<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Encrypted Files…]]></title><description><![CDATA[<p dir="auto">Hey,</p>
<p dir="auto">Im really frustrated. I’ve run through my list of passwords yet i can’t figure out the password to a encypted zip i made a while ago. It contains alot of my personal stuff for taxes and stuff and in my absentmindedness i deleted the source…is there any way I can get around needing to remember my password?</p>
<p dir="auto">Thnx,<br />
Longbowe</p>
]]></description><link>https://forums.powerarchiver.com/topic/196/encrypted-files</link><generator>RSS for Node</generator><lastBuildDate>Thu, 10 Sep 2026 18:50:32 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/196.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 30 Nov 2004 23:51:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Encrypted Files… on Wed, 01 Dec 2004 17:09:00 GMT]]></title><description><![CDATA[<p dir="auto">in future use a program called key maker it will let you input a phrase and generate a password from tyhat phrase.</p>
]]></description><link>https://forums.powerarchiver.com/post/6820</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/6820</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Wed, 01 Dec 2004 17:09:00 GMT</pubDate></item><item><title><![CDATA[Reply to Encrypted Files… on Wed, 01 Dec 2004 11:46:38 GMT]]></title><description><![CDATA[<p dir="auto">Well thats just wonderful I thought i’d have some fun and use 256-AES well that means i’m just SOL. Thanks anyways guys if any one else has a suggestion please reply.</p>
<p dir="auto">Longbowe</p>
]]></description><link>https://forums.powerarchiver.com/post/6818</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/6818</guid><dc:creator><![CDATA[Longbowe]]></dc:creator><pubDate>Wed, 01 Dec 2004 11:46:38 GMT</pubDate></item><item><title><![CDATA[Reply to Encrypted Files… on Wed, 01 Dec 2004 09:14:10 GMT]]></title><description><![CDATA[<p dir="auto">You can still attempt a dictionary test on AES encrypted archives, but it will take a lot longer. If you can remember the number of characters in the password, then you could write a script/program to do the job much faster.</p>
]]></description><link>https://forums.powerarchiver.com/post/6816</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/6816</guid><dc:creator><![CDATA[deipotent]]></dc:creator><pubDate>Wed, 01 Dec 2004 09:14:10 GMT</pubDate></item><item><title><![CDATA[Reply to Encrypted Files… on Wed, 01 Dec 2004 09:04:14 GMT]]></title><description><![CDATA[<p dir="auto">If the ZIP “encryption” was done using a simple password on the file (what PA refers to as PK V204) then you might be able to do this with a type of dictionary test - just keep trying different passwords.</p>
<p dir="auto">If the encryption was done using any of the AES methods, then you are out of luck.<br />
This is the point of strong encryption, it cannot be easily broken.</p>
]]></description><link>https://forums.powerarchiver.com/post/6815</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/6815</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Wed, 01 Dec 2004 09:04:14 GMT</pubDate></item></channel></rss>
