<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PA 2007 B10 context menu entries missing (Vista x64 german)]]></title><description><![CDATA[<p dir="auto">Hello</p>
<p dir="auto">I installed PA 2007 Beta 10 on the german Windows Vista Ultimate x64 today.</p>
<p dir="auto">Even I had the impression (maybe I’m wrong) that the context menu did work in the beta version of Vista it does not work anymore.</p>
<p dir="auto">Maybe the problem lies in the fact that even I select “program files” PA gets installed in “program files (x86)”. I tried “progra~1” which resulted in the right “program files” directory, however, the context menu isn’t working.</p>
<p dir="auto">Given other topics concerning context menu I searched the registry and found a key starting with “{d03d3…}” in which the pashelext.dll is mentioned.</p>
<p dir="auto">Any suggestions ? Or things I can provide to find a solution.</p>
]]></description><link>https://forums.powerarchiver.com/topic/2094/pa-2007-b10-context-menu-entries-missing-vista-x64-german</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 04:32:24 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/2094.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 10 Feb 2007 14:37:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PA 2007 B10 context menu entries missing (Vista x64 german) on Sat, 17 Feb 2007 21:26:53 GMT]]></title><description><![CDATA[<p dir="auto">drag and drop with the shell (works only in extraction)? I am not sure if functionality was implemented in x64 extensions, since they are completly different… Ivan will respond to that…</p>
<p dir="auto">Reuse seems to work with english, will check with german…</p>
]]></description><link>https://forums.powerarchiver.com/post/13829</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/13829</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sat, 17 Feb 2007 21:26:53 GMT</pubDate></item><item><title><![CDATA[Reply to PA 2007 B10 context menu entries missing (Vista x64 german) on Sat, 17 Feb 2007 20:39:14 GMT]]></title><description><![CDATA[<p dir="auto">Checked with RC1 just now.</p>
<p dir="auto">It works partly. The normal context menu is working in german now.</p>
<p dir="auto">The “drag and drop” menu is still missing. I forgot to test this with beta 10 but in RC1 it is missing in the english version as well.</p>
<p dir="auto">Maybe there is something to configure to make this menu show up which I’ve missed so far ?</p>
<p dir="auto">For me PA is now useful again (or the first time with Vista x64), thanks to the fast response.</p>
<p dir="auto">If there is something to try about the drag’n’drop Menu let me know.</p>
<p dir="auto">BTW, in the german (or maybe international) version the option “reuse window” does not work. Or better, as far back as I know it never did. Personally this is more a cosmetic thing anyway.</p>
]]></description><link>https://forums.powerarchiver.com/post/13828</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/13828</guid><dc:creator><![CDATA[Henry_Jones]]></dc:creator><pubDate>Sat, 17 Feb 2007 20:39:14 GMT</pubDate></item><item><title><![CDATA[Reply to PA 2007 B10 context menu entries missing (Vista x64 german) on Sat, 17 Feb 2007 00:17:02 GMT]]></title><description><![CDATA[<p dir="auto">please check with RC1… thanks</p>
]]></description><link>https://forums.powerarchiver.com/post/13809</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/13809</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sat, 17 Feb 2007 00:17:02 GMT</pubDate></item><item><title><![CDATA[Reply to PA 2007 B10 context menu entries missing (Vista x64 german) on Sat, 10 Feb 2007 17:52:43 GMT]]></title><description><![CDATA[<p dir="auto">Surprisingly the english setup works.</p>
<p dir="auto">It still goes to “program files (x86)” even I select otherwise but the context menu is working.</p>
]]></description><link>https://forums.powerarchiver.com/post/13772</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/13772</guid><dc:creator><![CDATA[Henry_Jones]]></dc:creator><pubDate>Sat, 10 Feb 2007 17:52:43 GMT</pubDate></item><item><title><![CDATA[Reply to PA 2007 B10 context menu entries missing (Vista x64 german) on Sat, 10 Feb 2007 15:07:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/henry_jones" aria-label="Profile: Henry_Jones">@<bdi>Henry_Jones</bdi></a>:</p>
<p dir="auto">Yes.</p>
<p dir="auto">Windows XP is still on another (physical) harddrive but the Vista OS is on it’s own drive and was installed as “clean” installation.</p>
<p dir="auto">Another idea: If Vista forces the install dir to be “program files (x86)” maybe the routine in the setup which selects the pashellext.dll version to be copied selects the x86 one.</p>
<p dir="auto">I personally forgot how it goes with 64bit, but other members of the team have PA 2007 working on 64bit. So it might be something with german setup.</p>
<p dir="auto">Can you check english setup and see how it works?</p>
<p dir="auto">thanks,</p>
]]></description><link>https://forums.powerarchiver.com/post/13766</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/13766</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sat, 10 Feb 2007 15:07:24 GMT</pubDate></item><item><title><![CDATA[Reply to PA 2007 B10 context menu entries missing (Vista x64 german) on Sat, 10 Feb 2007 15:04:52 GMT]]></title><description><![CDATA[<p dir="auto">Yes.</p>
]]></description><link>https://forums.powerarchiver.com/post/13765</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/13765</guid><dc:creator><![CDATA[Henry_Jones]]></dc:creator><pubDate>Sat, 10 Feb 2007 15:04:52 GMT</pubDate></item><item><title><![CDATA[Reply to PA 2007 B10 context menu entries missing (Vista x64 german) on Sat, 10 Feb 2007 14:41:59 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">we will check it out… I thought it was working? Was this your first PA install on that computer?</p>
]]></description><link>https://forums.powerarchiver.com/post/13763</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/13763</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sat, 10 Feb 2007 14:41:59 GMT</pubDate></item></channel></rss>
