<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PA 10 Beta 5: Shell Extension problem on Vista x64]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">the shell extensions on Vista X64 are still not working.<br />
This time, I don’t know if it is because I have made modifications in the registry base for PA 10. Beta 4 but there is something that really bothers me:<br />
the PASHLEXT64.DLL is not present in C:\Program Files (x86)\PowerArchiver. Is it normal???</p>
<p dir="auto">Default install after un-install of Beta 4 and reboot</p>
<p dir="auto">Regards,</p>
<p dir="auto">Vykranth</p>
]]></description><link>https://forums.powerarchiver.com/topic/2022/pa-10-beta-5-shell-extension-problem-on-vista-x64</link><generator>RSS for Node</generator><lastBuildDate>Wed, 11 Mar 2026 06:35:40 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/2022.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 10 Jan 2007 14:23:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PA 10 Beta 5: Shell Extension problem on Vista x64 on Wed, 10 Jan 2007 17:46:26 GMT]]></title><description><![CDATA[<p dir="auto">Thanks!</p>
<p dir="auto">We found the problem and should be fixed in Beta 6.</p>
]]></description><link>https://forums.powerarchiver.com/post/13317</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/13317</guid><dc:creator><![CDATA[ivan]]></dc:creator><pubDate>Wed, 10 Jan 2007 17:46:26 GMT</pubDate></item><item><title><![CDATA[Reply to PA 10 Beta 5: Shell Extension problem on Vista x64 on Wed, 10 Jan 2007 17:10:30 GMT]]></title><description><![CDATA[<p dir="auto">Now there should be now PASHLEXT64.DLL no matter which if the OS is 64-bit or not. Installation has two PASHLEXT.DLLs and install the one that is for target OS.</p>
<p dir="auto">I will check on my Win x64.</p>
]]></description><link>https://forums.powerarchiver.com/post/13316</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/13316</guid><dc:creator><![CDATA[ivan]]></dc:creator><pubDate>Wed, 10 Jan 2007 17:10:30 GMT</pubDate></item></channel></rss>
