<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[2007 Beta 3 RAR SFX Extraction Bug]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Just thought I would report this bug, incase it hasn’t been stumbled across. I came across this issue when trying to extract the contents of a <a href="http://www.nero.com" target="_blank" rel="noopener noreferrer nofollow ugc">Nero 7</a> update. Extraction does begin but quits out unexpectedly without any error message of information if there was a problem.</p>
<ol>
<li>Effects Right-Click context menu extraction.</li>
<li>Effects extraction when you open the file using the Open With PowerArchiver item in the context menu.</li>
<li>Effects extract function when you open PowerArchiver and then open the file that way.</li>
</ol>
<p dir="auto">Thanks, Andrew Robinson.</p>
]]></description><link>https://forums.powerarchiver.com/topic/1961/2007-beta-3-rar-sfx-extraction-bug</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 02:38:42 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/1961.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 10 Dec 2006 00:34:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 2007 Beta 3 RAR SFX Extraction Bug on Mon, 11 Dec 2006 01:57:52 GMT]]></title><description><![CDATA[<p dir="auto">we will check it out and let you know.</p>
<p dir="auto">thanks,</p>
]]></description><link>https://forums.powerarchiver.com/post/13078</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/13078</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 11 Dec 2006 01:57:52 GMT</pubDate></item><item><title><![CDATA[Reply to 2007 Beta 3 RAR SFX Extraction Bug on Sun, 10 Dec 2006 21:11:54 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I have tested this with many .RAR files, including non-SFX, and sometimes it will extract and create a folder, but then extract no files.</p>
<p dir="auto">Just a side note, no other archive software is installed. I have uninstalled the Beta and installed the latest official release, and the problem is non-existant, so points to some sort of problem with the new beta.</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forums.powerarchiver.com/post/13077</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/13077</guid><dc:creator><![CDATA[andyr2005]]></dc:creator><pubDate>Sun, 10 Dec 2006 21:11:54 GMT</pubDate></item><item><title><![CDATA[Reply to 2007 Beta 3 RAR SFX Extraction Bug on Sun, 10 Dec 2006 14:12:39 GMT]]></title><description><![CDATA[<p dir="auto">I’ve found that this happens with any large rar file, not just sfx ones. PA just quits without extracting all the files in the archive.</p>
]]></description><link>https://forums.powerarchiver.com/post/13073</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/13073</guid><dc:creator><![CDATA[By-Tor]]></dc:creator><pubDate>Sun, 10 Dec 2006 14:12:39 GMT</pubDate></item><item><title><![CDATA[Reply to 2007 Beta 3 RAR SFX Extraction Bug on Sun, 10 Dec 2006 13:18:22 GMT]]></title><description><![CDATA[<p dir="auto">thanks, we will check it out. It is very important that every bug is reported, no matter how small or large…</p>
<p dir="auto">thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/13071</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/13071</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 10 Dec 2006 13:18:22 GMT</pubDate></item><item><title><![CDATA[Reply to 2007 Beta 3 RAR SFX Extraction Bug on Sun, 10 Dec 2006 08:11:08 GMT]]></title><description><![CDATA[<p dir="auto">what version of the update do you have</p>
<p dir="auto">Secondley what things do u have open on your computer what programs are running.</p>
<p dir="auto">Thirdly do you have any other archivers on your computer.<br />
Have you tred this with another rar sfx yet.</p>
]]></description><link>https://forums.powerarchiver.com/post/13070</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/13070</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Sun, 10 Dec 2006 08:11:08 GMT</pubDate></item></channel></rss>
