<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Tar of long filenames]]></title><description><![CDATA[<p dir="auto">PACOMP 400b1 has similar problems with long filenames in TAR compression as PA9.01<br />
see<br />
<a href="http://www.powerarchiver.com/forums/showthread.php?t=71" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.powerarchiver.com/forums/showthread.php?t=71</a></p>
<p dir="auto">Test result attached - when 3 text files were compressed</p>
]]></description><link>https://forums.powerarchiver.com/topic/198/tar-of-long-filenames</link><generator>RSS for Node</generator><lastBuildDate>Sun, 08 Nov 2026 04:30:01 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/198.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 09 Sep 2004 14:39:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Tar of long filenames on Fri, 10 Sep 2004 12:20:51 GMT]]></title><description><![CDATA[<p dir="auto">Definetelly not for 4.0.</p>
<p dir="auto">We shall see later - currenty PACL is very usefull because it doesn’t need any DLLs to work with most archives. If we shall do on some big engine changes then probably we should have to distribute DLLs for some formats and then it becames more complicated for users who use PACL in their own programs for some operations.</p>
]]></description><link>https://forums.powerarchiver.com/post/6288</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/6288</guid><dc:creator><![CDATA[ivan]]></dc:creator><pubDate>Fri, 10 Sep 2004 12:20:51 GMT</pubDate></item><item><title><![CDATA[Reply to Tar of long filenames on Fri, 10 Sep 2004 10:35:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ivan" aria-label="Profile: ivan">@<bdi>ivan</bdi></a>:</p>
<p dir="auto">As in same PA post - PA v9.1 will be (hopefully) the first one that will support this.</p>
<p dir="auto">Can that be translated as will be implemented in PACL at some point in the future?<br />
Perhaps 4.x or even 5.0 - but not 4.0 ?</p>
<p dir="auto">If so, coud move this into WishList ;)</p>
]]></description><link>https://forums.powerarchiver.com/post/6287</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/6287</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Fri, 10 Sep 2004 10:35:24 GMT</pubDate></item><item><title><![CDATA[Reply to Tar of long filenames on Thu, 09 Sep 2004 15:34:42 GMT]]></title><description><![CDATA[<p dir="auto">Although PACL and PA use completelty different TAR/GZIP engines, currently both of them do not support long filenames in TAR archives (even extended POSIX, nor GNU TAR standard).</p>
]]></description><link>https://forums.powerarchiver.com/post/6284</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/6284</guid><dc:creator><![CDATA[ivan]]></dc:creator><pubDate>Thu, 09 Sep 2004 15:34:42 GMT</pubDate></item></channel></rss>
