<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[SFX file still says Powerarchiver 2004]]></title><description><![CDATA[<p dir="auto">When you run the created SFX file and press the about button, it still says “Powerarchiver 2004”. It doesn’t matter wich archive type is selected.</p>
<p dir="auto">Using PA 10 Dutch version.</p>
]]></description><link>https://forums.powerarchiver.com/topic/2155/sfx-file-still-says-powerarchiver-2004</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Jul 2026 09:04:39 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/2155.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 03 Mar 2007 14:13:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to SFX file still says Powerarchiver 2004 on Mon, 05 Mar 2007 18:15:02 GMT]]></title><description><![CDATA[<p dir="auto">it is just translation issue (not updated…).</p>
]]></description><link>https://forums.powerarchiver.com/post/14008</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14008</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 05 Mar 2007 18:15:02 GMT</pubDate></item><item><title><![CDATA[Reply to SFX file still says Powerarchiver 2004 on Sun, 04 Mar 2007 19:41:44 GMT]]></title><description><![CDATA[<p dir="auto">Probably yes, because Dutch translators didn’t update this. If you have checked English version you would see it is updated to 2007 - the engine is same, just some texts maybe haven’t been updated in translated versions.</p>
]]></description><link>https://forums.powerarchiver.com/post/14001</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14001</guid><dc:creator><![CDATA[ivan]]></dc:creator><pubDate>Sun, 04 Mar 2007 19:41:44 GMT</pubDate></item><item><title><![CDATA[Reply to SFX file still says Powerarchiver 2004 on Sun, 04 Mar 2007 19:08:17 GMT]]></title><description><![CDATA[<p dir="auto">Yes. Maybe they’re still using the “old” SFX-Engine to create them.<br />
It says “Created with PA 2006” for Zip-Archives and correctly 2007 for 7z-Archives.<br />
(Tested with German PA 2007)</p>
]]></description><link>https://forums.powerarchiver.com/post/14000</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14000</guid><dc:creator><![CDATA[H4ndy]]></dc:creator><pubDate>Sun, 04 Mar 2007 19:08:17 GMT</pubDate></item></channel></rss>
