<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Installing Plug-in?]]></title><description><![CDATA[<p dir="auto">:confused: There were 2 Plug-ins in the plug-ins download site<br />
1. MSI Plus 0.6.0.1<br />
2. CHMDir 0.40c</p>
<p dir="auto">How to install them…? *.ppf file<br />
I’m a bit blur! :D</p>
]]></description><link>https://forums.powerarchiver.com/topic/2194/installing-plug-in</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 16:59:57 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/2194.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 16 Mar 2007 16:47:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Installing Plug-in? on Sat, 17 Mar 2007 03:13:47 GMT]]></title><description><![CDATA[<p dir="auto">hola spwolf…it’s working fine by using the one that i download from the link you gave.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forums.powerarchiver.com/post/14177</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14177</guid><dc:creator><![CDATA[Naruto]]></dc:creator><pubDate>Sat, 17 Mar 2007 03:13:47 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Plug-in? on Sat, 17 Mar 2007 02:36:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/naruto" aria-label="Profile: Naruto">@<bdi>Naruto</bdi></a>:</p>
<p dir="auto">I double click it but nothing happen and one more thing when i try to open chm and msi files it says Access violation bla… bla… bla…</p>
<p dir="auto">Fix:<br />
<a href="http://www.powerarchiver.com/test/release10/powarc1001.exe" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.powerarchiver.com/test/release10/powarc1001.exe</a></p>
<p dir="auto">let me know if it works… thanks</p>
]]></description><link>https://forums.powerarchiver.com/post/14174</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14174</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sat, 17 Mar 2007 02:36:43 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Plug-in? on Fri, 16 Mar 2007 21:26:37 GMT]]></title><description><![CDATA[<p dir="auto">tested on windows 2000 both plugins work</p>
]]></description><link>https://forums.powerarchiver.com/post/14173</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14173</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Fri, 16 Mar 2007 21:26:37 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Plug-in? on Fri, 16 Mar 2007 19:28:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/naruto" aria-label="Profile: Naruto">@<bdi>Naruto</bdi></a>:</p>
<p dir="auto">aaaaaargh</p>
]]></description><link>https://forums.powerarchiver.com/post/14171</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14171</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 16 Mar 2007 19:28:35 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Plug-in? on Fri, 16 Mar 2007 18:40:08 GMT]]></title><description><![CDATA[<p dir="auto">I double click it but nothing happen and one more thing when i try to open chm and msi files it says Access violation bla… bla… bla…</p>
]]></description><link>https://forums.powerarchiver.com/post/14170</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14170</guid><dc:creator><![CDATA[Naruto]]></dc:creator><pubDate>Fri, 16 Mar 2007 18:40:08 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Plug-in? on Fri, 16 Mar 2007 18:30:14 GMT]]></title><description><![CDATA[<p dir="auto">doubleclick on the file in windows explorer and pa offers to install it?</p>
]]></description><link>https://forums.powerarchiver.com/post/14169</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14169</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 16 Mar 2007 18:30:14 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Plug-in? on Fri, 16 Mar 2007 18:19:27 GMT]]></title><description><![CDATA[<p dir="auto">wow….now I see the light! thanks Terry!</p>
]]></description><link>https://forums.powerarchiver.com/post/14168</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14168</guid><dc:creator><![CDATA[Naruto]]></dc:creator><pubDate>Fri, 16 Mar 2007 18:19:27 GMT</pubDate></item><item><title><![CDATA[Reply to Installing Plug-in? on Fri, 16 Mar 2007 18:00:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/naruto" aria-label="Profile: Naruto">@<bdi>Naruto</bdi></a>:</p>
<p dir="auto">:confused: How to install them…? *.ppf file</p>
<p dir="auto">There <em>may</em> be a quicker way but<br />
Open ppf in PA<br />
Extract wcx file to a folder e.g. PowerArchiver\PLUGINS<br />
PA Options<br />
Install plug-in as described in PowerArchiver help.<br />
Don’t forget to enter the (associated) filetype(s).</p>
]]></description><link>https://forums.powerarchiver.com/post/14167</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14167</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Fri, 16 Mar 2007 18:00:58 GMT</pubDate></item></channel></rss>
