password and then create a new archive file (in whichever format you want) without a password.<br />
You could then delete the original password protected file.</p>
]]></description><link>https://forums.powerarchiver.com/post/14476</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14476</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Mon, 30 Apr 2007 08:54:36 GMT</pubDate></item><item><title><![CDATA[Reply to Removin Passwords From Files on Mon, 30 Apr 2007 02:09:13 GMT]]></title><description><![CDATA[<p dir="auto">Something like this is what you mean?</p>
<p dir="auto"><a href="http://www.picozip.com/prt/index.html" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.picozip.com/prt/index.html</a></p>
]]></description><link>https://forums.powerarchiver.com/post/14474</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14474</guid><dc:creator><![CDATA[iampedro]]></dc:creator><pubDate>Mon, 30 Apr 2007 02:09:13 GMT</pubDate></item><item><title><![CDATA[Reply to Removin Passwords From Files on Sun, 29 Apr 2007 17:50:03 GMT]]></title><description><![CDATA[<p dir="auto">pa can remember passwords for an archive.</p>
]]></description><link>https://forums.powerarchiver.com/post/14461</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14461</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Sun, 29 Apr 2007 17:50:03 GMT</pubDate></item></channel></rss>
